Old 22nd February 2019, 18:46   #16721  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Originally Posted by byteshare View Post
I was playing around with some filters for "fun"....boring life I suppose...
Anyways, I noticed that not all filters seem to work with the same syntax and I was wondering if anyone knew or could better describe AviSynth syntax/format in RipBot for me?
Why do some filters seem to work with video=Filter and others video=video.filter? Is it just because some are "built-in" to RipBot?
for example: video=QTGMC(Settings) works but FK3DB needs video=video.fk3db(settings)
Are the filters taken in order of the jobsxxx.avs file (top to bottom)?
for example: Deinterlace would go before Decimate? I don't think this is happening since Crop is 3rd from VideoSource, but custom would go last?
If I string them in a row with a "." they are done one at a time from left to right, yes?
for example: video=video.filter01(settings).filter02(settings) > filtero1 is processed, then filter02
or if I did them:
video=video.filter02(settings)
Would it be the same as stringing them together with "."?
Syntax is like this
video=Filter(video,settings)
you can create chain of filter like this
video=Filter(video,settings).FilterB(settings).FilterC(settings)
Just remember that first filter will need clip name!
Old 22nd February 2019, 18:54   #16722  |  Link
Atak_Snajpera
Originally Posted by egres View Post
I have got 2 other jobs which worked yesterday and not working today. Did not change anything to my setup, except updating core !!
Smells like your antivirus/firewall is just doing some weird stuff in background. In last update I just fixed few deadlocks (when user clicked abort client randomly hung) in code and I didn't mess with other parts of the code. I'm still investigating that auto-connecting bug...
Old 22nd February 2019, 19:02   #16723  |  Link
egres
Hum, just checked firewall rules... green light on encoder and Ripbot264. Even the local encoder just sits there with the command line.... nothing happens...
egres is offline   Reply With Quote
Old 22nd February 2019, 19:03   #16724  |  Link
Atak_Snajpera
Check if script can be opened in MPC-HC.
Old 22nd February 2019, 19:04   #16725  |  Link
egres
I will reinstall the original RipBot264v1.24.0 and try that
Old 22nd February 2019, 19:05   #16726  |  Link
byteshare
ByteShare
byteshare's Avatar
Syntax is like this
Oh! I think I wasn't seeing the video in the settings:
video=Filter(video,settings) on the default ones...
So video=video.filter is working because I'm just saying to AviSynth do:
video then the filter and the filter is using the video from the first "command", which is just video.
Are the custom scripts getting the "video" from the other parts of the jobxx.avs after their AVISynth scripts (assuming there are some) or should I be putting everything like QTGMC into the custom script, except for crop?
I had in the past only been using a custom script.
Old 22nd February 2019, 19:06   #16727  |  Link
egres
I am rather new at using your wonderful software... Could you elaborate
Old 22nd February 2019, 19:16   #16728  |  Link
egres
Just did a fresh reinstall of RipBot264v1.24.0.7z making sure update flag was set to 0. Works like a charm
Old 22nd February 2019, 19:17   #16729  |  Link
byteshare
ByteShare
byteshare's Avatar
Click on the Job > Edit > AviSynth > Preview Script
Old 22nd February 2019, 19:18   #16730  |  Link
egres
I left encoder v1.14.2.0 on all the remote PC's, and it works
Old 22nd February 2019, 19:20   #16731  |  Link
egres
I will try that when job concludes. Thanks
Old 22nd February 2019, 19:26   #16732  |  Link
Atak_Snajpera
It does not matter where you put your code.
Old 22nd February 2019, 19:27   #16733  |  Link
egres
Just killed the job.... went in Click on the Job > Edit > AviSynth > Preview Script
I never had a chance to use this before, but that dont look ok !!
Old 22nd February 2019, 19:29   #16734  |  Link
Atak_Snajpera
Basically What you see here is what you will get in encoded file.
Old 22nd February 2019, 19:31   #16735  |  Link
egres
As I said, never used this > Edit > AviSynth > Preview Script and all my jobs worked fine. The mkv was just fine
Old 22nd February 2019, 19:34   #16736  |  Link
egres
This is my Video script:
#AudioSource
LoadPlugin("C:\Users\Serveur\Desktop\Video\RipBot264\tools\AviSynth plugins\NicAudio\NicAudio.dll")
audio=NicDTSSource("D:\Temp\RipBot264temp\job32\audio_1_English.core.dts")
audio=ResampleAudio(audio,48000)
#DownMix
#Delay
audio=DelayAudio(audio,0)
#Tempo
#Normalize
#AudioDub
AudioDub(video,audio)
Old 22nd February 2019, 19:36   #16737  |  Link
egres
I meant audio... this is my video script...
#MT
#VideoSource
LoadPlugin("C:\Users\Serveur\Desktop\Video\RipBot264\Tools\AviSynth plugins\ffms\x64\ffms2.dll")
video=FFVideoSource("D:\Temp\RipBot264temp\job32\video.mkv",cachefile = "D:\Temp\RipBot264temp\job32\video.mkv.ffindex")
#Deinterlace
#Decimate
#Crop
#Resize
#Tonemap
#Levels
#Colours
#Denoise
#Custom
#Prefetch
#After_Prefetch_Denoise
#After_Prefetch_Custom
#Subtitles
#AudioSource
Import("D:\Temp\RipBot264temp\job32\job32_a1.avs")
#Triming
#AVSameLength
#ColorSpace
#Return
Old 22nd February 2019, 19:41   #16738  |  Link
Atak_Snajpera
Maybe reinstall GPU driver.
Old 22nd February 2019, 19:44   #16739  |  Link
egres
Do I need to set x264 OpenCl acceleration to my gpu ?
Old 22nd February 2019, 19:46   #16740  |  Link
Atak_Snajpera
no...
