Old 28th March 2017, 12:48   #14761  |  Link
skylinekiller
Ripbot and Eac3 error
Cut out few minute sample and send me prepared .mkv. I will check what is going there.
Here is a short clip that still gives it the error. Audio is EAC3
http://www.mediafire.com/file/go5c67..._with_eac3.mkv
skylinekiller is offline   Reply With Quote
Old 29th March 2017, 17:59   #14762  |  Link
byteshare
ByteShare
byteshare's Avatar
Not related to RipBot directly, but Avisynth+ r2455-MT: https://github.com/pinterf/AviSynthP...s/tag/r2455-MT
faster ordered dither to 8bit: SSE2 (10x speed)
and a few other speed improvements if you're still on an old version.
Old 29th March 2017, 22:26   #14763  |  Link
skylinekiller
Thank you, I thought this app updated all the components automatically... On a different note, everytime I do a batch, job #2 always ends up with an error. After the job is complete, I have to redo only the job # 2 and it completes successfully. Why does this happen only in batch mode and only on Job #2?
Old 29th March 2017, 22:39   #14764  |  Link
skylinekiller
I downloaded that file, where do I extract the documents to?
Old 30th March 2017, 02:26   #14765  |  Link
burt123
burt123's Avatar
After you have unpacked the .7z file, read the "readme.txt", it will tell you exactly where to put the files
burt123 is offline   Reply With Quote
Old 30th March 2017, 04:03   #14766  |  Link
skylinekiller
thank you for pointing out my shortfalls...definitely should have looked at the readme file. . Well what can I say, it was 0430...
Old 30th March 2017, 18:35   #14767  |  Link
byteshare
ByteShare
byteshare's Avatar
Happens to all of us, LOL
AviSynth doesn't get updated by RipBot.
I don't have this issue with batch mode. Do you get any error messages or anything to be more specific?
Old 3rd April 2017, 01:28   #14768  |  Link
archaeo
scribe
archaeo's Avatar
Question regarding distributed encoding: I have both a desktop and a laptop connected through my router. Can I use distributed encoding between the two? The problem appears to be that the IP address is the same. thanks!
archaeo is offline   Reply With Quote
Old 3rd April 2017, 02:47   #14769  |  Link
burt123
burt123's Avatar
Should be able to, but if the laptop isn't reasonably powerful, there's not much point.
Are you using wireless or wired connection ??
Simply change the IP address on one of them.
Old 3rd April 2017, 03:37   #14770  |  Link
archaeo
scribe
archaeo's Avatar
burt,
Thanks. Using wireless, and the laptop is much more powerful (i7) than my core2duo. I didn't realize changing the IP was so simple. I'll give that a go.
Old 3rd April 2017, 18:59   #14771  |  Link
archaeo
scribe
archaeo's Avatar
working! Thanks Burt.
EDIT: additional server was encoding, everything running smoothly, but at the end of process, the output folder was empty!
Cannot find the finished file anywhere. Here's the log file:
C:\>"C:\DVD TOOLS\m2ts utilities\ripbot\EncodingClient.exe" "C:\Temp\RipBot264temp\job1\job1_EncodingClient.meta"
C:\>"C:\DVD TOOLS\m2ts utilities\ripbot\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\eolus\Desktop\rip\Moonlight 2016 1080p BluRay.mkv" --compression 0:none --title "Moonlight 2016 1080p BluRay" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.264" --compression 0:none --language 0:eng "C:\Temp\RipBot264temp\job1\Encoded_Audio_1.ac3"
mkvmerge v9.8.0 ('Kuglblids') 32bit
Error: The file 'C:\Temp\RipBot264temp\video.264' could not be opened for reading: open file error.
Elapsed Time: 01h:02m:42s
Old 3rd April 2017, 23:29   #14772  |  Link
byteshare
ByteShare
byteshare's Avatar
If you haven't already I'd run through the tutorial video: https://www.youtube.com/watch?v=b-BI...ature=youtu.be
If you have try entering in your "Authentication information under Settings > Distributed Encoding
Old 3rd April 2017, 23:58   #14773  |  Link
archaeo
scribe
archaeo's Avatar
byteshare,
Yes, I have referred to both the youtube video and the written distributed encoding instructions at another site. As well, there is no password authentication required with my system. And, I have run the program as administrator. The files appear to be encoding fine, but the last step in reading the video.mkv file is hanging it up. I also checked my folder sharing permissions, and the shared folder is set up to allow everyone to read/write. When I run the file without distributed encoding, the final output file is fine.
At a loss here to see why I'm getting an open file error in distributed encoding.
Old 4th April 2017, 14:49   #14774  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
go to Chunks folder and manually run CombineAllChunks.cmd and then jobx_MuxFiles.cmd
Old 4th April 2017, 17:47   #14775  |  Link
archaeo
scribe
archaeo's Avatar
That worked
On the next DE job I ran, it muxed and outputted correctly.
Many thanks Atak!
Paypal donation just made for your all your work on this program. Thanks
Old 4th April 2017, 22:51   #14776  |  Link
klopsknoedel
Does not work for me. RipBot quits conversion immediatly with these errors:
error: failed to load avisynth.dll
y4m [error]: bad sequence header magic
x264 [error]: could not open input file `-'
Edit:
Never used AviSynth+ before. Just switched from AviSynth 2.6 ST because of the quoted post by byteshare. Does someone have any suggestions on how to fix this issue? I did what the readme told me but no luck.
klopsknoedel is offline   Reply With Quote
Old 6th April 2017, 02:59   #14777  |  Link
burt123
burt123's Avatar
Edit:
I had some problems with this, and had to re install 2.6....
Old 7th April 2017, 19:38   #14778  |  Link
FuzzyNutz
v1.19.6 demuxing dts-ma with unrecognized file extension
v1.19.6 demuxes dts-HD-MA tracks to files with the extension .dtsma. These .dtsma files do not appear as selectable tracks in the audio pull-down, but they can be selected via the "..." box to the right. This creates a new file with .ffindex extension in the job(x) folder, which takes awhile.
Changing .dtsma to .dts in the job(x) folder first, is an effective workaround.
Prior to v1.19.6, dts-HD-MA tracks were demuxed to files with the extension .dts and appeared as selectable audio tracks.
I have not tested True-HD with v1.19.6.
FuzzyNutz is offline   Reply With Quote
Old 9th April 2017, 05:28   #14779  |  Link
burt123
burt123's Avatar
With more and more movies having 7.1, etc (and above) audio, what IS the best way to process them with Ripbot, without losing anything (or much) ???
Old 9th April 2017, 13:51   #14780  |  Link
Atak_Snajpera
Copy stream?
