22nd July 2009, 09:39 | #201 | Link |
Hey guys
iv been using staxrip for a year or so recently my dvb-c source has changed to 1080i from 720p when i am cutting in the file i get this error after some time http://dvdguider.org/PICS/fejl.png i can push R to rebuild and it works 2 or 3 times then stax crashes this is my source video info Video ID : 3900 (0xF3C) Menu ID : 3900 (0xF3C) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 53mn 52s Bit rate : 8 782 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16/9 Frame rate : 25.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : MBAFF Bits/(Pixel*Frame) : 0.169 Stream size : 3.30 GiB (91%) i have the errors running vista 32 bit and win7 x64 no difference anybody have a clue? |
22nd July 2009, 10:28 | #202 | Link |
This is a error generated by AviSynth and the cause might be a bug in a filter, how does your script look?
22nd July 2009, 12:56 | #203 | Link | |
avs looks like this
after cut i do crop and resice Last edited by cbsjanten; 22nd July 2009 at 13:04. |
22nd July 2009, 13:07 | #204 | Link |
Does it still happen if you disable all but the source filter?
22nd July 2009, 13:12 | #205 | Link |
i will give it a try....i am encoding now again...it dident get the filzise right i 2 pass
ill test i about 3 houers when its done i have 2 say i reallly enjoyed this apps for a long time....no probs what so ever when i have 720p source so thx for all your good work edit is there anyway to get leakkerneldeint to work whit this edition of stax? the best and fastsets deinterlacer i know |
22nd July 2009, 13:28 | #206 | Link |
It requires a bit deeper understanding of StaxRip and AviSynth, a project/template holds a filter setup and a filter setup holds filters, for the filters there are filter profiles which you can reach with a right-click on filters, for the filter setups there are filter setup profiles which you can reach in the main menu and the profiles/templates are also in the main menu. AviSynth is one of the most important applications in StaxRip like x264 and therefore is well supported in StaxRip.
22nd July 2009, 17:10 | #209 | Link |
@Bilskate
You could search if there might be a newer version for DivXMux available and try it if there is. @cbsjanten You can try if when loading the script with VirtualDub the error also occurs and post to the AVCDGDec support thread.
28th August 2009, 10:03 | #211 | Link |
Encoding for people..
Hello,
why is the choise to "add x264 profiles" removed from the 1.1.1.4.7 version? Also, Templates from previous versions aren't compatible?
We Capture.. you Watch.. Last edited by MoUCLAs; 28th August 2009 at 10:28. |
28th August 2009, 10:28 | #212 | Link |
@MoUCLAs
MeGUI support was removed because there were major changes in x264 which resulted in: hard to keep up-to-date with new fields added by MeGUI hard to keep in sync with fields changed by MeGUI hard to interoperate between different MeGUI and StaxRip versions It's hard enough to add all x264 changes and the benefit of MeGUI profiles has become questionable because x264 has now built in profiles and other new features that improve ease of use greatly and StaxRip has great support for these new features. On top of that StaxRip can now import/export profiles as well so somebody might provide a batch of profiles that were created with StaxRip instead of MeGUI, still I would rather try to do my own profiles. @all I realized it's easier to support StaxRip in a single thread, the one found in my signature, please try to post there instead of here.
2nd July 2010, 19:17 | #215 | Link |
File name: video
Extension: mpeg I want to DVBRip. I want to use the XviD codec, the file you import. The name itself is identified. Filename itself. ".avı" is written as. I want to change but the project closes. Divx Plus codec .mkv is not the problem. Problems when you import a file "avi" and not ".avı" for the writing ... Sorry for bad english ... |
2nd July 2010, 19:29 | #216 | Link |
If the source file is called video.avi the output file should automatically be changed to video_new.avi
In Windows Explorer, try renaming the source file completely to: filename.avi If the original extension wasn't .avi, replace .avi with the correct extension. Its worth a try at least. |
1st May 2017, 17:11 | #217 | Link |
h265 error
I am using the test version 1.4.3.2 and I am getting the following error for Intel h265: Error: Unknown value "h265" for "--codec" Start: 18:03:22 End: 18:03:22 Duration: 00:00:00 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoder output file is missing My Intel graphic card is activated and has quicksync. When I use the check hardware option, I get QuickSyncVideo (hw encoding) unavailable. Any idea why this occurs? My specs are these: Processor - I7-4702MQ with Intel HD Graphics 4600 and Nvidia GeForce GT 750M. |
11th June 2018, 10:19 | #218 | Link |
MTS filetype not fully supported (TS works fine)
MTS filetype is not fully supported, especially for automation.
When importing an MTS, StaxRip would not fill the "Audio" tab (instad one must right click on audio and find the path to the specific MTS file MANUALLY, after that, it will work fine) This completely kills the ability to convert in automation mode (P.S there's one workaround - renaming the file extension to "TS" then it works fine) |
15th June 2018, 22:21 | #219 | Link |
Funny regression...
I am still using the old stable 32-bit version 1.1.9.0, and with this version audio is nicely supported for MTS files. So much for "Newer is always better" Cheers manolito |
20th June 2018, 20:52 | #220 | Link | |
Only MPEG-2 is officially supported with MTS with the full automation process. It's the pre-process that likely needs to be tweaked. you can make the changes your self in the settings under Pre-Process just add MTS to demuxer you wish to use. Last edited by Revan654; 20th June 2018 at 20:56. |
bug, staxrip |
