22nd July 2017, 19:32 | #44401 | Link | |
Still need to test, it reach to 34-38 ms . By the way, we can't use Exclusive D3D11 anymore with HDR ? it disable HDR mode when entering Full Exclusive mode. so no need for it or it's not supported ? Windowed mode is enough for HDR mode at the moment ? |
22nd July 2017, 20:35 | #44402 | Link |
driver problem: https://forum.doom9.org/showpost.php...ostcount=44259
no one ever said you need FSE mode. |
22nd July 2017, 20:39 | #44403 | Link | |
Do you know if I still need to use Artifact removal with 1080p content with 4K TV ? Also I should cancel Reduce dark halos around bright edges , too if I want Anime right ? in the end of what Madshi says , he means if I have Nvidia and using driver 384.72 then my TV changes to HDR perfect ? because my TV changes to HDR with a small notification, but does it mean it's perfect and no conversion is happening without Enabling HDR from the windows 10 ? Last edited by x7007; 22nd July 2017 at 20:44. |
22nd July 2017, 21:00 | #44404 | Link | ||||
your output resolution obviously has nothing todo with it. you should only use setting you can see. Quote:
without FSE you are not getting 10 bit output. |
22nd July 2017, 21:13 | #44405 | Link |
Is it typical for the "present queue" to drop when the progress bar appears in full screen? My "present queue" drops from 7-8/8 to 1-2/2 when the progress bar appears and this leads to dropped frames and possibly the culprit for audio sync issues.
22nd July 2017, 22:28 | #44407 | Link |
The reason for this is because otherwise the bar would have a delay of the number of frame in the present queue, which at 8-frames is pretty unpleasant.
madVR options explained |
22nd July 2017, 23:03 | #44409 | Link |
You can get HDR and 10bit output without FSE: just use the win10 HDR switch and play the video in windowed fullscreen (cf. last version release notes). Given how little HDR content is out there, switching HDR manually from time to time to get the best output possible isn't that big of a deal.
23rd July 2017, 06:09 | #44410 | Link |
I have a problem have set HDR windowed mode because then it won't be 10 bit and only 8 bit. It says it's NV12 8 bit.
I needed to enable HDR in windows because then it won't be 10 bit and only D3D11 8 bit. I have a notification on my TV HDR mode when I run the HDR movie. could you tell me what is wrong and what a settings I could change to fix it ? http://i.imgur.com/0WCPAgy.jpg Last edited by x7007; 23rd July 2017 at 06:16. |
23rd July 2017, 10:32 | #44411 | Link |
Im curious, my PC seems to play all movies fine.
Except when I try and play a 10bit HDR movie. Kodi seem's to be crashing.... What could be the cause of this? Is this possibly the HEVC decoding I do with the GPU? (should I unclick that?) (I am using Full Screen Exclusive on the older non-buggy NVIDIA Drivers) |
23rd July 2017, 10:45 | #44412 | Link |
Madshi, chances of SDR to HDR upconversion?
The whitepaper is MIA, wonder if this can be done in real time, likely not yet.. Maybe some years off. Last edited by ryrynz; 23rd July 2017 at 10:49. |
23rd July 2017, 12:54 | #44413 | Link | |
23rd July 2017, 13:06 | #44414 | Link | |
GTX 1080 Nvidia Driver Version 378.92 Windows 10 Enterprise Creators Editions Using DXVA2 Copy Back (Using Ryzen 5 results in 90-100% CPU-load and not filled qeue's on for example "The World in HDR in 4k demo" so that's not an option either, even if it would have been, it still crashes) After some testing it crashes on both windowed and on FSE, so atleast that's not the culprit. Last edited by Sarlaith; 23rd July 2017 at 13:16. |
23rd July 2017, 13:16 | #44416 | Link | |
http://demo-uhd3d.com/fiche.php?cat=uhd&id=159 Ps. Im using DSPlayer, not MPC-HC. Not sure if that's the culprit? Last edited by Sarlaith; 23rd July 2017 at 13:53. |
23rd July 2017, 14:09 | #44417 | Link | |
How to watch this video in potplayer + lav filters + MAdvr in 10 bit ? I'm only getting 8 bit. EDIT : need to enable windows 10 creators HDR ON. D3D11 windowed 10bit but it still says NV12 8 bit, does it need to be 10bit ? This video is working fine for me from start to end , CPU 40% I7 3770K and GPU max 1080 , Last edited by x7007; 23rd July 2017 at 14:16. |
23rd July 2017, 14:14 | #44418 | Link |
Recently i removed k-lite codec pack and changed to individual installation for MPC-HC, MadVR and codecs. Now MadVR is not displaying UTvideo files anymore. MPC-HC screen stay black with no playback when start UTvideo file. For other codecs(MagicYUV,H264,HEVC) it plays fine. Changing renderer from madVR to EVR-CP UTvideo plays correctly.
Im not 100% secure but i think i played UTvideo files with MadVR over k-lite installation and played fine, so i dont know what become wrong. Any advise? |
23rd July 2017, 14:28 | #44419 | Link | |
23rd July 2017, 14:58 | #44420 | Link |
_
Slow ? Have you proofs it is slower than another player ?
Old ? Are you the kind of user who needs his monthly updates whereas he doesn't even need a new feature ? PotPlayer stole code from other projects and so is not welcomed on this forum. MPDN x64 is an alternative to madVR and recommending it in this thread is not welcomed too. I don't want to debate this off-topic anymore. I just wanted to tell you I saw what you did, and it was ugly. |
