Old 6th April 2021, 18:03   #3661  |  Link
Selur
Selur's Avatar
Hybrid rev 2021.04.06.1:
*fixed*
  • Jobs: batch job creation
-> downloads: http://www.selur.de/downloads
Cu Selur
Old 12th April 2021, 07:37   #3662  |  Link
ReinerSchweinlin
*fixed*
Cu Selur
Nice Thanx!
Old 12th April 2021, 15:43   #3663  |  Link
Selur
Selur's Avatar
Hybrid rev 2021.04.12.1:
*fixed*
  • Jobs: vpx version check
  • Avisynth: IVTC - TFM add additional options
  • Vapoursynth: fixed QTGMC bob
Cu Selur
Old 13th June 2021, 13:56   #3664  |  Link
Gravitator
Салам!
How can I avoid resetting the encoding thread to the processor when changing the profile in x265?
Win10x64, Xeon E5450, GTX 750 2GB, DDR3 8GB.
Gravitator is offline   Reply With Quote
Old 13th June 2021, 14:02   #3665  |  Link
Gravitator
I mean the preset
Old 13th June 2021, 18:29   #3666  |  Link
Gravitator
Bloated font.
https://images4.imagebam.com/f2/29/9f/ME1224W_o.jpg
Last edited by Gravitator; 14th June 2021 at 16:52. Reason: Added a link to the image.
Old 16th June 2021, 18:51   #3667  |  Link
Selur
Selur's Avatar
You can't presets are rooted on the default values, thus Hybrid resets first to the default values and then applies the changes associated especially with the preset.
Bloated font.
will look at it
Old 17th July 2021, 19:39   #3668  |  Link
Selur
Selur's Avatar
Hybrid rev 2021.07.17.1:
*fixed*
  • Decode: ffmpeg rgb -> yuv conversion with pc scale
  • Subtitle: do not convert subtitles to ttxt when muxing srt to mp4 with ffmpeg
  • Vapoursynth: embed sup subtitle
  • Avisynth: AutoAdjust only using general parameters when autoBalance was a enabled
  • Vapoursynth: ResampleHQ call
  • Vapoursynth: crash when fmtconv was used multiple times with 'spline16'
  • Avisynth: 64bit ImageSequence handling
  • Decode: add swapuv when using eq2 on 422 sources in FFmpeg
  • Xvid: encoding progress when using xvid_encraw
  • Vapoursynth: meta overwrite evaluation
  • Vapoursynth: Santiag h/v
  • Vapoursynth: Stab 'mirror'-parameter
  • Frontend: fixed font size in some tool-tips
  • Analyser: crash on some calculation decimal to fraction combinations
  • Vapoursynth: TIVTC + gpu
  • Audio: eac3 passthrough to mp4
  • Muxing: ffmpeg chapter generation
  • Muxing: ffmpeg + avc + parallel subjobs
  • Avisynth: don't use lsb with Avisynth+
  • Vapoursynth: GLSFilter calls when used with FilterQueue
  • Vapoursynth: Filter Queue handling
  • x265: adjust --uhd-bd do not remove options
  • x265: ultrafast profile
  • Audio: fixed 'auto (add all)' accidentally adding an audio track 2 times
  • Vapoursynth: Histogram depending on type restrict color space
  • Vapoursynth: filter preview crash for SRMD resizer
  • Vapoursynth: crash when ToneMap was used on rgb content
  • Avisynth: inserting custom code before QTGMC failed.
  • Audio: '-ignore_editlist' accidentally used even when handling pipeinput from sox
  • Crop: crop value not always properly reset on source change
  • Jobs: don't use mkvmerge with flac audio since mkvmerge doesn't support cutting flac fixed ass style overwrite
  • Vapoursynth: AddLogo (reenabled EdgeFixer)
  • Vapoursynth: set Fades didn't enable (on Linux)
  • Decode: ffmpeg -> x264 (use rawvideo)
  • Decode: x264 use raw video instead of y4m pipe when not using a script
  • Synth: SelectRangeEvery frame count/rate calculation of output
  • Filtering: fix rotation flag
  • Avisynth: tv/pc luma mapping on import
  • Autocrop: fix QSVCEnc detect fix
*changed*
  • Vapoursynth: changed sangnom.SangNom to sangnom.SangNomMod calls in scripts
  • Files: sort file names explicitly when collecting them from the OS
  • Frontend: AVStats: do not adjust based on selection/cut
  • Muxing: adjust chapter&qp file to cut
  • Vapoursynth: use 'accurate=1' when using VsFilterMod and high bit depth content. (slower but more accurate)
  • Vapoursynth: stepped resize support
  • Vapoursynth: FrameRateConverter
  • Synth: Hybrid now only auto-refreshes the Vapoursynth/Avisynth preview if "Filtering->Misc->Auto-refresh" is enabled, otherwise refresh needs to be triggered manually
  • Synth: F5 refreshes the Avisynth/Vapoursynth preview when 'auto-refresh' is disabled
  • Vapoursynth: allow multiple 'Framerate Interpolation'-methods when using 'Filter Queue'
  • Tools: remove 32bit qaac support
  • Internal: fraction handling
  • Synth: by default remove FFmpeg/Mencoder deinterlacers when using AviSynth
  • Vapoursynth: adjusted to Waifu2x cnn to r4
  • Vapoursynth: dgdecnv use default activated
  • Vapoursynth: added option to force a specific chroma location when converting from and to YUV420
  • Avisynth: changed script names
  • Avisynth: lifing some 8bit restrictions
  • adjusting SVT AV1 to removed options
  • Video: NVEncC: check that "NVEncC->Only encoder" is used only on supported formats
  • Video: x265: hme-range support
  • Video: svt-av1 ui glitch when switching encoding typ
  • DGDecNV: remove license.txt check of DGDecNV support, since it's free now
  • Video: x265 removed signal end of bitstream/videostream
  • Analysis: if scantype is interlaced but unknown after interlaced checked, assume tff if inpuHeight > 576
  • x264/x265: extend some options from single to double didget fl
*added*
  • Vapoursynth: debanding through vs-placebo
  • Vapoursynth: FrameRateConverter support
  • Vapoursynth: Detail-Preserving Image Downscaler (https://github.com/ WolframRhodium/VapourSynth-dpid/)
  • Vapoursynth: added support for RIFE (https://github.com/ HomeOfVapourSynthEvolution/VapourSynth-RIFE-ncnn-Vulkan) (Windows only atm.)
  • Vapoursynth: support for VSGAN through an 'addon' (Windows only), download only by request since it's huge
  • Vapoursynth: SpotLess from G41Fun
  • Vapoursynth: support for SmoothLevels from havsfunc
  • Vapoursynth: TIVTC from https://github.com/dubhater/vapoursynth-tivtc
  • Vapoursynth: added 'Flip vertical' to Santiag
Cu Selur
Ps.: BIG THANKS to DG for allowing me to bundle DGDecNV with Hybrid!
Old 18th July 2021, 08:36   #3669  |  Link
Selur
Selur's Avatar
Hybrid rev 2021.07.18.1:
*fixed*
  • Vapoursynth: missing libraries and old scripts in MacOS package
    Users might have to reset FilteringModel defaults and Vaporusynth filter order.
*changed*
  • Vapoursynth: changed sangnom.SangNomMod to sangnom.SangNom calls
Cu Selur
Old 22nd July 2021, 02:11   #3670  |  Link
RedDwarf1
RedDwarf Fan
I have been using this to quickly encode to HEVC with my Turing nVidia graphics card. The relatively, compared with other software, advanced options is a big reason why I use it.
However I have found that the encodes only come out with CAVLC and not CABAC entropy encoding. Can anyone tell me why this is so? Is it all that nVidia NVEnc can manage or is a setting that I am using incorrect? Is there a way to enable that to improve the compression/quality?
Thanks in advance for all input and help with this issue.
RedDwarf1 is offline   Reply With Quote
Old 23rd July 2021, 08:47   #3671  |  Link
Gravitator
The sample was taken from this post >https://forum.doom9.org/showpost.php...42&postcount=8
Video
ID in the original source medi : 4113 (0x1011)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference fra : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1 min 0 s
Bit rate mode : Variable
Bit rate : 17.9 Mb/s
Maximum bit rate : 38.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 2 176.592 FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.004
Stream size : 11.4 GiB
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
Is it better for a Hybrid to use information from "Frame rate" or "Original frame rate"? The first has sky-high rates and this leads to sky-high rates of coding time calculation in the program
Old 23rd July 2021, 11:03   #3672  |  Link
Sharc
[/SIZE]
Framerate Mode "Variable" is also suspicious
Old 30th July 2021, 19:32   #3673  |  Link
Selur
Selur's Avatar
In this case definitly 'Original frame rate', also if the source really is a Blu-ray vfr is wrong, so ignoring time codes when importing with Hybrid is probably a good idea too.
(wondering if 'email notification' will ever work again for subscriped threads,...)
Cu Selur
Old 3rd August 2021, 06:42   #3674  |  Link
Gravitator
Hydrid v2021.07.18.1
x265
Any change in the "Hierarchical M.E. range:" parameter will automatically save to the configuration profile.
Old 4th August 2021, 19:17   #3675  |  Link
Selur
Selur's Avatar
x265
Can't reproduce.
What I did:
  • start Hybrid
  • enable "x265->Motion->Motion estimation->Hierarchical M.E."
  • set "x265->Motion->Motion estimation->Hierarchical M.E." to "full/full/full"
  • closed Hybrid
  • opened Hybrid
-> settings are not automatically saved
Yes, if you save a 'Configuration' those settings are naturally saved, same if you save a global profile or similar.
Cu Selur
Old 4th August 2021, 20:03   #3676  |  Link
Gravitator
I apologize for the inaccuracy.
Apply the currently selected configuration "Ультра" - the parameter Hierarchical range ME range: 16/32/48 will be loaded > change to 16/16/16 > re-apply the currently selected configuration "Ультра" - the original 16/32/48 did not load.
It seems that this happens if the name is in Russian.
Old 5th August 2021, 17:02   #3677  |  Link
Selur
Selur's Avatar
Still can't reproduce this here.
What I did:
  • Start Hybrid
  • save a x265 configuration under "Ультра"
  • set "x265->Motion->Motion estimation->Hierarchical M.E. range" to "full/full/full"
  • change "Encoding mode" to "average bitrate (1-pass)"
  • apply the "Ультра" x265 configuration
-> "Encoding mode", "Hierarchical M.E." and the "Hierarchical M.E. range" values have all been properly reset.
Could it be that the profile isn't loaded at all?
May be some file system encoding vs Windows language coding issue?
-> no clue atm.
Cu Selur
Old 8th August 2021, 15:00   #3678  |  Link
Gravitator
The profile is loaded, but it is not possible to restart this setting again.
It seems that this problem also affects the font (it becomes very bold).
>Demo
Old 8th August 2021, 15:07   #3679  |  Link
Gravitator
Activates/Aktivates (In the info field when selecting encoders).
Video handling:
Allows you to select the video encoder that Hybrid will use:
available options:
- x264 (MPEG-4 AVC aka. H.264) activates the x264-Tab
- XviD (MPEG-4 ASP) activates the Xvid-Tab
- VPX activates the VPX-Tab
- CUDA H.264 (MPEG-4 AVC aka. H.264) activates the CUDA H.264-Tab (Windows only)
- x265 (MPEG-4 HEVC aka. H.265) aktivates x265-Tab
- DivX265 (MPEG-4 HEVC aka. H.265) aktivates DivX265-Tab
- Kvazaar (MPEG-4 HEVC aka. H.265) aktivates Kvazaar-Tab
- passthrough = copy input clip to output without any changes (no reencoding)
- ignore (no video processing, needed for audio only output)
Old 9th August 2021, 15:07   #3680  |  Link
Selur
Selur's Avatar
The too large font for 'Target mode&Co' is a bug with some tooltips which happend when switching to Qt6 -> will fix for the shown instances.
About the other 'bug', looking at the video:
- you apply "rskip"and the range ist set to 16,32,32
- you manually change the rante to 0,0,0
- "Ультра" and the range stays 16,32,32
- you manually change the range to 0,0,0
and then the cinfiguration is not applied (no clue, why)
-> tried the sam here, couldn't reproduce.
I got an idea,..
Ccould it be that you "Ультра" profile is an old profile which was created with an old Hybrid version and the profile simply doesn't contain any:
<HybridData value="true" name="hierarchicalME"/>
 <HybridData value="umh" name="hme1"/>
 <HybridData value="umh" name="hme4"/>
 <HybridData value="hex" name="hme6"/>
 <HybridData value="48" name="hmer1"/>
 <HybridData value="32" name="hmer4"/>
 <HybridData value="16" name="hmer6"/>
values?
If you open a profile with
Try:
1. applying you "Ультра" profile
2. saving it again
and see whether it now properly resets the setitng since the profile now contains the hme options,...
Cu Selur
