Old 21st July 2010, 00:58   #10341  |  Link
rica
Guys,
Haven't got any response to this post, pls:
http://forum.doom9.org/showpost.php?...ostcount=10321
_ _ _ _ _
rica is offline   Reply With Quote
Old 21st July 2010, 01:07   #10342  |  Link
rica
And another question even i'm not sure being in the right place?
What code should be used in converting any lossless HD audio to PCM before remuxing to BD with TSMuxer? (if i want to make a PCM BD?)
eac3to input.thd(dtshd) output.pcm
and later
pcm2Tsmu input.pcm output.pcm (to be recognized by TSMuxer)
OR,
eac3to input.thd(dtshd) output.wav
Or, doesn't matter?
_ _ _ _ _
Old 21st July 2010, 02:14   #10343  |  Link
dansrfe
@ rica post 1
forget nero. libav works fine if not better.
@ rica post 2
I don't think it matters.
Old 21st July 2010, 02:21   #10344  |  Link
rica
1) OK i forgot nero but i still wonder where is neroaudiodecoder2?
2) Yes, thanks.
Old 21st July 2010, 02:23   #10345  |  Link
SamuriHL
SamuriHL's Avatar
Rica, are you just thinking about Nero for the DTS-HD MA decoding? TMT3's DTS-HD MA codec works fine if you register it properly, but, I think you know that? Am I missing something?
EDIT: Oh, sorry, you meant to use Nero for TrueHD decoding. Yea, libav does a fine job of that. Nero's not needed.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 21st July 2010, 02:32   #10346  |  Link
rica
Samuri,
the question was not nero needed or not; it was why i can not use it even it's worse than libav or even i force it to be used in eac3to?
And where is this f***g nero decoder?
Old 21st July 2010, 02:34   #10347  |  Link
SamuriHL
SamuriHL's Avatar
Originally Posted by rica View Post
Samuri,
Yea, I don't know the answer to that one. I haven't installed Nero in a very long time.
Old 21st July 2010, 02:37   #10348  |  Link
rica
Pls reinstall it on your seven and tell me where it is?
You will see Ne.Audible.ax- fake nero audio decoder2 on Seven.
And i need a hack. But i haven't been able to do.
Old 21st July 2010, 02:38   #10349  |  Link
SamuriHL
SamuriHL's Avatar
Oh god no. I don't have a recent version of Nero. I don't even know what the last version I bought was. 8 maybe? I'm not spoiling a good 7 install with that!
Old 21st July 2010, 02:42   #10350  |  Link
rica
Nero 7; what i've been speaking about which eac3to supposed to be used to use. With its HD patch.
Old 21st July 2010, 02:45   #10351  |  Link
SamuriHL
SamuriHL's Avatar
Is Nero 7 even compatible with W7 64? I've read a lot of reports that it no workie. I've never tried. I don't even know if I still have the email with my key kicking around. Is there a reason you're wanting to get it to work so badly?
Old 21st July 2010, 02:48   #10352  |  Link
rica
Normally all 32 bit SW should work on 64 bit OS.
No reason; i just wonder
Old 21st July 2010, 02:52   #10353  |  Link
SamuriHL
SamuriHL's Avatar
Yea, I don't have my license for 7. I only have a license for 8. I never bothered with anything after that cause it became ridiculously bloated. I have no intention of installing Nero again. As for eac3to and TrueHD, I've had no problem at all with the built in libav code. Works perfectly.
Old 21st July 2010, 02:53   #10354  |  Link
rica
OK, thanks Samuri.
So, i think nautilus7 should revize the wiki.
Old 21st July 2010, 07:20   #10355  |  Link
ACrowley
Remember that theres a bigger Problem with the NeroAudio Decoder in eac3to! The DRC isnt removed properly so the Decoder is not recommended
ACrowley is offline   Reply With Quote
Old 21st July 2010, 09:25   #10356  |  Link
hubblec4
Matroska find' ich toll
Originally Posted by mastrandrea View Post
No, I was meaning I need to sync audio and video, and the audio is 400ms shorter.
streching is possible in MKVmergeGUI.
you need the time of the video and the audio( audio= 100sek ; video 100,400sek) then you divide the videotime by the audiotime and you get the stretch-value.
hubblec4 is offline   Reply With Quote
Old 21st July 2010, 12:06   #10357  |  Link
deado
Using Nero 7 with Win 7 64 here no problems.
deado is offline   Reply With Quote
Old 21st July 2010, 12:56   #10358  |  Link
rebkell
I assume the audio is out of sync? If it drifts over the entire clip, you could just add some audio loops spaced equally over the entire audio track.
-edit=0:00:00,0ms loops or removes audio data at the specified runtime
-silence/-loop forces usage of silence (or looping) for audio edits
If it's 48Khz AC3 you could add 12 or 13 32ms edits spaced equally and get with 16ms.
rebkell is offline   Reply With Quote
Old 21st July 2010, 14:05   #10359  |  Link
SamuriHL
SamuriHL's Avatar
Well, I guess that's good. I could only find my key for Nero 8. Not that I care in either case. I'm perfectly content with the libav support for TrueHD in eac3to. And I use ImgBurn for all my burning needs. That's all I ever really used Nero for anyway...stable burning. Then they started bloating it up with all kinds of other useless stuff. Meh.
Old 21st July 2010, 20:47   #10360  |  Link
stax76
There is a improved dialog for Blu-ray demuxing in StaxRip:
http://forum.doom9.org/showthread.ph...18#post1419618
eac3to
