31st July 2015, 07:49 | #32301 | Link | ||
31st July 2015, 09:13 | #32302 | Link | |
31st July 2015, 11:49 | #32303 | Link | |
So we add information and a good algorithm makes sure that it's *good* information. Thanks. |
31st July 2015, 11:51 | #32304 | Link | |
Following this I managed to get to 23.97589 and/or 23.97599 which is really close to what we aim for. |
31st July 2015, 12:10 | #32305 | Link | |
31st July 2015, 12:30 | #32306 | Link | |
a custom refreshrate overrides the 24hz so you can used that for 24 hz movies any more. |
31st July 2015, 12:38 | #32307 | Link |
that doesn't change that most people didn't have one and that this will not change for some time.
don't get me wrong I order one my self month ago and stopped test madVR and wasn't using my HTPC any more but i order this TV at hardwareversand so i'm forced to wait a "bit" longer. the good news i don't need a 960 any time soon. but most important AMD cards are ridiculously strong for openCL. nnedi3 is the only madVR feature for openCL now but that may change in the future. so openCL maybe has use for something else so removing it doesn't really help. Last edited by huhn; 31st July 2015 at 23:25. |
31st July 2015, 14:07 | #32310 | Link | |
I don't think it has necessarily to do with OpenCL but with the kind of calculation that is executed. In Anandtechs compute tests (OpenCL only), Fury X is sometimes much slower than Titan X (and vice versa): http://www.anandtech.com/show/9390/t...ry-x-review/24 I don't think GCN looks great here, since it's just 6.2 TFlops for GM200 vs. 8.6TFlops for Fiji. |
31st July 2015, 16:23 | #32313 | Link |
Then install Windows 8.1, it solves all your troubles!
31st July 2015, 16:33 | #32314 | Link |
I'm not aware of any mouse issue with 353.49, nothing like that showed up here with GTX 980.
There was a mouse cursor issue with drivers post 353.49, but it's fixed in 353.62 (which has the OpenCL issue, of course). I still wonder if NNEDI3 OpenCL is also broken with AMD in general on Windows 10 with most current drivers (15.7.1). |
31st July 2015, 16:34 | #32315 | Link |
I'm holding off on Windows 10 until this gets resolved. I don't need it that badly. The questionable opt-out systems (sharing Wifi with all contacts, P2P updates..) are also making me less than enthusiastic about upgrading.
Edit: Apparently the Wifi sharing is opt-in per network, which isn't so bad.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) Last edited by Ver Greeneyes; 31st July 2015 at 18:04. |
31st July 2015, 16:39 | #32316 | Link |
You can basically disable everything privacy-related.
Only thing that can't be disabled is feedback about installed programs, for this you need Enterprise edition (or dirty hacks). Edit: Is the extension still there on Windows 8.1 with 353.62? Last edited by aufkrawall; 31st July 2015 at 16:42. |
31st July 2015, 17:20 | #32317 | Link | |
Posts: n/a
It has 90% of what everyone needs to do after Windows 10 installation to get it REAL fast, smooth, compatible, and with Feedback disabled for good! I do not want to provide a link to the actual guide (on a forum) because I do not want to violate Doom9 forum rules, which are strict regarding certain aspects. |
31st July 2015, 20:42 | #32319 | Link | |
Win10Pro, 15.7.1, NNEDI32, 720x352 encode => 1080P HDTV
Win7Ult || RX560/4G || Ryzen 5 |
