Old 15th August 2014, 18:22   #1261  |  Link
LigH
LigH's Avatar
Don't do that. After using DirectShowSource(..., convertfps=true ...), the previously existing field/frame structure will be destroyed so that no deinterlacer will work anymore. Serious AviSynth users will always try to prefer native AviSynth source plugins, and avoid norm conversions if applicable. Most modern HD TV sets will adapt to all available TV norms.
New German Gleitz board
Old 16th August 2014, 11:34   #1262  |  Link
Okeeffe1881
Okeeffe1881's Avatar
Can you please tell me in more detail, or link with more information.
Thanks
Okeeffe1881 is offline   Reply With Quote
Old 16th August 2014, 16:03   #1263  |  Link
LigH
LigH's Avatar
If I knew you would understand German, I would link you to "exotisches Interlacing" by scharfis_brain; unfortunately, I don't know which similarly comprehensive explanations of interlacing and good or bad norm conversions exist in English... In brief: If you really have regular interlacing you want to remove, ensure that your source will be read as exactly as possible; DirectShow cannot guarantee that, there may be decoders which already try to "deinterlace" with very bad-because-fast algorithms...
DirectShowSource is disfavoured by AviSynth purists for many years now. Hard to miss so many threads about the disadvantages of a source filter relying on unreliable sets of filters every user may have a different set of and different settings of.
Preferable alternatives should be: L-SMASH Works as free-of-charge software-only solution, or DGDecNV as unexpensive interface to the hardware decoder chip of Nvidia cards generation 8+.
Old 11th September 2014, 13:59   #1264  |  Link
PeterYu
The cArray's size is 4 times the block number not equal to block number.
"cArray = (int *)_aligned_malloc((((vi.width+xhalf)>>xshift)+1)*(((vi.height+yhalf)>>yshift)+1)*4*sizeof(int), 16);"
in TFM.cpp, corresponding in TFMYV12.cpp, TFMYUY2.cpp
"cArray[temp1+box1+0] += sum;
cArray[temp1+box2+1] += sum;
cArray[temp2+box1+2] += sum;
cArray[temp2+box2+3] += sum;"
Can someone please tell me why?
Thanks!
PeterYu is offline   Reply With Quote
Old 11th September 2014, 15:38   #1265  |  Link
@ Ligh,
Here's the best I can do (EDIT: English Translation) for "'exotisches Interlacing' by scharfis_brain" (exotic Interlacing),
Probably a temporary link:
EDIT: LINK REMOVED:
Several links included in zip (120KB).
EDIT: See DATA Folder via Mediafire Link in sig below this post.
Will now be permanently available.
Old 11th September 2014, 19:58   #1266  |  Link
LigH
LigH's Avatar
Great, I am impressed how much leisure time you had...
Old 11th September 2014, 20:50   #1267  |  Link
I did it about 2 years ago, I Asked S_B if he minded if I posted it (PM or post in thread, cant remember), never got a reply so left it.
Hardest part was aligning all of the symbols and letters representing frames, they were all over the place after Google translation.
Corrected what I could but was lost for the meaning of some sentences.
Old 19th September 2014, 16:25   #1268  |  Link
Exotic Interlacing (English translation) by Scharfis_Brain will now be available via my Mediafire account (in sig below this post) in the DATA
folder. Has had 57 downloads so is quite popular, perhaps a good candidate for the Wiki if someone could correct
any mis-translations and fix the sentences that I could not figure out.
Link deleted in post #1266 above.
Old 17th October 2014, 19:17   #1269  |  Link
turbojet
Would anyone be so kind as to add dgi support to tfm's d2v parameter? It would speed things up and overcome some potential ivtc issues.
I don't want to minimize the workload but there's only a few instances of d2v outside of tfmd2v.cpp. I don't think vast c++ knowledge is needed, just a bit more than I have which is almost none.
If something is needed feel free to ask. TIA.
PC: FX-8320 GTS250 HTPC: G1610 GTX650
PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0
Old 17th October 2014, 19:49   #1270  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
+1 for DGdecNV support.
I just emailed tritical and he currently has no plans to update TFM himself.
I'll ask to see if ex-Neuron knows much to help with this.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 27th July 2015, 00:54   #1271  |  Link
Seedmanc
Doesn't 100fps.com do a better job at explaining interlacing? At least compared to autotranslation from a foreign language that we have here.
Seedmanc is offline   Reply With Quote
Old 27th July 2015, 07:08   #1272  |  Link
ChiDragon
ChiDragon's Avatar
The "exotic interlacing" page explains norm conversions, not just interlacing. And 100fps.com misdiagnoses some things like improper 4:2:0 conversion.
ChiDragon is offline   Reply With Quote
Old 13th September 2015, 06:44   #1273  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
DGdecNV support aside, any chance of a modern update with something newer then 2003?
Avisynth Info Tool 1.3.1 gives error: R6034
C:\AVS\AVS_Ver\AVS260_MT\plugins\TIVTC.dll
Timestamp: January 17, 2008, 14:01:48
MD5 Hash: 0416E3D06AD70685C6ECE448713928AE
DLL Dependencies: KERNEL32.dll
Linker version: 7.10 (VS2003)
Plugin version: AVS 2.5 Plugin
FILEVERSION: 1.0.5.0
PRODUCTVERSION: 1.0.5.0
Language: English (United States)
Comments:
CompanyName:
FileDescription: TIVTC v1.0.5 for Avisynth 2.5.x
FileVersion: 1, 0, 5, 0
ProductVersion: 1, 0, 5, 0
InternalName:
LegalCopyright: Copyright (C) 2004-2008 Kevin Stone
LegalTrademarks:
OriginalFilename:
PrivateBuild:
ProductName:
SpecialBuild:
I got every version of MSVS redistributables installed. Error only happens when using AIT but no errors while actually using it in anything else.
Old 13th September 2015, 09:29   #1274  |  Link
Groucho2004
Please try this version of AIT.
Old 13th September 2015, 09:33   #1275  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Still has r6034 error.
Old 13th September 2015, 09:38   #1276  |  Link
Groucho2004
Please post both AIT logs. I can't reproduce this. Have you tried with just that DLL in your auto-load directory?
Old 13th September 2015, 10:54   #1277  |  Link
Groucho2004
Here it is built with VC10. You'll need the runtimes for VC2010.
Old 13th September 2015, 10:55   #1278  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
I got every version of MSVS redistributables installed. Error only happens when using AIT but no errors while actually using it in anything else.[/QUOTE]
So I isolated and it turns it really wasn't tivtc. It was "toon".
I even downloaded and re-installed the redist but it just went through so quickly I don't know if it actually installed.
Avisynth info log: http://www.mediafire.com/view/ajzlcw...isynthInfo.txt
Full plugin info: http://www.mediafire.com/view/971sdh...PluginInfo.txt
Isolated DLL's for just Toon + AwarpSharp2: http://www.mediafire.com/view/c77iea...o_isolated.txt
This is the one I had downloaded, Toon v1.1
http://avisynth.nl/index.php/Toon
Old 13th September 2015, 10:58   #1279  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Thanks for the update, though!
Old 7th June 2016, 22:31   #1280  |  Link
bilditup1
bilditup1's Avatar
Hmm. appears to be dead now - do you think you could put this up somewhere again, please?
bilditup1 is offline   Reply With Quote
tdeint, tivtc
