Old 30th December 2018, 20:57   #54041  |  Link
el Filou
el Filou's Avatar
The very purpose of madVR is to bypass most of the graphics card driver's video picture processing to guarantee a consistent picture quality.
In your described scenario you would have exactly the same quality.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 30th December 2018, 21:01   #54042  |  Link
brazen1
Is this a trick question? There would be zero difference imo.
Upgrading a video card provides more capability. If you don't utilize the capability, nothing has changed. In other words, I doubt replacing a GT630 with a GT740 and playing the same non-problematic title is going to look any different than it did provided all you did is swap the cards.
W10 1903 9604GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5
65JS8500 UHD HDR 3D
Old 30th December 2018, 21:41   #54043  |  Link
SirSwede
Cheers lads!
No, not a trick question!
Yeah, I have a DELL Dimension 9150 (with a GT630) as a HTPC, since all the material I watch is just 720p anyway. The picture is great, btw!
I also have a DELL Dimension E521 (with a GT740) in reserve.
I wonder what would happen, to the picture, if I needed to change out the graphics card and take the GT740 and put in the Dimension 9150?
Or the other way around (what would happen to the picture) if I needed to take the GT630 and put in the Dimension E521?
Due to their age, I mean - and using the same TV.
What you guys are basically saying is, that - should either of these scenarios occur, I would still have the same picture with the same TV?
SirSwede is offline   Reply With Quote
Old 30th December 2018, 21:47   #54044  |  Link
Asmodian
Yep, everything should look exactly the same.
madVR options explained
Old 31st December 2018, 01:53   #54045  |  Link
XTrojan
What's the difference between OS HDR (Windows 10 HDR enabled playback) and NV HDR (MadVR auto switching with Windows 10 HDR turned off)?
I red some about OS HDR not sending metadata back in early 2018s, but some people claim it does.
Are they basically both the same but one is rendered by Windows and one by Nvidia?
XTrojan is offline   Reply With Quote
Old 31st December 2018, 02:15   #54046  |  Link
actarusfleed
copyback gives you the option to use some feature you can only use using a CPU like blackbar detection IVTC this is currently not possible with a native decoder.
I imagine that the "2.35:1 35mm film" sign tells me that black bar detection is actived ...
The strange thing is that I still have black bar detection also if I change "hardware decoder to use" to none or D3D11.
Is it not only a feature of DXVA2 copyback?
Originally Posted by chros View Post
On the first pic in OSD: you play 60.00Hz content on 59.94Hz! That's why you get drops
What exact values do you have in madVR for display resolutions switching?
This is a new photo taken now with the file not paused, during playback.
In the settings for devices into Madvr I've setted: 2160p23, 2160p24, 2160p50, 2160p60.
Chors , trust me, the frame lost are massive. This is not a refresh problem ... Look at the decoder queue ... it's to low.
Huhn is right , my GTX970 has a poor decoder for UHD files!
I've also problems with 24fps UHD HDR files taken from UHD discs.
If I play the file from the beginning the queue remains full and I've no drop frames with a avg rendering time near 32ms.
If I move ahead using the line-time of the film and jump to another point It starts to drop frames massively.
If I pause the playback the rendering queue fills up again and if I play it again I have no dropped frames for some minutes .... after that maybe the queue turns down and the drop frames restarts.
In a first moment I was thinking that my USB3 HDD was to slow to send MKV UHD files to HTPC. So I've copied a file to the main SSD hdd.
The problem persists so I'm thinking that Huhm is right my GTX970 has poor decoder also for UHD at 24fps.
P.s. Focus assist is disabled.
If you have any suggestion to reduce dropped frames ...
Thank you so much.
actarusfleed is offline   Reply With Quote
Old 31st December 2018, 06:00   #54047  |  Link
grendelrt
Are there any disadvantages of using the internal subtitle renderer inside MPC_HC for Madvr instead of using xysubfilter?
grendelrt is offline   Reply With Quote
Old 31st December 2018, 12:03   #54048  |  Link
albur
Post of a picture of the OSD (Ctrl + J) and post it here. What are your rendering times and is the GPU switching correctly to 1080p24?
https://imgur.com/a/gxw3ZBA
Yes it switch to 1080p24 but in full screen exclusive mode it drops a lot of frames with 3D MVC mkvs, without exclusive mode it works fine
albur is offline   Reply With Quote
Old 31st December 2018, 16:06   #54049  |  Link
Warner306
They are the same, but one is automatic and the other isn't.
Old 31st December 2018, 16:10   #54050  |  Link
Warner306
The OSD says the GPU can't keep up, so I don't know what the problem would be. Try reducing your setting for chroma upscaling and see if the rendering times come down. There must be some sort of bottleneck causing those rendering times. fullscreen exclusive mode isn't reliable on Windows 10. That is most likely the issue.
Old 31st December 2018, 16:24   #54051  |  Link
Damien147
The only benefit for 8 bit panels and fullscreen exclusive mode is the removal of unwanted pop up messages from win.Am I right?
Damien147 is offline   Reply With Quote
Old 31st December 2018, 17:26   #54052  |  Link
clsid
You can also use Quiet Hours / Focus Assist to hide notifications.
Old 31st December 2018, 17:40   #54053  |  Link
Damien147
Indeed.I am just trying to find out if fullscreen exclusive mode has any + or - for me.Win 10 and 8 bit panel here.Is it suggested to stay with fullscreen windowed in my occasion?
Old 31st December 2018, 17:50   #54054  |  Link
brazen1
I don't think auto engage vs manual is the only difference when using NV HDR vs OS HDR.
OS HDR does not apply at display level through any player or software. NV HDR does. This means the display is not going to enter an HDR mode that auto adjusts settings like contrast and backlight because it doesn't passthrough anything to the display other than the desktop faux HDR.
65JS8500 UHD HDR 3D
Old 31st December 2018, 17:52   #54055  |  Link
jkauff
I seem to remember madshi saying that fullscreen windowed is the way to go with Win 10.
Old 31st December 2018, 17:56   #54056  |  Link
brazen1
Use FSE for frame packed MVC 3D.
Use FSE for UHD HDR.
Use FSW for everything else.
65JS8500 UHD HDR 3D
Old 31st December 2018, 18:05   #54057  |  Link
Damien147
I see.Fullscreen windowed for me then.Thanks guys.
Old 31st December 2018, 18:25   #54058  |  Link
Asmodian
Focus Assist does not play well with madVR. Oddly it causes studder if any aspect of it is enabled.
Old 1st January 2019, 02:38   #54059  |  Link
XTrojan
Some people back in the thread said that OS HDR doesnt't send metadata.
Then there's also NV HDR sending 12bit image while OS HDR maxes out at 10?
Old 1st January 2019, 02:49   #54060  |  Link
madVR is limited to 10 bit output no matter what.
the GPU driver is limited to 12 bit for the usual refreshrates/resolutions.
the HDR NV API or the HDR OS API have nothing todo with this.
