Old 21st February 2018, 15:43   #49181  |  Link
nevcairiel
Originally Posted by e-t172 View Post
Again, the only reason why it's 100 MB is because madshi wrote the simplest possible 3DLUT code without support for interpolation, therefore users are forced to generate full 256x256x256 3DLUTs which are grossly overkill. If you can get away with using smaller 3DLUTs, just like all other color-managed software does, then I suspect it will be much faster. (A 64x64x64 16-bit 3DLUT is 1.5 MB.)
The reason the 3DLUT is so large is specifically to front-load the processing requirement, and not have to do it for every single video frame. Thats the entire purpose of such a LUT in first place - solve complex math once.
Photoshop for example isn't going to care if displaying a single image takes 100ms of color processing, its not in any area a user is going to notice. Video playback does care, hence entirely different requirements.
Old 21st February 2018, 15:47   #49182  |  Link
If you can color correct a single image, then it de facto means you can trivially generate a 3DLUT. It's super easy: just generate an image containing all the source colors you care about, then color correct it. The resulting image is de facto your 3DLUT. It's as simple as that. If you have the transform to color correct a single image, then just generate a 3DLUT from that transform and then it's business as usual. Thus the "60 times a sec" that you're worried about is a non-issue. The hard part is generating the transform - once you have that, the rest is trivial.
(The reason why it's so simple is because the color of a destination pixel is only determined by the color of the source pixel - there is no other input, which is the very reason why you can use a LUT in the first place.)
and who said that the image has all possible colors and who said PS is saving it for all possible colors?
the 256│ LUT is interpolated from a 64│ with default settings. so you want to make it faster by skipping the interpolation which is suspected to be slow to be done later in realtime?
Old 21st February 2018, 16:04   #49183  |  Link
e-t172
If your 3DLUT is smaller than full size (say, 64x64x64 instead of 256x256x256), then the only "complex math" you need to do in real time is interpolation between the 3DLUT points, such as basic bilinear or bicubic interpolation. Which is laughably trivial for a GPU to do, and something that I'm sure madshi would be able to do in his sleep.
You don't even need to use a fancy upscaling algorithm for that - no one is going to notice the difference. (Keep in mind that the color response of any reasonable monitor is at least somewhat linear, so basic interpolation is highly likely to land very close to the correct point. And in fact, you really don't want to get too fancy, because a response that's not smooth will result in banding artefacts. Which is why ArgyllCMS docs warn you against generating a transform that's trying to be too precise.)
It is trivial to generate an image that has all possible colors. In fact, a full 3DLUT is, itself, by definition, an image that has all possible colors. You just need to deal with that once (not for every frame), and then you're done. In practice though, you would use sampling (only generate an image with a subset of all possible colors, such as 64│) and then interpolate, as described above.
Huh? I didn't know that madVR could interpolate from a 64│ 3DLUT. I've always used a 256│ 100 MB 3DLUT (256x256x256 x 3 colors x 16-bit = ~100 MB). Maybe I've missed that option.
In any case, yes, I'm saying that 3DLUT interpolation can, and should, be done in real-time. That's completely trivial and can be done extremely quickly. (Just like video upscaling, except you can get away with very basic interpolation.) Interpolating a large 3DLUT from a small one is not hard nor expensive. It's generating the initial transform that's the hardest part. Everything else after that is peanuts.
e-t172 is offline   Reply With Quote
Old 21st February 2018, 16:16   #49184  |  Link
Ver Greeneyes
I think what huhn is referring to here is the processing in collink - collink generates a 3DLUT of a lower resolution (determined by the quality setting) then interpolates it to 256x256x256 to produce a file compatible with madVR. But you can override the resolution using -r256 to make it produce a 256│ 3DLUT directly without interpolation (which obviously takes a while).
Old 21st February 2018, 16:24   #49185  |  Link
e-t172
Ah, okay. But the ArgyllCMS docs explicitly state that you should not do that. I can't find where the exact rationale is explained but, IIRC, you don't want to generate too many points because there is a point of diminishing returns where you're basically just optimizing for measurement error and are more likely to create banding and other aberrant behavior than to actually improve color accuracy. This leads to the counter-intuitive result that interpolating provides better results than trying to achieve maximum precision, because the resulting transform is smoother.
Old 21st February 2018, 16:42   #49186  |  Link
Ver Greeneyes
Sure, I mean regardless of the fact that it's possible not to use interpolation, I don't think it really matters since we aren't pushing for madVR to do that. I suppose there is some value in noting that collink is slow despite not producing a 256│ 3DLUT directly, but I think that's just because it does everything to a very high standard. Whatever the reason, there are counterexamples showing that the process doesn't have to be that slow (and there's no reason not to cache the result).
Old 21st February 2018, 16:48   #49187  |  Link
bkrieger
Depends on your content, personally I'd drop chroma or luma scaling back if you need the headroom to hit that sweet SSIM 2D, your decision if you want to stick AR on top of that but personally I'd rather use that headroom for luma and chroma.
I am mainly watching 1080P movies
Should I drop Chroma Upscaling to NGU AA medium, and change downscaling to SSIM 2D?
Also under “ if any more Upscaling/downscaling is needed”, I have set to Let Madvr decide. Should I change these to something else?
Also, under image Upscaling, should I leave the quadrupling settings to “let madvr decide” as well as Chroma set to normal?
Lastly, what do you mean if I want to stock AR on top? What settling is that for and what should it be changed to?
Thanks
bkrieger is offline   Reply With Quote
Old 21st February 2018, 17:33   #49188  |  Link
fhoech
fhoech's Avatar
Originally Posted by Asmodian View Post
The 3DLUT is is a better solution, technically, than it would be if madVR used the full contents of the ICC profile.
Creating complex gamut mapping is not really a focus (and doesn't need to be) of applications using ICC profiles to display imagery, irrespective if they are video renderers/players/editors or still image viewers/editors. There is no inherent technical reason why one solution would be superior to the other (pre-computed link/3D LUT vs dynamic linking of, in essence, also pre-computed cLUTs). The practical reason you can do more with a pre-computed link/3D LUT in terms of complex gamut mapping is because ICC color management modules that do the actual color transform, are by design "stupid" (same for programs applying 3D LUTs as they don't have to concern themselves with anything else than straightforward lookup through the cLUT and maybe interpolation) - all the complexity is in the profiles. That allows fast transform creation (linking) and application, and software authors can implement support more easily (even more easily if they just want to support pre-computed links).
But there's a difference between just creating a transform (linking two existing ICC profiles, for example) and inverting the "natural" profile (which for display devices is inverting the device RGB -> CIE values mapping), doing complex gamut mapping and appearance modeling (what Argyll's collink does when used with the -G inverse forward lookup gamut mapping option). The latter bunch is what takes up most time, transform creation (linking) alone is relatively trivial. You could also put all that complexity in the input and/or output profile creation instead of into the link creation (less self-contained approach though).
Also what is in an ICC profile, beyond the simple 1D LUTs, varies wildly. Often they contain simple measurements that can only be used to do a rough conversion with little or no user control over how it is done. madVR's 256x256x256 3DLUT allows full control of the conversion with very fine grained corrections being possible.
Same is true for any 3D LUT, naturally, when it comes to the result. The source and destination color spaces to be linked can come from just a few measurements, or a synthetic color space defined by only primaries and simple tone curve, or thousands of measurements or complex synthetic cLUT-based color spaces.
Wow, EVR uses an ICC profile in Windows 10 now?
That functionality has been around for well over half a decade now (not sure if it's a feature of EVR or MPC-HC).
Unfortunately there are simply too many formats or types of ICC profiles and that tool doesn't support all of them. Proper handling of most ICC profiles is a big job.
Argyll supports all types of profiles, but only version ICC v2.x, not ICCv4.
I don't think web browsers use ICC profiles for video, but they do support it (to some extent) for still images. (Although they support it in kind of a retarded way because they don't use the monitor ICC profile - they always use sRGB as the destination. But that's neither here nor there.)
Yes, browsers that do color management, only tend to color manage still images. IE 9+ (prior versions had no notion of color management whatsoever) and Edge use sRGB as display profile though (which is wrong and broken, could as well use no color management), Firefox does work correctly (but you really should set gfx.color_management.enablev4=true to get cLUT profile support), even though its multi-monitor support is lacking. Chrome does color management since a few versions, but it regularly seems to break in all kinds of interesting ways.
Originally Posted by Ver Greeneyes View Post
Now I imagine Firefox cuts corners to do this, and they replaced LCMS with the in-house qcms because LCMS wasn't fast enough
If I recall correctly the reason for the replacement was not speed but security concerns (which several people, me included, shook their head at at the time, and still do).
A performant color management solution worth it's salt will cache the transforms and re-use them if it detects same source and destination profiles, and it will apply the created transforms using hardware acceleration via a GPU, e.g. via texture lookups/shaders.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
fhoech is offline   Reply With Quote
Old 21st February 2018, 17:45   #49189  |  Link
Ver Greeneyes
Hmm, I don't recall. I do know they designed qcms to be fast.. but they wrote the whole thing in C and gave it an upstream repository, which has resulted in it becoming basically unmaintained. The library works, but I wouldn't call it their finest moment. I wonder if anyone has considered rewriting it in rust..
Old 21st February 2018, 17:56   #49190  |  Link
e-t172
In the case of madVR you could be even smarter and, on top of caching, also compute the transform asynchronously. The video starts playing with slightly wrong colors for maybe a few seconds while the transform is being computed, and as soon as it's done, the transform is swapped in and color correction is active for the rest of the playback session.
Old 21st February 2018, 18:04   #49191  |  Link
fhoech
fhoech's Avatar
Exactly. You then push that (e.g.) 64^3 image through your transform, and the resulting image is your 3D LUT. Cache it, use it. Over and over. 60, 120, 240, or any number of times per second that you need. GPUs are made for that, speed is not an issue unless you have texture sizes that no longer fit into the graphics card memory.
madVR can load eeColor 3D LUT files, which are 65^3 by design.
Old 21st February 2018, 18:14   #49192  |  Link
fhoech
fhoech's Avatar
I have a feeling they achieved speed mostly by leaving out all the parts of a CMM that deal with complex transforms (i.e., cLUT profiles). Naturally, they could be fast when they didn't even do color management
Not even sure that would be needed. Transform creation using LCMS should take mere milliseconds on a moderately modern system (as it's only linking). I may be wrong, but I think the main time spent is probably reading the files from disk, and then a couple more milliseconds to apply the transform to the input 'cLUT' image (the result of which will be the final 3D LUT).
Old 21st February 2018, 18:32   #49193  |  Link
e-t172
I meant that in case someone wants to go through the full gamut mapping process (i.e. the equivalent of collink -G) on the fly. But as you said, it is debatable whether that's really that useful in the first place.
Old 21st February 2018, 18:33   #49194  |  Link
leeperry
Kid for Today
If all you need is gamut mapping, this script works like a charm in mVR: http://www.avsforum.com/forum/26-hom...lly-works.html
Feel free to use a Windows LUT on top if need be.
IME on test patterns it outputs identical results to 3DLUT's with a perfectly calibrated TV using CMUNDIS + Color.HCFR.
You can setup automatic PotPlayer profiles using different gamut mappings based on resolution and/or framerate, works like a champ and you can roll them with a mouse click too
Old 21st February 2018, 18:41   #49195  |  Link
e-t172
leeperry: it looks like your solution is just simple matrix conversion (as opposed to a 3DLUT-based solution). It will do gamut mapping alright, just not in a very accurate way, especially if your monitor is not perfectly linear. Also part of of this discussion is about making it easier for madVR users to get perfect color correction by simply doing the right thing out-of-the-box as soon as an ICC profile is configured for the monitor in which video is playing, and asking them to write shader code or setting up complex profiles goes a bit against that don't you think
(I also have the suspicion that naive matrix-based transforms will give poor results if the source gamut is very different from the destination gamut, e.g. DCI-P3 -> BT.709, because the mapping is very inflexible and any non-linearities get magnified. I'm just speculating though.)
Old 21st February 2018, 22:30   #49196  |  Link
ryrynz
ryrynz's Avatar
You should have a bit more performance available than I do so you may get away with high.. but yes, I have chroma set to NGU AA medium, NGU sharp set to high (very high is hardcore, btw madshi setting in between these please? xP)
You can get SSIM 2D by 'use "image downscaling" settings' and having SSIM 2D set there.
No, that's fine.
Quadrupling doesn't gain you much generally, and certainly you won't be doing this with 1080 content, so leaving it is fine.
"Stack AR on top" "AR" is Anti-ringing, it's a tick box under 'downscaling'. Personally I prefer the added sharpness with it not being ticked (plus I need the extra headroom) I keep sharpeners for at the end if required, I find supersampling and downscaling first achieves more pleasing results.
Old 21st February 2018, 22:39   #49197  |  Link
bkrieger
Thank You very much. I actually do have the AR filter checked, I have it set to relaxed.
Thanks
Old 22nd February 2018, 01:00   #49198  |  Link
Oguignant
Oguignant's Avatar
Hi !!! One question, what version of Nvidia driver works MadVr + HDR + 12bits 23hz?
385.26, 385.69 or 390.77
"To infinity, and beyond!"
Oguignant is offline   Reply With Quote
Old 22nd February 2018, 01:16   #49199  |  Link
ryrynz
ryrynz's Avatar
Use 390.77, I'm aware of no issues with it with madVR.
Old 22nd February 2018, 02:55   #49200  |  Link
Asmodian
Yes, 390.77 has some good fixes for HDR and no regressions I know of. Still weirdness with custom resolutions sometimes but that is in all the options.
madVR options explained
