Old 2nd December 2007, 23:16   #201  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by vlada View Post
Anyway I have another problem. I'm not sure if MediaInfo is supposed to handle elemantary streams, but I think it usually does. I have a h.264 stream demuxed from AVCHD camcorder. MediaInfo 0.7.5.5 reports it as an AC3 audio. A sample can be downloaded here (7 MB).
Yes it can handle "elementary" streams...
MediaInfo v0.7.5.3 reports your sample as being: -
General #0
Complete name        : C:\Documents and Settings\SeeMoreDigital\Desktop\video5.264
Format               : AVC
Format/Info          : Advanced Video Codec
Format/Family        : AVC
File size            : 7.27 MiB
Video #0
Codec                : AVC
Codec/Info           : MPEG-4 AVC
Codec profile        : High@L4.0
Width                : 1440 pixels
Height               : 1088 pixels
Aspect ratio         : 4/3
PixelAspectRatio     : 1.000
DisplayAspectRatio   : 1.324
....and yes, MediaInfo v0.7.5.5 reports this: -
General #0
Format               : AC3
Format/Info          : Audio Coding 3
PlayTime             : 1mn 59s
Bit rate             : 512 Kbps
Audio #0
Codec                : AC3
Bit rate             : 512 Kbps
Bit rate mode        : CBR
Channel(s)           : 3 channels
Channel positions    : L C R
Cheers
Old 3rd December 2007, 01:08   #202  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
A friend of mine wrote a Python wrapper for the .dll so it is solved. I didn't have the time to dive into the code yet, I just verified it works. If anyone's interested in it, let me know.
Sure!
Old 8th December 2007, 12:50   #203  |  Link
vlada
So here it is: http://www.sendspace.com/file/ks1hei
As my friend told me it might not be fully functional, because he's never programmed anything in Python before. I'll also post it as an attachment, I hope somebody will approve it. It's only 4kB.
From what I tested so far everything seems to work correctly. I removed some comments he wrote me in Czech and translated some of them to English.
vlada is offline   Reply With Quote
Old 9th December 2007, 22:20   #204  |  Link
vlada
Zenitram> I have a TS sample, where MediaInfo can't detect any streams. It has one h.264 video track and 4 AC3 audio tracks. Are you interested in that file?
Old 18th December 2007, 21:12   #205  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Does anybody know why I get always that kind of garbage with every file on Vista?
Old 21st December 2007, 01:40   #206  |  Link
vlada
Atak_Snajpera
I can confirm this too with 0.7.5.6. Version 0.7.5.0 works correctly. (I use Czech WinXP)
Old 21st December 2007, 16:40   #207  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
try this build...
Old 21st December 2007, 16:44   #208  |  Link
Kurtnoise
Kurtnoise's Avatar
sure...upload a sample please. Same thing for the raw AVC (the link to download the file is dead).
Old 23rd December 2007, 20:55   #209  |  Link
Atak_Snajpera
Thanks Kurtnoise13 for fixed version
Old 1st January 2008, 20:09   #210  |  Link
vlada
The problematic .TS file is uploaded at http://www.sendspace.com/file/xjfw21. I think the problem with AVC stream is general, because it happend to me with more files. But if you can't reproduce it I will reupload the sample again.
Also I have some features requests for MediaInfo. I'm now working on a program, which uses MediaInfo library to get information about media files and then displays the needed modification to transcode it to DVD-Video. I also plan to add more output formats and maybe some day even make it a simple to use transcoding tool.
Here is the problem I currently have:
I need to know video compression. I need to know if it is MPEG-1/2/4 ASP or AVC. Or any other compression format. I use the "codec/family" information to get the compression, but it only works for AVI. In other containers the video compression is found under "codec". I could workaround it, but I think this inconsistency should be fixed in MediaInfo.
Second problem is, that for Matroska files the DLL only displays Mk. Again I could workaround it very simply, but I think I should mention it.
Also I'd like to ask you if it is possible to indicate some more informations about H.264. For example B-frames, CABAC etc. Is it possible at all?
Also I get much more information from a RAW AVC stream then from the same video muxed in MKV. Why?
Old 2nd January 2008, 06:20   #211  |  Link
Kurtnoise
Kurtnoise's Avatar
thanks...I'll try.
Should be easy to tweak this...
It's possible and it's planned afaik...but I've no deadline on that.
such as ? mkv parsing has been rewritten recently. So, several things are missing.
Old 2nd January 2008, 16:48   #212  |  Link
vlada
For example used profile (Baseline, Main, High etc.)
Old 2nd January 2008, 20:37   #213  |  Link
Kurtnoise
Kurtnoise's Avatar
with which matroska writer tools ? (x264/xvid_encraw-mkvtoolnix-gdsmux-gstreamer-handrake-avidemux-avimux_gui)
Old 3rd January 2008, 01:25   #214  |  Link
vlada
O.K., so I'll be more specific. This what I get from an MKV:
Hlavní #0
Celý název a cesta   : C:\_avchd\video4.mkv
Formát               : Mk
Velikost souboru     : 16.2 MiB
Hrací čas            : 22s 880ms
Bit rate             : 5957 Kbps
Encoded date         : UTC 2007-08-11 16:43:56
Použitý software     : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Enkódoval            : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Codec                : MPEG-4 AVC
Codec/Info           : MPEG4 ISO advanced profile
Bit rate             : 5833 Kbps
Šířka                : 1440pixely
Výška                : 1080pixely
Poměr stran          : 16/9
Frame rate           : 25.000 fps
The SW used to create the video is clear. Sorry for the Czech description, but even if I switch MediaInfo to English, the text remains in Czech. But it should be clear what the parameters are.
Now the same file after demuxing in MediaInfo 0.7.5.6:
Hlavní #0
Celý název a cesta   : C:\_avchd\video4.264
And now the same file in 0.7.5.0 (CLI, but it would be the same with GUI version):
General #0
Complete name        : C:\_avchd\video4.264
Format               : AVC
Format/Family        : AVC
File size            : 16.2 MiB
Video #0
Codec                : AVC
Width                : 1440 pixels
Aspect ratio         : 4/3
So first of all there is a bug in newer versions of MediaInfo that they don't read RAW AVC streams. With the older version 0.7.5.0 there are no problems. Also as you can see, I get different information about the video stream when it is demuxed. From a RAW AVC stream I get the information about profile, but not bitrate, framerate and time. Neuron2 says it should be possible to read framerate information from an AVC stream.
Also aspect ratio doesn't match. Any idea why?
If you can't reproduce it and want to see this sample video, let me know and I'll upload it.
Last edited by vlada; 3rd January 2008 at 18:30. Reason: Finished uncomplete sentence
Old 4th January 2008, 20:32   #215  |  Link
Kurtnoise
Kurtnoise's Avatar
mmh, I just tried to parse a raw AVC stream on my side with the last library and I got all infos...could you upload a sample of your video4.mkv file.
Old 4th January 2008, 23:37   #216  |  Link
vlada
The sample is at http://www.sendspace.com/file/gpb5ul. It is a 17MB clip from Panasonic AVCHD camcorder muxed into MKV (only video).
Old 5th January 2008, 21:28   #217  |  Link
Kurtnoise
Kurtnoise's Avatar
I've no idea why the parsing fails...I'll ask to Zenitram to look at this more carefully.
btw, I've made a fix for your 2nd problem from the post #211.
Old 6th January 2008, 12:00   #218  |  Link
vlada
Thanks a lot for your great feedback.
Old 23rd January 2008, 21:22   #219  |  Link
Kurtnoise
Kurtnoise's Avatar
@vlada: some new stuff in the incoming release...
General #0
Complete name : D:\Tor_\Script ED new_h264.mkv
Format : Matroska
File size : 5.11 MiB
PlayTime : 36s 959ms
Bit rate : 1160 Kbps
Encoded date : UTC 2008-01-23 20:13:57
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Codec : MPEG-4 AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec profile : High@L5.1
PlayTime : 36s 920ms
Bit rate : 1107 Kbps
Width : 640 pixels
Height : 336 pixels
Display Aspect ratio : 1.905
Chroma : 4:2:0
Interlacement : Progressive
Writing library : x264 - core 57 svn-699C
Old 23rd January 2008, 21:31   #220  |  Link
vlada
That's great thanks a lot. I hope to get back to coding my application after a 2-weeks break. It is great news that I'll be able to get more detailed info.
