Old 1st July 2006, 23:29   #21  |  Link
Kostarum Rex Persia
Banned
What about XP 64-bit build of MPUI and MPlayer/MEncoder?
Kostarum Rex Persia is offline
Old 2nd July 2006, 03:26   #22  |  Link
celtic_druid
celtic_druid's Avatar
If you want 64bit mplayer, then install Linux.
celtic_druid is offline
Old 2nd July 2006, 04:06   #23  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
... and forget win32 codecs ...
Sharktooth is offline
Old 2nd July 2006, 04:51   #24  |  Link
celtic_druid
Well yeah. Same would I guess be true of an x64 port. x64 seems to be somewhat lacking in terms of 64-bit multimedia playback. There are a couple of .NET based samples/players, graphedit, ffdshow, XviD, some MPC filters, that is about it.
Old 2nd July 2006, 11:44   #25  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
*UPDATE*
MPlayer/MEncoder 2006-07-02
LoRd_MuldeR is offline
Old 2nd July 2006, 17:42   #26  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
Thanks LoRd_MuldeR for keeping us posted
btw, I'm having some issues with encoded files (Xvid codec, MK container, encoded and muxed using MeGUI)
I tried and used VirtualDub, same issue. Not the same error message, but mplayer says it can't play the file. No Video track found.
The files work fine with other players though :S
Any idea?
Thanks!
Setting process priority: abovenormal
C:\WINDOWS\Fonts\Arial.ttf doesn't look like a font description, ignoring.
Cannot load font: C:\WINDOWS\Fonts\Arial.ttf
Playing Z:\trailers\The Night Listener\thenightlistener_1280.mkv.
ID_VIDEO_ID=0
[mkv] Track ID 1: video (V_MPEG4/ISO/ASP), -vid 0
[mkv] Unknown/unsupported CodecID (V_MPEG4/ISO/ASP) or missing/bad CodecPrivate data (track 1).
[mkv] No video track found/wanted.
Matroska file format detected.
No stream found.
Exiting... (End of file)
Razorholt is offline
Old 2nd July 2006, 21:30   #27  |  Link
iwod
Well it still does not play unicode files for some reason.
iwod is offline
Old 2nd July 2006, 21:51   #28  |  Link
emmel
Small suggestion: It might be useful to add some -cache by default in the cl-params when accessing File -> Play URL...
emmel is offline
Old 2nd July 2006, 23:02   #29  |  Link
LoRd_MuldeR
Software Developer
Any idea?
Thanks!
Maybe your file is broken in some way or it's a bug in MPlayer.
Old 2nd July 2006, 23:03   #30  |  Link
LoRd_MuldeR
Software Developer
You should report that to the author of MPUI.
Old 2nd July 2006, 23:34   #31  |  Link
emmel
Oh, sorry, I was a bit confused, I thought you were the "responsible" in this case... Anyways, done.
emmel is offline
Old 3rd July 2006, 07:51   #32  |  Link
celtic_druid
Seems to work ok here. Straight x264 encode. No audio or anything though.
Playing D:\Stuff\test.mkv.
[mkv] Track ID 1: video (V_MPEG4/ISO/AVC), -vid 0
[mkv] Will play video track 1
Old 3rd July 2006, 09:50   #33  |  Link
Mix de Rax
Could You make also a non SSE just MMX version. Please.
Mix de Rax is offline
Old 3rd July 2006, 13:13   #34  |  Link
LoRd_MuldeR
Software Developer
You can take the build from that download. Just replace MPlayer.exe
http://prdownloads.sourceforge.net/m...8.zip?download
Old 3rd July 2006, 17:42   #35  |  Link
markrb
Old fart
markrb's Avatar
I have read everything I can find, including the html that came with it, but I am stumped on 2 things?
1. I found it.
2. How do I make the player default into fullscreen mode?
Thanks,
Mark
Oh no Mr. Bill!
markrb is offline
Old 3rd July 2006, 17:49   #36  |  Link
LoRd_MuldeR
Software Developer
I guess you talk about MPUI.
Just go to the options window, select language and save!
Old 3rd July 2006, 19:00   #37  |  Link
markrb
Old fart
markrb's Avatar
Yep saw that after I posted. I was just using the seperate language drilldown that is not on the options screen.
Thanks,
Mark
Oh no Mr. Bill!
markrb is offline
Old 4th July 2006, 00:55   #38  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
@ LoRd_MuldeR: I will email the folks there, thanks.
@ celtic_druid: Encoded with x264 works fine. Please try encoding the same file (with or without audio) with Xvid. MeGUI is fine. Thanks.
Old 4th July 2006, 01:00   #39  |  Link
Kostarum Rex Persia
Banned
Where I can find sources for MPUI 1.2?
Old 4th July 2006, 01:12   #40  |  Link
LoRd_MuldeR
Software Developer
http://sourceforge.net/project/showf...roup_id=155302
mplayer, mpui, smplayer, windows
