31st July 2016, 11:58 | #38981 | Link | |
The overall detail is still there there's actually little change to most of the image except for the lines, I don't understand the reason why people want to thin them so much, it ruin's the appearance of the characters. Sometimes I found even thin edges at 1.0 went a bit overboard so I stopped using it and just rely on a Awarpsharpen, and a touch of line darkening through Avisynth along with some sharpening through madVR depending on the source. I can make IMO 480 anime look similar to 720 content. It's all about having a firm yet gentle hand, it's easy to over do it. Last edited by ryrynz; 31st July 2016 at 12:03. |
31st July 2016, 12:46 | #38982 | Link | |
Visual Novel Dev.
Some algorithms are less needed in some anime that were natively produced in FHD, so I'm playing around with my settings a lot, but that image represents exactly why I love edge thinning. It;s mostly about getting rid of blurry and too thick edges that make things look fuzzy. Not that much about thinning really, as much as about making edges look tangible, opposed to the gaussian blurred filtered look they have sometimes. Well, I agree that sometimes it might be overkill and the image might degrade, so I think I might have to also step down a bit on the details. I also think that for my images examples I'm using upscaling refinement -> edge thinning 8.0 while for image enhancements I'm stepping it down a lot, as it does break eyes of anime characters. For real media content, I think that the sweet spot is (for me?) around 2.8 for edge thinning on image enhancements, whilst I'm still testing for upscaling refinement.
Visual Novels! https://www.facebook.com/seventh.heart.studios/ https://audiophile-heaven.blogspot.com/ https://www.youtube.com/watch?v=27VWU3ydRY8 |
31st July 2016, 12:47 | #38983 | Link | |
Visual Novel Dev.
I don't think that details are missing. The backgrounds look less blurry really, even closer to a clear image
31st July 2016, 15:03 | #38984 | Link | |
i use 60Hz at 1080P run the test for yourself and see what you come up with. it runs at 60fps http://privat.bahnhof.se/wb192876/FP...Resolution.mp4 but madvr and its smooth motion must be doing something good because motion on 24p content is way better (more fluid) than on the build in windows media player which this test runs smooth on. so i think this motion test doesnt say it all about motion performance. not for 24p content anyway. but just for the papers Last edited by Patrik G; 31st July 2016 at 15:07. |
31st July 2016, 16:45 | #38985 | Link |
this test file is kind of broken.
it is interlanced and madVr isn't deinterlancing it because it is saying that is has 60 FPS before deinterlancing. when lavfilter is deinterlancing than madVr things this file is 120 hz. |
31st July 2016, 18:31 | #38988 | Link |
Doesn't that function actually get the video before madVR has even done scaling? I think it grabs the frame after decoding but before madVR.
madVR options explained |
31st July 2016, 18:36 | #38989 | Link |
you still need to do a YCbCr->RGB conversation and madVR has to do that.
i have no clue if the selected chroma scaler is used for that or not. if i remember correctly it is dithering even with disabled dithering(don't do this). |
31st July 2016, 21:36 | #38990 | Link |
Visual Novel Dev.
But the enhancements appear when you press print screen, if you want to notice differences, as far as I know.
31st July 2016, 23:10 | #38992 | Link | |
@madshi: speaking of cropping black bars, could we get file name tags for that, please? Your last reply to leeperry on the subject didn't say whether you would implement it or not. Last edited by ibius; 31st July 2016 at 23:20. |
1st August 2016, 03:11 | #38993 | Link | |
Sent from my Nexus 5 using Tapatalk |
1st August 2016, 04:23 | #38994 | Link |
@madshi
I have a mk3d file with the following parameters: Code:
MultiView_Count : 2 MultiView_Layout : Side by Side (left eye first)
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
1st August 2016, 04:26 | #38995 | Link |
madVR will only accept frame-packed 3D. So, no, it can't be converted.
1st August 2016, 05:10 | #38996 | Link |
SBS or TAB are just 2D, so of course madVR can accept them. It can output row interleaved too. However, I don't know if you can tell madVR that a 2D input video is a certain type of 3D and have it handle it accordingly.
1st August 2016, 09:30 | #38997 | Link |
that's what warner is saying.
in it's current state madVR only detects frame packed 3D as 3D and it can only convert these. more 3D features where planned AFAIK like the feature Volt is talking about reading some flags in mkv and convert the input to the selected output. |
1st August 2016, 15:04 | #38998 | Link |
The after image linked was too heavy a hand. If you compare the red and yellow bows they wear, especially the one in the center, the yellow portions have actually shrunk and are now smaller than they were before by several mm.
1st August 2016, 15:39 | #38999 | Link | ||
It doesn't. All that it knows is the HDR peak brightness (of the display), as set during 3D LUT creation, then applies the BT.2390 rolloff + saturation adjustment, then maps into the display colorspace (with imo great results btw, my implementation has come some way in the past three weeks and will be available in the next version of DisplayCAL). Of course, a 3D LUT cannot react to dynamic metadata, which could be seen as a drawback. So far, I don't think it matters much, though.
1st August 2016, 16:41 | #39000 | Link |
For some reason I keep going back to Jinc for all my scaling needs. It seems to look more natural and has almost no artifacts unlike the other scalers.
NNEDI3 128 does look quite good. 256 looks a tiny bit better, but my 1080 GTX tends to get hot with that setting and the render times are at about 39 ms, which is too close to the frame time of 24p content. Should I lower the setting if the max sometimes hits 45 ms, but the average is around 30 ms? I'd ideally want the max under the 41.7 ms of 24p content? |
