10th November 2002, 17:01 | #21 | Link | |
Thanks for answer. Can you implement 'SelectRangeEvery' function (for fast compresibility check) too? |
12th November 2002, 09:56 | #23 | Link |
Vlad, the Buffy slayer
SelectRangeEvery was included in mpeg2dec.dll by Dividee. I think it's now removed from mpeg2dec3 (by MarcFD) so adding this filter in YV12 is juste a matter of compile.
I can do that tonight.
Vlad59 Convolution3D for avisynth 2.0X : http://www.hellninjacommando.com/con3d Convolution3D for avisynth 2.5 : http://www.hellninjacommando.com/con3d/beta |
12th November 2002, 10:31 | #24 | Link |
Retired AviSynth Dev ;)
Couldn't it simply be included in AviSynth 2.5 (or is that what you meant). The old filters no longer works anyway, so why not just add it as an internal feature?
Regards, sh0dan // VoxPod |
12th November 2002, 10:49 | #25 | Link | |
12th November 2002, 10:51 | #26 | Link | |
I am not (big) programmer, but I think, that implementation of 'SelectRangeEvery' direct into Avisynth2.5 is very easy (few lines of code). |
12th November 2002, 10:52 | #27 | Link |
Yes it should be included in avisynth 2.5 .
If you need the original code I can send it to you (adding it to field.cpp is just a matter of copy/paste) or if you don't have time I can do this for you.
12th November 2002, 10:58 | #28 | Link | |
SelectRangeEvery is very similar to SelectEvery. SelectEvery works with alone frames, SelectRangeEvery work with intervals of frames. E.g. SelectRangeEvery(280,14) Select this frames 0 to 13, 280 to 293, 560 to 573, etc. |
12th November 2002, 11:07 | #29 | Link | |
I use relative often VisualBasic or sometime Delphi only. |
12th November 2002, 11:23 | #30 | Link |
@HarryM
Sorry while posting I was answering to Sh0dan but in the meanwhile you posted two answer too. So I'll make the modification. don't worry.
12th November 2002, 12:23 | #31 | Link |
@vlad: I'm doing modifications on field.cpp (I think there is a bug in Separatefields()) today, so feel free to mail or PM me the sources.
15th November 2002, 14:30 | #33 | Link | |
15th November 2002, 15:30 | #35 | Link |
I checked CVS and this function is already added. I won't be able to compile before 5 or 6 hours.
And I don't know if it a really good idea to compile this fresh checkout (I don't know if Sh0dan is modifying something).
18th November 2002, 04:09 | #38 | Link | |
developer wannabe
Anyway, I suppose it's about time I figured out how to work with the CVS branch... |
18th November 2002, 19:52 | #39 | Link |
I just wanted to thank everyone who's made this possible. My encodes are easily -- easily 20-30% faster, just as you say. And quality doesn't look any less. In fact, theoretically, it's better, right?
19th November 2002, 14:30 | #40 | Link | |
2) It's really easy, just use the "avisynth_2_1" branch name to get access to the files.
Regards, sh0dan // VoxPod Last edited by sh0dan; 19th November 2002 at 15:04. |
avisynth, faq |
