Old 28th November 2010, 17:02   #41  |  Link
Diablo69_HUN
Hi there,
I sure do something wrong with Photoshop and Scenarist Designer because I installed both of them, but Photoshop File/Export menu is gray so I can't do anything with it. When I open a png file what I'd like to edit, I can see the File/Export/Scenarist Designer PS option but it's still gray and I can't do anything with it. In this case the png file is a "colour palette" not layers, so it's unable to edit. What should I have to do?
Diablo69_HUN is offline   Reply With Quote
Old 1st December 2010, 11:12   #42  |  Link
crl2007
Diablo69_HUN Most likely, you didn't install the software as it should.
Update*
I've updated the guide with a new menu edititng method.
crl2007 is offline   Reply With Quote
Old 21st December 2010, 12:09   #43  |  Link
tkozdras
Scenarist Designer
Hi there crl2007,
I don't know but I can't get this export dialog box of scenarist designer when I try to save the button exported to SD. when I hit export images it goes straight to save as window and I can only save scenarist designer file also asset folder is created but I need this export window with options to attach this pxml file with pallete colors I saved in bdedit
Thanks in advance for your help!
tkozdras is offline   Reply With Quote
Old 21st December 2010, 12:49   #44  |  Link
crl2007
Are you sure you are using my recommended Photoshop versions ?
Old 21st December 2010, 14:16   #45  |  Link
tkozdras
As far as I know yes. It's Photoshop CS2
Old 21st December 2010, 15:45   #46  |  Link
crl2007
Then you must have installed the plugin wrong.
Old 21st December 2010, 16:30   #47  |  Link
tkozdras
Ok, Thanks a lot.
Old 9th January 2011, 22:26   #48  |  Link
IVaN_000
I always thougth the BDMV\BACKUP folder had an exact copy of the BDMV one. So the following line confused me:
Originally Posted by crl2007 View Post
b) Copy the contents of the BDMV\BACKUP folder to BDMV folder. Now you'll have the original structure.
Why are they different?
IVaN_000 is offline   Reply With Quote
Old 9th January 2011, 22:32   #49  |  Link
crl2007
When you rip your disc to HDD, anydvd hd or dvdfab modifies some java signatures and some other things, like removing UOP, region codes etc.
Old 10th January 2011, 00:01   #50  |  Link
IVaN_000
I thought the BACKUP folder was a way to have a copy of important files, in case of a disc scratch (like .BUP files on DVD). So now I guess it's not. Because if you have a scratch in your backup and the player can't read a file, it would search for a backup of files that don't correspond to the backup but to the original disc.
Old 2nd April 2011, 10:31   #51  |  Link
PurpleMan
In this cases you'll have to check the *.class files with a hex editor. In your archive, the subtitles streams are declared in h.class.
Originally Posted by Diablo69_HUN View Post
Maybe I do something wrong, but when I change the name of the stream (for example: Spanish => Magyarr), the disc doesn't work. When I write back the original, it's okay. What could be the problem?
The problem: On some discs the class files are hash-signed, so if you change even 1 bit in them (hex editor to change language text, for instance) - the menu will stop working because the hash signature won't match. The signatures for each class file are stored inside the jar (META-INF\SIG-BD00.RSA).
The solution: Make all the changes you want, then pack the entire thing to an ISO. Mount that ISO with your favorite virtual drive software, then run AnyDVD on that virtual drive. After the drive is ready for use (anydvd finished scanning it) - copy the content from the virtual drive to a new iso or directory.
This works because anydvd recalculates all the hashes of class files in all the jars when readying a disc for use.
Enjoy
PurpleMan is offline   Reply With Quote
Old 2nd April 2011, 10:37   #52  |  Link
crl2007
This solution was posted in the guide right from the start. It's the only working one.
Old 2nd April 2011, 11:49   #53  |  Link
TSX1
How can I remove those annoying FBI warnings from the start-up of the movie?
TSX1 is offline   Reply With Quote
Old 2nd April 2011, 14:46   #54  |  Link
crl2007
http://forum.doom9.org/showthread.ph...ght=multiavchd Read here.
Old 1st May 2011, 18:31   #55  |  Link
warnerbros86
warnerbros86's Avatar
Editing Blu-ray menu button commands!!
Hello crl2007,
Thanks for the great guide, it's been so useful for me, I'm working on my Resident Evil 3D and trying to convert it from BD50 to BD25, but I want to edit the menu button commands (IGS menu) so when I press play movie, it will read the file I assign, not the default SSIF file which can't be put onto my 25 BD disc!!
Could you please help me in this? It will be great appreciated...
warnerbros86 is offline   Reply With Quote
Old 1st May 2011, 22:32   #56  |  Link
crl2007
The menu links point to certain mpls files. You can edit those mpls with bdedit and just remove the SSIF links from them. Or you can just delete the SSIF files and only choose to play the 2D movie in the menu. But you should try BD Rebuilder. I don't know if it has a 3D backup option, but it's the best software for BD50 to 25 conversion.
Old 2nd May 2011, 11:28   #57  |  Link
warnerbros86
Thanks a lot crl2007,
BD Rebuilder has no 3D support, I'm gonna try editing the mpls files and see what happens then get back to you,
Cheers
Old 7th May 2011, 18:36   #58  |  Link
warnerbros86
Hello again crl0007,
I've tried many times to know how to edit those mpls files but I didn't know how to do it, forgive my stupidity, could you please help me out, what am I supposed to edit exactly and where should I go?!
This is what I've got, it's Piranha Blu-ray 3D
Thanks in advance!
Old 7th May 2011, 18:44   #59  |  Link
crl2007
It's too hard to explain if you don't have knowledge of the BD structure.
Old 7th May 2011, 19:04   #60  |  Link
warnerbros86
Any links to read or a guide to read, I do understand the general concept but I have some difficulties to do the coding things
Thanks!
