10th January 2010, 07:58 | #10181 | Link |
Didée Fan
software used
- first installed visual studio professional 2008, default loacation, full build - second installed sdk for windows 7 and .net 3.5, in the C:\Program Files\Microsoft Visual Studio 9.0\VC folder I made a new folder and called it "PlatformSDK" and installed the sdk in this folder. - third I installed the directx sdk, august 2009 - fourth the tortoise svn, TortoiseSVN-1.6.6.17493-win32-svn-1.6.6.zip - fifth i installed the custom made mingw designed for ffdshow. I installed this wrong the first time, the correct way to install it is to check all the boxes during installation. It will show a lost of boxes for these programs: mingw runtime 3.16(2009-08-15) msys 1.0.11(2009-07-18) gcc 4.4.1(tdm-2) binutils 2.19.1(2009-02-03) win32api 3.13(2008-12-06) pthreadsapi(2009-07-30) yasm 0.8.0(2009-04-10) make 3.81(2009-09-14) unxutils(2007-03-01) sdl 1.2.13 just check all the boxes and install in the default location. - sixth I downloaded yasm; yasm-0.8.0-win32.exe, I renamed this yasm.exe and put this in the C:\Program Files\Microsoft Visual Studio 9.0\VC\bin folder - seventh I downloaded and installed the innosetup QuickStart Pack: ispack-5.3.7-unicode.exe I let it install all the add ons available. - Eighth Then I downloaded the files from the internet and put them on my hard drive. here is how I did that. I opened windows explorer, file tab, svn checkout. I used this repository url: https://ffdshow-tryout.svn.sourcefor...w-tryout/trunk I chose where to save the file (c:\ drive) and clicked ok. it's fully recursive and head version. Now all the sw and files are on the computer and you can start the project step 1, open visual studio 2008, c++ environment, setup visual studio "tools, options, projects and solutions, vc++ directories" Code:
show directory for executable files (list is from top to bottom, use the arrows to move a line up or down.) $(WindowsSdkDir)\bin $(VCInstallDir)bin C:\Program Files\Intel\Compiler\11.1\054\bin\ia32 $(VSInstallDir)Common7\Tools\bin $(VSInstallDir)Common7\tools $(VSInstallDir)Common7\ide $(ProgramFiles)\HTML Help Workshop $(FrameworkSDKDir)bin $(FrameworkDir)$(FrameworkVersion) $(VSInstallDir) $(SystemRoot)\SysWow64 $(FxCopDir) $(PATH) C:\Documents and Settings\789\Desktop\ffdshow-tryout\bin show directory for include files (list is from top to bottom, use the arrows to move a line up or down.) $(ProgramFiles)\Microsoft DirectX SDK (August 2009)\Include $(WindowsSdkDir)\include $(VCInstallDir)include $(VCInstallDir)atlmfc\include $(FrameworkSDKDir)include show directory for reference files (list is from top to bottom, use the arrows to move a line up or down.) $(FrameworkDir)$(FrameworkVersion) $(VCInstallDir)atlmfc\lib $(VCInstallDir)lib show directory for library files (list is from top to bottom, use the arrows to move a line up or down.) $(ProgramFiles)\Microsoft DirectX SDK (August 2009)\Lib\x86 $(WindowsSdkDir)\lib $(VCInstallDir)lib $(VCInstallDir)atlmfc\lib $(VCInstallDir)atlmfc\lib\i386 $(FrameworkSDKDir)lib $(VSInstallDir) $(VSInstallDir)lib C:\Program Files\Intel\Compiler\11.1\054\lib\ia32 show directory for source files (list is from top to bottom, use the arrows to move a line up or down.) $(VCInstallDir)atlmfc\src\mfc $(VCInstallDir)atlmfc\src\mfcm $(VCInstallDir)atlmfc\src\atl $(VCInstallDir)crt\src show directory for exclude directories (list is from top to bottom, use the arrows to move a line up or down.) $(VCInstallDir)include $(VCInstallDir)atlmfc\include $(WindowsSdkDir)\include $(FrameworkSDKDir)include $(FrameworkDir)$(FrameworkVersion) $(VCInstallDir)atlmfc\lib $(VCInstallDir)lib step a. from ffdshow package using mingw "msys". click Start, all programs, mingw32, msys A cmd prompt black window will appear with a dollar symbol "$". Copy and paste each directory from the list I will show then press enter, then type "make" and press enter and the file will be created in the C:\ffdshow-tryout\trunk\bin folder here is a example of what the black msys window will look like: Code:
jeremy@jeremy-A0DCBD577E3 ~ $ Code:
jeremy@jeremy-A0DCBD577E3 ~ $ cd "/c/ffdshow-tryout/trunk/src/imgFilters/KernelDeint" Code:
jeremy@jeremy-A0DCBD577E3 /c/ffdshow-tryout/trunk/src/imgFilters/KernelDeint $ I do this for all the files in the list below: step 1. built with mingw msys cmd promt Code:
ff_kernelDeint.dll: cd "/c/ffdshow-tryout/src/imgFilters/KernelDeint" TomsMoComp_ff.dll: cd "/c/ffdshow-tryout/src/imgFilters/TomsMoComp" xvidcore: cd "/c/ffdshow-tryout/src/codecs/xvidcore" libmplayer.dll: cd "/c/ffdshow-tryout/src/mplayer" libavcodec.dll: cd "/c/ffdshow-tryout/src/ffmpeg" ffmpegmt.dll, ff_theora.dll, ff_x264.dll: cd "/c/ffdshow-tryout/src" libmpeg2ff: cd "/c/ffdshow-tryout/src/codecs/libmpeg2" ff_acm ff_liba52 ff_libdts ff_libfaad2 ff_libmad ff_realaac ff_samplerate ff_tremor ff_unrar ff_vfw ff_wmv9 ffavisynth ffvdub flt_ffdshow rebase verinc ffdshow ffdshowall makeavis How do you do this you may be asking? Open visual studio professional from the file tab click open project/solution go to this folder: C:\ffdshow-tryout\trunk, and choose ffdshow_2008.sln right click the top file from the list and choose configuration manager, set the Active solution configuration to Release unicode, set the active solution platform to win32, click close. highlight a file from the list shown, for instance ff_acm, then from the build tab choose build only ff_acm. Wait till it's built then look for the newly created file in the C:\ffdshow-tryout\trunk\bin folder You do this for every file I listed above. if you do everything correctly then when you build ffdhow you won't get a error, but if you did something wrong like something was not built by visual studio or msys, then you will get a Yasm error when you try to build ffdshow. Now all the files are built and you can create a ffdshow.exe in step 3. Step 3. Go to this folder: C:\ffdshow-tryout\trunk\bin\distrib\InnoSetup, double click this file to open it: ffdshow_installer.iss Add the info in the first five lines: day made and version number press f9, then from the build tab click compile and it will make ffdshow.exe and put it in that same folder. All done ! here is the ffdshow I made using the steps above. Why don't you install it and test to see if it works and tehen post to tell me how you did? link to the file I uploaded for you to test out. link to release version of a ffdshow I made This version uses set's patch. It's best to open ffdshow video configuration, decoder options, uncheck detect soft telecine, uncheck drop frame on delay
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 10th January 2010 at 13:19. Reason: section two files made by msys and visual studio tweaked |
10th January 2010, 08:39 | #10182 | Link | |
ffdshow user
ff_kernelDeint.dll,libmpeg2_ff.dll and TomsMoComp_ff.dll shouldn't be compiled by MinGW GCC because they are slower than MSVC 2008. |
10th January 2010, 09:22 | #10183 | Link | |
Didée Fan
I installed this wrong the first time, the correct way to install it is to check all the boxes during installation. It will show a lost of boxes for these programs: mingw runtime 3.16(2009-08-15) msys 1.0.11(2009-07-18) gcc 4.4.1(tdm-2) binutils 2.19.1(2009-02-03) win32api 3.13(2008-12-06) pthreadsapi(2009-07-30) yasm 0.8.0(2009-04-10) make 3.81(2009-09-14) unxutils(2007-03-01) sdl 1.2.13 just check all the boxes and install in the default location. " uninstall the custom mingw, then reinstall it and in the section it asks what to check to install check everything. gcc has a box unchecked and that needs to be checked, and sdl should be checked too.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. |
10th January 2010, 09:48 | #10184 | Link |
DXVA doesn't work here i get 33 fps i should get 60 fps like with MPC-HC though that isn't happening XP 32bit VMR7 Nvidia, i activated DXVA in the extra panel tried both ffdshow-mt and libavcodec nothing no acceleration.
Allgemein Vollständiger Name : I:\wipeoutHD_DE_1080p\WipEout_HD_German_1080p.mp4 Format : MPEG-4 Format-Profil : Base Media / Version 2 Codec-ID : mp42 Dateigröße : 171 MiB Dauer : 1min 11s Gesamte Bitrate : 20,0 Mbps Kodierungs-Datum : UTC 2008-08-01 18:14:03 Tagging-Datum : UTC 2008-08-01 18:14:09 Video ID : 2 Format : AVC Format/Info : Advanced Video Codec Format-Profil : Main@L4.2 Format-Einstellungen für CABAC : Nein Format-Einstellungen für ReFrame : 2 frames Codec-ID : avc1 Codec-ID/Info : Advanced Video Coding Dauer : 1min 11s Bitraten-Modus : variabel Bitrate : 19,9 Mbps Breite : 1 920 Pixel Höhe : 1 080 Pixel Bildseitenverhältnis : 16:9 Modus der Bildwiederholungsrate : konstant Bildwiederholungsrate : 59,940 FPS Auflösung : 8 bits Colorimetrie : 4:2:0 Scantyp : progressiv Bits/(Pixel*Frame) : 0.160 Stream-Größe : 170 MiB (99%) Sprache : Englisch Kodierungs-Datum : UTC 2008-08-01 18:13:45 Tagging-Datum : UTC 2008-08-01 18:14:09 colour_primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 transfer_characteristics : BT.709-5, BT.1361 matrix_coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 1 Format : AAC Format/Info : Advanced Audio Codec Format-Version : Version 4 Format-Profil : LC Format-Einstellungen für SBR : Nein Codec-ID : 40 Dauer : 1min 11s Bitraten-Modus : konstant Bitrate : 144 Kbps nominale Bitrate : 160 Kbps Kanäle : 2 Kanäle Kanal-Positionen : L R Samplingrate : 48,0 KHz Stream-Größe : 1,25 MiB (1%) Sprache : Englisch Kodierungs-Datum : UTC 2008-08-01 18:13:44 Tagging-Datum : UTC 2008-08-01 18:14:09
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 10th January 2010 at 09:53. |
10th January 2010, 14:08 | #10187 | Link |
Build 3195.
@Jeremy Duncan: Don't take what I'm going to say the wrong way, but please don't pollute this thread with these nonsense posts of yours. No one cares about how you compiled ffdshow. That's why the wiki exists. |
10th January 2010, 14:12 | #10188 | Link | |
Didée Fan
I then found out how and posted it in one single post, not multiple posts as you stated, only one post. Then xxl_ had a question which I answered. "No one cares ". And do you think you speak for everybody as you suggest? You do not speak for me.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 10th January 2010 at 14:14. |
10th January 2010, 15:30 | #10189 | Link |
Kerneldeint requires g++ (GCC c++ compiler).
MPC-HC 2.2.1 |
10th January 2010, 17:13 | #10191 | Link | |
Your experieces compiling are much appreciated. Could you please help to update the wiki?
10th January 2010, 17:34 | #10192 | Link |
@Jeremy Duncan: It's pretty clear that you don't have any clue about what you are doing. I'm not saying that I'm an expert, which clearly I'm not, but the wiki instructions are pretty straightforward (although it needs updating since some compilers have changed like xvidcore is built with MSVC and not GCC). So please don't do what Casshern suggests.
Now, that's only my opinion and so you can do whatever you think at the end. |
10th January 2010, 18:29 | #10193 | Link |
Media Control author
Okay, Jeremy's posts are veryyyyy long, but there are different ways to request things.
FFDShow is complicated to compile, and the wiki needs to be updated so please do so. We are very few on this project and need motivated newcomers so please let's remain.... uh, welcoming |
10th January 2010, 18:41 | #10194 | Link |
There's a wiki page? Son of a!!! I set it up blind when I first compiled it for the bitstreaming debugging. Ah well.
10th January 2010, 20:28 | #10196 | Link |
Software Developer
Just a heads up, I'm not sure if it's a regression issue or just a screw-up with the build numbering, but ffmpeg-mt H.264 decoding is broken in build 3190 (non DXVA decoder), works in build 3189.
10th January 2010, 20:40 | #10197 | Link | |
EDIT: So soon - videos are still blue if DXVA is off...
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 10th January 2010 at 20:46. |
10th January 2010, 21:21 | #10198 | Link |
Old fart
I know some may consider this slightly off topic and I do apologize if it really is.
I am running 3195 build using both Haali and MPC (for m2ts) as splitters. I am running through MediaPortal as my main player. I have a Xonar slim card as my audio card. I am using the TMT audio renderer as is suggested. The following has been a problem since the first HD pass through builds. I can get DTS-MA and Dolby TRUHD to work with my receiver no problem. The problem is that once either of those formats plays I cannot get any other audio format to play. It is like my pc codec is locked and will not reset until I close out of the application and restart it. I do not know if this is an issue in ffdshow or Media Portal and honestly I don't know how to find out. If I leave use PCM first unchecked my HD video will not even start. Checking using Xonar formats has no effect and AC3 encode mode is unchecked. Thanks for all the great work, Mark
Oh no Mr. Bill! |
10th January 2010, 22:19 | #10200 | Link | |
It works but not complete, i have sometime blue color. I must set option to "ignore .... " with normal it don't work. But i must made more test and i'll try 3195 to see what happen But it's great DXVA Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
