23rd March 2013, 23:59 | #101 | Link | ||
TEncoder, TX264, TAC
2) The thing that prevents TEncoder's GUI from being smaller is the number of controls on the right. I'm planning to put them in scrollbox if that works with skinning component. It most probably will be like some of the shareware encoders has. 3) Please use TAC's own thread for questions etc related to it. Why do you want to save logs to temp dir? It is for temp files. Notification sound "sounds" like a good idea. |
29th March 2013, 13:21 | #103 | Link |
it always produce unplayable mp4 files when i tried to hardsub srt files.
Also, even if the subtitles were turned off, mencoder seems often unresponsive/very slow encoding. I love how Tencoder keep the folder structure on output, ihope the subtitles (bug???) were fixed on future update. |
29th March 2013, 13:38 | #104 | Link |
The problem with unplayable MP4s is not in TEncoder; remember, TEncoder is only a GUI.
Blame ffmpeg / mencoder for multiplexing to incomplete MP4 containers (due to its "filter" behaviour, writing the output file sequentially only once). Fix them with MP4Box. |
29th March 2013, 15:04 | #105 | Link |
LigH beat me to it but Mencoder, for some reason, causes problem when using AAC audio. I just change audio codec to MP3 and works without a problem.
About MEncoder slowness, that might depend on many things but if you've selected AAC as audio codec, MEncoder writes lots of messages to console which might be slowing it down. I did a quick test and changing codec from AAC to MP3 speeds up the process at least x10 times. |
1st April 2013, 13:51 | #107 | Link |
Hi Ozok!
Just started using your tool, good work with the layout/skins. I used Tencoder in order to convert some videos to webm, usually i use a ffmpeg script but i wanted to test a GUI, for some some reason webm videos converted with tencoder end up with nearly twice as much bitrate, if i select 900 as bitrate the converted video has 1600. What could be causing this? Code:
My script: ffmpeg -i source.mp4 -vf "scale=-1:480" -codec:v libvpx -quality good -cpu-used 0 -b:v 900k -qmin 10 -qmax 42 -maxrate 900k -bufsize 1800k -threads 2 -an -pass 1 "1stpass.webm" ffmpeg -i source.mp4 -vf "scale=-1:480" -codec:v libvpx -quality good -cpu-used 0 -b:v900k -qmin 10 -qmax 42 -maxrate 900k -bufsize 1800k -threads 2 -codec:a libvorbis -b:a 128k -pass 2 "output.webm" Code:
Tencoder script: "ffmpeg.exe" -y -ss 00:00:00 -t 00:00:43 -threads 2 -i "source.mp4" -pass 1 -passlogfile "source.log" -vcodec libvpx -b:v 900000 -minrate 900000 -maxrate 900000 -bufsize 1800000 -muxrate 1800000 -r 23.976 -vf scale=866:368 -f webm -an "source.webm" "ffmpeg.exe" -y -ss 00:00:00 -t 00:00:43 -threads 2 -i "source.mp4" -pass 2 -passlogfile "source.log" -vcodec libvpx -b:v 900000 -minrate 900000 -maxrate 900000 -bufsize 1800000 -muxrate 1800000 -r 23.976 -vf scale=866:368 -f webm -map 0:0 -itsoffset 0 -map 0:1 -acodec libvorbis -ab 128k -af aresample=resampler=soxr -ar 44100 -ac 2 "source.webm" Last edited by ricardo.santos; 1st April 2013 at 13:56. |
1st April 2013, 14:41 | #110 | Link |
Cant tencoder use mp4box to fix corrupted mp4 that were talked about a few comments back? After the conversion finished the video has to go through mp4box? Can it be automated in Tencoder? That happened to me when trying to hardcode subs.
1st April 2013, 20:43 | #113 | Link |
There are some good signs. I changed many things but it seems I'll be able to release a new version with proper mp4 muxing using mp4box in a few days. After the changes, it will be much easier to add other encoders/tools as well.
TEncoder-Multithreaded GUI for FFMpeg and MEncoder TX264-x264 GUI with audio encoding, subtitle and chapter TAudioConverter-Multithreaded Audio Converter/Extractor THandBrake-HandBrake GUI Last edited by ozok; 1st April 2013 at 20:49. Reason: added date info |
1st April 2013, 23:24 | #114 | Link |
I managed to make TEncoder to use FFMpeg as muxer. I tried playing converted mp4 files with a mobile (galaxy mini) and it works fine. https://dl.dropbox.com/u/9617171/TEncoder_beta.7z if you want to try it. But please note that it is beta and make a backup before you copy it over to your TEncoder.exe. It is for installed version.
2nd May 2013, 00:21 | #116 | Link | |
Update:
3rd May 2013, 11:14 | #117 | Link |
Thank you for fixing the update check bug & screen resolution problem now TEncoder(3.4.0.3608) looks better in 800x600 resolution.
When skins are disabled in TEncoder(3.4.0.3608) many text in setting dialog are not visible because they are in white color. Since the main difference between the TEncoder installer & TEncoder Portable version is the TEncoder executable, i have made a installer script which will enable TEncoder installer to install both installer version & the TEncoder portable version optionally similar to the foobar2000 installer. When the Portable version is selected the installer will not create uninstaller & just extract the files & the TEncoder Portable executable & if the Portable version is not selected the installer will install the regular version and create uninstaller. This will help the users who use both installed version & the portable version, plus if a user first uses the installed version then he wants to use the portable version he will not need to download the portable version separately the same installer can be again used to extract the portable version. I hope you like & use the script for TEncoder Installer. Last edited by kolpotoru; 3rd May 2013 at 11:18. |
3rd May 2013, 11:27 | #118 | Link |
Oops, I forgot to change the colors.
Thanks for sharing your script. It is not approved yet so I can't download it but I'll take a look at it. BTW, it is not mentioned in the change log, support for ProRes was added with 3.4. |
4th May 2013, 13:52 | #119 | Link | |
Update:
TEncoder-Multithreaded GUI for FFMpeg and MEncoder TX264-x264 GUI with audio encoding, subtitle and chapter TAudioConverter-Multithreaded Audio Converter/Extractor THandBrake-HandBrake GUI Last edited by ozok; 4th May 2013 at 14:03. |
4th May 2013, 19:44 | #120 | Link |
what argument line would be best for bluray to avi (Xvid) asp level 5 with very best settings but using a CQ 3 (i'm after the very higest quality Xvid can produce kind of settings!
thanks. p.s. i want the Xvid part of FFmpeg, not the Mpeg4 generic encoder, LibXvid or something like that i think??? |
ffmpeg, gui, mencoder, multithreaded, subtitle |
