2nd June 2007, 10:28 | #1181 | Link |
WMP10 on Vista
I`ve tried to install Wmp10 on a german Vista 32Bit with the instructions of CademiaX. Now WMP 10 runs on my vista (Ultimate). The problem with the error message #File wmploc.dll is version 10.xxx and not 11.xxx, which was expected....# disappeared after i double-clicked on unregmp2.exe under the Programme/Windows Media Player folder.
Now Wmp runs fine. The problem now is, that i can`t do the upgrade on the windows media individualisation site . The Upgrade Button is greyed out. So I can't play files with licenses. Has anyone installed WMP10 on Vista successful. Please Help |
2nd June 2007, 15:30 | #1182 | Link | |
3rd June 2007, 17:37 | #1185 | Link |
oh, i dunno then. i haven't used vista.
are there any online subscription stores that are totally online, you don't have to install anything and have a free trial where you don't have to enter credit card info?? i looked at napster, but you need to enter credit card info. i also checked out urge, but it makes you update wmp. |
4th June 2007, 22:43 | #1187 | Link |
drmdbg update
drmdbg 2007/06/04 00:15 for "IndivBox.key v11.0.6000.6324"
by taku & inoyan http://panda.orz.hm/uploader/5/src/up48.zip |
6th June 2007, 15:26 | #1188 | Link | |
Banned
and Cademix - YES...I have spent countless hours trying to do wmp11b2 on vista...no dice, so wanted you to know I worked on it hard also, and came up with nothing. I finally actually got it instgalled, but right when I opened it, it would crash, so technically it was on there, but I was never able to keep it running more than 10 seconds. ::: milOtis |
6th June 2007, 15:30 | #1189 | Link | |
Banned
not true. if you have windows XP you can use windows media player 11beta2 with URGE all you want without updating. I have three PCs right now with that setup. Everytime I open windows media player it says "do you want to update" i just hit no, and I'm still downloading DRM music from urge to this day. also, i have windows vista instlaled with virtualpc, and have windows xp running in that, and urge is using 11.0.5703.x version of media player also. (beta 2) It doesn't force you to update, it just asks all the time, you can just click 'no'. ::: milOtis |
6th June 2007, 16:06 | #1190 | Link | |
6th June 2007, 20:26 | #1191 | Link |
Ren: I use URGE, and the security update it prompts you for doesn't upgrade your ibx. I'm not sure what service you use, but if it's not allowing you to play protected files, the worst you can do is try (remember to restart afterwards, though!). If it doesn't work, you can always use the rollback procedure gone over many times before (I just did it last night with 11.0.57, so I know it still works)
6th June 2007, 23:07 | #1194 | Link | ||
Banned
anyone having trouble should read the second answer!
Remember the motto: "If it ain't broke, don't fix it" and if you have a working FairUse4WM and music service that doesn't require you to upgrade, then keep it taht way! If you are on windows xp, my "12-27 fix" will work just fine for you on rolling back to wmp11beta2... (used it on my friend's computer last week that was 100% updated to the latest wmp11) This has been tested on xp home, professional, 64bit, and on dells, gateways, acers, shuttles, even intel imacs, and it works on all of them...the people who are having trouble with my FairUse4WM fix is anyone on vista, or who use more than one WMA-file music service, like Urge and Napster to download songs, or Yahoo and Rhapsody and something else...due to conflicting DRM data, the rollback does not work for those people, and their upgrade button is grayed out on the individualization site. So pick a service you like and only use just that ONE. ::: milOtis Last edited by milOtis; 6th June 2007 at 23:25. |
7th June 2007, 03:55 | #1197 | Link |
I just rolled back my install last night. I use Zune, so I had to get rid of that as well, but I know the rollback still works. (if possible, don't use Beta 2, it's much slower than the final version, and there's really no need). If you can't find WMP 11.0.57, pm me.
MilOtis: do you know how to disable the "upgrade now" dialog? I've tried setting wmp to never check for updates, but that doesn't work. I've also tried hacking with the dlls, but nothing really came of that. Do you have any ideas? Or is it just a minor annoyance that I'll have to put up with every now and then? |
7th June 2007, 05:44 | #1200 | Link | |
http://forum.doom9.org/showthread.ph...reg#post979744 Regards |
