Old 25th January 2017, 17:11   #25561  |  Link
colinhunt
In-mux is not "supposedly" anything. I know what I'm doing, and when I say it is 100% compliant -- it is 100% compliant. Support is required by the spec -- so if there is a 3D player out there that doesn't support it THE PLAYER IS NOT COMPLIANT.
Apologies, I did not mean it like that. I was referring to the fact that the spec contains also optional, non-mandatory features that are not supported by all manufacturers. I have no idea whether in-mux stereo is a mandatory or an optional feature.
Frankly I think the SSIF format is ridiculous
Agreed.
Can you send me the MPLS of the playlist that is reversed?
Sure thing!
colinhunt is offline   Reply With Quote
Old 25th January 2017, 17:23   #25562  |  Link
jdobbs
Agreed.
Sure thing!
I looked at the MPLS. It is in the standard format in which the left view is in the main stream (AVC) portion of the video. So it shouldn't need to be swapped. I'll look at it and make sure I didn't screw up the standard configuration by trying to account for the unusual.
Website: www.jdobbs.net
Old 25th January 2017, 17:28   #25563  |  Link
colinhunt
Wait. I sent you the playlist from the movie-only backup that had its views reversed. Did you want the original's playlist instead? /confused
Old 25th January 2017, 17:29   #25564  |  Link
jdobbs
Yes. Also, can you send me the .meta file from the working folder?
Old 25th January 2017, 17:43   #25565  |  Link
colinhunt
I've run a few backups since the Hobbit so it's probably gone. I'll run Hobbit again using same settings.
Old 25th January 2017, 19:07   #25566  |  Link
jdobbs
Wrong meta file. I need the one entitled MUX_MOVIE_ONLY.meta. I should have been clearer.
Old 25th January 2017, 20:51   #25567  |  Link
jdobbs
@colinhunt
I just did several tests with 3D sources and output to ISO. It worked correctly every time. I'll look at it some more -- but it sure looks like it's working from here.
[Edit] Never mind. I was able to repeat it. I traced it and I see how it happens now. I'll get a fix in for the next release.
Old 25th January 2017, 20:59   #25568  |  Link
colinhunt
@colinhunt
Fantastic, thank you!
Old 26th January 2017, 07:23   #25569  |  Link
Lathe
Lathe's Avatar
Aww yeah - thank you! I'll start running tests immediately. Y'know, this might merit another donation from yours truly...
Whadaya mean 'Might'...???
Pay the man...
Lathe is offline   Reply With Quote
Old 26th January 2017, 10:59   #25570  |  Link
colinhunt
I've donated several times over the years. jdobbs even told me once not to donate again, but I'm guessing he was seriously distracted at the moment
Regardless, I was planning on donating when the movie-only 3D backup bug was squashed.
Old 27th January 2017, 02:34   #25571  |  Link
Lathe
Lathe's Avatar
Good man!
Yes, I actually do remember that...
Old 27th January 2017, 18:56   #25572  |  Link
jdobbs
BD Rebuilder v0.50.22
I have updated the first post of this thread with a link to the latest version of BD-RB (v0.50.22). Changes for this release:
- Added three more supported CODECs to the
  import capability (HFYU, LAGS, and ULY2).
  Automatic conversion to AVC will occur
  during import.
- Made changes to the way VFR is handled
  on import.  Now it is converted, during
  import, to CFR.  Avoids annoying desync,
  and makes handling much cleaner.
- Added new hidden option. IMPORT_VFR_FILM
  (see HIDDENOPTS.TXT) allows you to choose
  between importing VFR sources to FILM or
  VIDEO (23.976/29.97 fps) rates.
- Added new hidden option. IMPORT_VFR_SCAN
  (see HIDDENOPTS.TXT). Sometime MediaInfo
  does not catch a VFR source.  This option
  tells BD-RB to perform a complete scan of
  all frame timecodes in a source file to
  look for VFR. Especially useful when you
  can't get a file's audio to sync during
  import because VFR isn't detected. It can
  add a couple minutes to import time.
- Corrected an issue in which importing to
  an existing import folder could result in
  previous PSEUDO settings remaining even if
  they no longer apply.
- Fixed an issue that remained in v0.50.21
  in which a 3D source feature that is
  flagged for the base view to be the right
  picture was not carrying over when
  outputting to a non-ALTERNATE movie-only
  structure.  The result would be an apparent
  swapped left/right picture.
- Updated the included version of mkvextract
  and mkvmerge to v9.7.1.
- Other minor corrections and cosmetic fixes.
Old 27th January 2017, 20:29   #25573  |  Link
colinhunt
jdobbs is on fire! Happy dance! Thank you once again!
Old 27th January 2017, 20:34   #25574  |  Link
Sharc
@jdobbs
BD-RB 0.50.22. Trying to import any of the newly added 3 lossless formats (thanks!) throws the error:
[20:17:25] Importing: HFYU
- [20:17:27] Importing video file: (1 of 1)
  - Preparing AVI for processing...
  - Collecting audio/video streams from source...
  - Converting VFR source to CFR format...
[20:17:29]ERROR: Failed VFR conversion.  Aborted
The input is CFR 25fps (according to the capture settings and in line with what MediaInfo reports) so I wonder why DB-RB wants to convert VFR to CFR.
I assume you still have my 3 testclips. Did you try with these? Do I have to force a full timecode scan?
Old 27th January 2017, 21:39   #25575  |  Link
jdobbs
@jdobbs
Wierd. Run MediaInfo and see if it says the source is Variable Frame Rate. I'll import the examples you gave me and see what happens.
[Edit] DAMN!!! I had added a hidden option called IMPORT_VFR_FORCE for testing -- and I mistakenly defaulted it to ON. Damn. Damn. Damn. I'll fix it and post a new release in a little while. In the meantime you can set IMPORT_VFR_FORCE=0 in your INI file.
Old 27th January 2017, 21:54   #25576  |  Link
Sharc
No worry, no rush! Glad you found it
Old 27th January 2017, 22:05   #25577  |  Link
jdobbs
BD Rebuilder v0.50.23
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.50.23). Changes for this release:
January 27th, 2016 - v0.50.23
  during import.
- Corrected an error introduced in v0.50.22
  that forced VFR to CFR conversion during
  import.
If you attempt to download v0.50.22 after this post -- it will also have this update included.
Old 27th January 2017, 22:12   #25578  |  Link
jdobbs
I had to fix it fast. Otherwise every IMPORT would result in reencoding to a huge pseudo-BD folder.
Old 27th January 2017, 23:16   #25579  |  Link
colinhunt
Hobbit 3D disc 2 movie-only to .ISO backup job finished, and happy to report L/R views display correctly! Thank you jdobbs; donation made.
Old 28th January 2017, 00:08   #25580  |  Link
Sharc
Still no luck. This time I am getting for all 3 codecs the error
[00:04:04] Importing: ULY2
- [00:04:06] Importing video file: (1 of 1)
  - Scanning for Variable Frame Rate...
  - Converting codec to compatible format...
[00:04:09]ERROR: Failed codec conversion.  Aborted.
Edit:
Sorry, the problem was here: A typo in the .INI.
Never mind.
