Old 2nd July 2017, 19:56   #44281  |  Link
ABDO
[QUOTE=madshi;1810884]
but to my eyes NGU Sharp looks significantly better. NGU is slightly softer, but is much cleaner and consequently looks more natural to my eyes.
thanks madshi ,tottly agree with you، I'm sure that ngu Unbeatable and do unbelievable result even when Compare it to waifu2x ، Honestly ido not even know how did you do that amazing ruselt with this speed in the same time، the only diffrent betwen waifu2x and ngu is the denoise، waifu2x in 2d Anime can tottly clean low bitrate compresing artifacts ، but much much much slower than ngu.
please take looke at some dirty comparison images here
http://www.mediafire.com/file/zkq3jw...creenshots.rar
but in normal life content ، 3d Anime and 2d clean Anime ngu do great job at all . it easily beat Nnedi3+SuperRes with less speed.and clean، sharp as waifu2x even with less ringing and 100x faster
ABDO is offline   Reply With Quote
Old 2nd July 2017, 23:14   #44282  |  Link
TheShadowRunner
TheShadowRunner's Avatar
A quick word to tell you I'm still looking forward to the test-build madshi (with "* last video frame is now remembered for 2 seconds when stopping graph" disabled or optional, to test if it's the change responsible for the DVD playback crash on XP).
(no hurry, just worried you'll forget ^^;)
XP SP3 / Geforce 8500 / Zoom Player
TheShadowRunner is offline   Reply With Quote
Old 2nd July 2017, 23:44   #44283  |  Link
krmit
madVR - crash report.zip
krmit is offline   Reply With Quote
Old 2nd July 2017, 23:55   #44284  |  Link
galneon
Is there still a possibility that nearest neighbor image upscaling will return one day? I know it may seem niche, but it's really nice for vintage gameplay footage. Sad to see something go away due to UI design decisions.
galneon is offline   Reply With Quote
Old 3rd July 2017, 01:22   #44285  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Hey folks! Would appreciate some thoughts on my issues with HDR output to an LG OLED using MadVR
https://forum.doom9.org/showthread.p...07#post1811007
[edit] Never mind, this is the same FSE problems with latest nVidia drivers that was discussed a few pages back[/edit]
Old 3rd July 2017, 03:24   #44286  |  Link
oddball
So I am still in the situation whereby I can only get HDR if FSE is disabled and if I hover over certain system tray icons. It times out after a few seconds though and goes back to washed out colors. I can only get it to stick if I actually click on the MadVR systray icon and don't move or click away for several seconds. After that I can click anywhere and it stays in HDR mode. EXCEPT if I click on the MPC video playback window.
AMD RX 480 with latest drivers.
Is this an AMD driver issue? Why does it work OK with Win10's Film & TV player?
EDIT: Sorry just noticed the post(s) above already mentioning it.
oddball is offline   Reply With Quote
Old 3rd July 2017, 04:08   #44287  |  Link
johnnylaiyee
johnnylaiyee's Avatar
Tested the new v0.91.11 build last night
Now my TV can automatically switch to HDR mode in MPC-BE x64 even in Windowed mode
The seeking time is significantly faster in HDR mode compare to the last build
Great update! Madshi!
johnnylaiyee is offline   Reply With Quote
Old 3rd July 2017, 04:17   #44288  |  Link
valdeski
Was it really removed completely? There is a keyboard shortcut for it.
valdeski is offline   Reply With Quote
Old 3rd July 2017, 11:53   #44289  |  Link
ogakul
I get dropping and repeating frames if I use custom display modes like 2160p23. If I disable custom display modes and run it in 2160p60 it runs without drops. Input material are 1080p h264 mkv's
Im using NGU AA high for upscaling the rest is set to "let madvr decide". Chrome Upscaling is set to NNEDI3 32 neurons.
Intel 4790K, GTX 980TI OC. Playing on a 2160p 10-bit TV
Any suggestions?
ogakul is offline   Reply With Quote
Old 3rd July 2017, 18:02   #44290  |  Link
Asmodian
2160p60 with smooth motion enabled if there would be judder without it is what I would use in your case.
madVR options explained
Old 3rd July 2017, 20:31   #44291  |  Link
ddjmagic
madVR v0.91.11 now switches automatically to HDR for me with "HDR and Advanced Color" off in Windows. Thanks for the update/workaround.
ddjmagic is offline   Reply With Quote
Old 3rd July 2017, 22:24   #44292  |  Link
jmonier
For me under Win 8.1 64 things are a little different. It switches into HDR fine, INCLUDING under Full Screen Exclusive with the latest (384) Nvidia drivers.
However, it will NEVER switch back to SDR. My LG OLED will switch to SDR when I switch inputs but it will go back to HDR when I switch back to the PC. The only way I can get back to SDR with the PC is to re-boot.
By any chance, is something like 3D Vision required? Currently, I do not have it installed.
jmonier is offline   Reply With Quote
Old 3rd July 2017, 22:30   #44293  |  Link
Mercury_22
Haven't tried this in a while (since before Creators Update ) so ... is 3D not working with Creators Update ?
Cause when I'm trying to play a BD 3D my TV "flickers" a few times (like it's trying to enter in 3D mode ... ) and then windows is crashing
HD7790 + Crimson 17.6.2 beta + LAVFilters-0.70.1 + madVR v0.91.11 + MPC-BE 1.5.1.2685
Windows 10 1809 x64, HD7790 Adrenalin 2019 Edition 19.1.2, HDMI Full RGB 4:4:4
Mercury_22 is offline   Reply With Quote
Old 3rd July 2017, 22:48   #44294  |  Link
nevcairiel
Read madshis recent status post. AMD is not a good choice for HDR at this time.
nevcairiel is online now   Reply With Quote
Old 4th July 2017, 02:00   #44295  |  Link
foozoor
Reclock works by resampling audio, so that's not something madVR can do. However, there will soon be a new feature that may make Reclock like algorithms not needed, anymore. We'll have to see if it works as intended, but that's my hope.
Do you have any news on this matter?
foozoor is offline   Reply With Quote
Old 4th July 2017, 02:19   #44296  |  Link
nevcairiel
When he does, you'll find it in this thread. Until then, patience.
Old 4th July 2017, 19:22   #44297  |  Link
kalston
You can enable it with keyboard shortcuts. There is one for Chroma, one for "Image upscaling" and one for "Image downscaling". They still work fine for me.
kalston is offline   Reply With Quote
Old 4th July 2017, 21:20   #44298  |  Link
galneon
Thank you both!
Old 5th July 2017, 17:41   #44299  |  Link
oldpainlesskodi
@ Madshi - many thanks for v0.91.11....awesome stuff.
K
oldpainlesskodi is offline   Reply With Quote
Old 6th July 2017, 10:58   #44300  |  Link
vazel
Originally Posted by mrcorbo View Post
When viewing an HDR video madVR default settings "Use DXVA chroma upscaling.." under "trade quality for performance" cause incorrect colors when in fullscreen.
I'm having this problem too when viewing x265 10-bit encoded anime. Here are images showing what it looks like in windowed and fullscreen.
vazel is offline   Reply With Quote
