Old 24th June 2009, 23:19   #1  |  Link
cerjy
1080i MeGUI to 720p/1080p/anything that isnt 50gb and interlaced =D!
alright, i've been meaning to post this here for awhile and i have no idea if this is the right section but we'll go with it since megui is what im using.
about 6months ago i bought the tom petty live at soundstage bluray, i used the ps3 to copy the bluray files to my pc, i stripped the AACS or whatever-drm-bluray-uses-nowdays off it, and have 3 m2ts files. 15gb,15gb and 8gb.
well, ive been wanting to convert them down to 720p since a) i dislike interlacing, b) i'd like to have a smaller copy to archive.
ive read megui can supposidly do this, so i read some tutorials and whatnot.
no matter what settings i put in the avs script, the output video is TRASH. and i cant figure out why. it's screaming..
"Your AviSynth clip is is the wrong colorspace, 1610612740.
The colorspace should by YV12. Do you want me to add ConvertToYV12() to the end of your script?"
i thought that might be the problem. but i really am clueless here, heres the mediainfo text of the bluray file im trying to convert from. perhaps theres an answer in it.
Format : BDAV
Format/Info : BluRay Video
File size : 8.05 GiB
Duration : 34mn 11s
Overall bit rate : 33.7 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Duration : 34mn 9s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA
Duration : 34mn 11s
Bit rate mode : Variable
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
im using megui .3.1.1046, updated all the little addons.
any help would be apperciated verymuch.
also, heres a ss of what the quality looks like from a 1080i source. its pretty scary.
http://cerjturb.net/vlcsnap-3816740.JPG
cerjy is offline   Reply With Quote
Old 24th June 2009, 23:32   #2  |  Link
cerjy
ALRIGHT. SORRY GUYS. i shouldve read the entire tutorial rather than skimming, i had to set the bitrate. my 8gb file was being compressed to 200mb. perhaps that could explain said bad quality? lolwhoops! =D!
i converted it with full bitrate and ohgawd, its hawt. i suppose ill change hte subject here, does anyone have an idea why these bluray interlaced videos show very few signs of interlacing like you see on dvds? i figure it has something to do with framerate, but id like to know the details.
thanksbois!
1080i, 720p, convert, error, megui
