Old 7th November 2010, 16:12   #481  |  Link
Sirber
retired developer
Sirber's Avatar
Originally Posted by Alex_080 View Post
Is it possible add two tabs likes one tab contains sources like Anime, Movie etc. and other tab contains profiles like slower, slow, normal?so that we can choose what we want.
would be possible, but no. I think the presets are good as is.
Detritus Software
Sirber is offline   Reply With Quote
Old 7th November 2010, 16:47   #482  |  Link
Sirber
retired developer
Sirber's Avatar
found a bug:
* merge will fail if the output file already exist. fixed in dev build.
Detritus Software
Old 7th November 2010, 16:52   #483  |  Link
Alex_080
User of X264
Are the values of psy_rd and aq really affect the quality in anime encoding?
I want to know is it ok with psy_rd=1.00:0.00 and aq=1:1.00.
Alex_080 is offline   Reply With Quote
Old 7th November 2010, 16:53   #484  |  Link
Sirber
retired developer
Sirber's Avatar
I don't know, best ask in AVC forum.
Detritus Software
Old 7th November 2010, 18:17   #485  |  Link
Sirber
retired developer
Sirber's Avatar
I'm testing the encoding queue. might have a release tomorrow if it works.
changes since the last dev release:
* added subtitle support (soft, to Matroska only)
* added new icon/logo
* added presets: "faster", "fast" and "medium"
* updated container/codec selection:
** x264/PC locks to MKV :
** x264/iPod to MP4 and AAC-LC
** WebM to WebM and Vorbis
** fixed: start / stop button
* fixed: merge fails if output file exists
Detritus Software
Old 8th November 2010, 02:07   #486  |  Link
Sirber
retired developer
Sirber's Avatar
from time to time ffmpeg "hang" at 100% CPU merging files and stop responding :S
Detritus Software
Old 8th November 2010, 02:50   #487  |  Link
Alex_080
User of X264
Today i download your new dev version but Avira antivirus detect it as TR/Dropper.Gen
I visit and search some AVS forum and i found that for anime encoding psy_rd= 0.6 and aq= aq=1:0.60 are suitable values.
Old 8th November 2010, 02:53   #488  |  Link
Sirber
retired developer
Sirber's Avatar
a virus in which file? MSSE finds nothing here.
Detritus Software
Old 8th November 2010, 03:34   #489  |  Link
Alex_080
User of X264
Avira Antivirus detects it as Malware.
Old 8th November 2010, 03:37   #490  |  Link
Sirber
retired developer
Sirber's Avatar
... false positive. I only added the ffmpeg presets to the installer...
Detritus Software
Old 8th November 2010, 05:12   #491  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
avira is well known to detect TONS of false positives.
however, false positives apart, is one of the "best" antiviruses (even the free version).
Old 8th November 2010, 11:54   #492  |  Link
flebber
Practising Schemer
Added an MKV file and hit start. Got this error though.
C:\Program Files\Bencos\ffmpeg.exe -an -y -threads 8 -i "C:\Rip\Source\FAWLTY_TOWERS_PROP2_DISC2\title05.mkv" -vb 268k -vcodec libx264 -passlogfile "C:\DOCUME~1\Family\LOCALS~1\Temp/bencos/video.mp4" -pass 1 -fpre "C:\Program Files\Bencos\presets/libx264-slower_firstpass.ffpreset"  "C:\DOCUME~1\Family\LOCALS~1\Temp/bencos/video.mp4"
FFmpeg version SVN-r25680, Copyright (c) 2000-2010 the FFmpeg developers
  built on Nov  6 2010 04:07:01 with gcc 4.4.2
  configuration: --enable-gpl --enable-version3 --enable-libgsm --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --enable-libschroedinger --enable-libopencore_amrwb --enable-libopencore_amrnb --enable-libvpx --disable-decoder=libvpx --arch=x86 --enable-runtime-cpudetect --enable-libxvid --enable-libx264 --extra-libs='-lx264 -lpthread' --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --target-os=mingw32 --enable-avisynth --cross-prefix=i686-mingw32- --cc='ccache i686-mingw32-gcc' --enable-memalign-hack
  libavutil     50.32. 6 / 50.32. 6
  libavcore      0.12. 0 /  0.12. 0
  libavcodec    52.94. 3 / 52.94. 3
  libavformat   52.84. 0 / 52.84. 0
  libavdevice   52. 2. 2 / 52. 2. 2
  libavfilter    1.56. 0 /  1.56. 0
  libswscale     0.12. 0 /  0.12. 0
Unable to find a suitable output format for 'Files\Bencos\ffmpeg.exe'
flebber is offline   Reply With Quote
Old 8th November 2010, 13:08   #493  |  Link
Sirber
retired developer
Sirber's Avatar
I have no clue.. what OS are you on? Did the old bencos work?
Detritus Software
Old 8th November 2010, 13:25   #494  |  Link
flebber
Practising Schemer
Windows XP sp 3. yeah the old bencos worked.
Old 8th November 2010, 13:25   #495  |  Link
Sirber
retired developer
Sirber's Avatar
new release: download changelog
Detritus Software
Old 8th November 2010, 13:27   #496  |  Link
Sirber
retired developer
Sirber's Avatar
just to be sure, would it work if you install it to "C:\bencos"?
mine is at "C:\Users\sirber\Documents\My Dropbox\prog\bencos\out" and works (on w7)
Detritus Software
Old 8th November 2010, 13:33   #497  |  Link
flebber
Practising Schemer
Just installed latest dev release to C:\Bencos and it is now working
Old 8th November 2010, 13:34   #498  |  Link
Sirber
retired developer
Sirber's Avatar
I'll try to encapsulate the ffmpeg.exe path in " " and give you a special build tonight to test.
Detritus Software
Old 8th November 2010, 15:54   #499  |  Link
Alex_080
User of X264
new dev version working
one request Sirber..can u make a profile for anime encoding. I know given profiles are good but i need one special for anime.
I need slow one like these values
ref=8, subme=8, deblock=1:1:1, fast_pskip=0, bframes=3, b_pyramid=2, b_adapt=2, aq=2:0.50, psy_rd=0.60:0.00, rc_lookahead=50
Old 8th November 2010, 16:08   #500  |  Link
Sirber
retired developer
Sirber's Avatar
installed in the default folder?
like I said earlier, I'll add the possibility to have your own custom ffpreset file, so you'll be able to encode the way you like.
Detritus Software
aac, bencos, gui, webm, x264
