Old 21st March 2010, 12:02   #1  |  Link
M_Knox
Custom user
M_Knox's Avatar
[PgcEdit plugin] Options Dialog plugin v1.0 (2010.03.21)
Hello,
This plugin displays all PgcEdit options in a single dialog window with tabs. That's the only purpose of this plugin.
Installation is plain simple. Just copy the .tcl file info PgcEdit's plugins subfolder (for example C:\Program Files\PgcEdit\plugins) and run PgcEdit.exe
The plugin installs itself to the "Options" menu as "Show options dialog" command, while its options are placed in a submenu of the "Plugins" menu (I hope it's not too confusing). Optionally (and this option is enabled by default) the plugin hides the "Options" menu contents leaving only "Show options dialog" command. You can turn this off via the plugin's configuration.
The plugins needs PgcEdit 9.3 or later to function (9.3 is on the way, so that's why I'm releasing this plugin )
Additional URL for the plugin package: http://members.elysium.pl/morris/pro...plugin_1.0.rar
M.O.R.R.I.S.: Mechanical Obedient Replicant Responsible for Infiltration and Sabotage
morris#rarlab*com
M_Knox is offline   Reply With Quote
Old 22nd March 2010, 10:34   #2  |  Link
blutach
Country Member
blutach's Avatar
Literally - neat!
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
options dialog, pgcedit, plugin
