Old 28th October 2019, 05:15   #14861  |  Link
SquallMX
Special SeeD
Seamless branching for new 4K titles seems to be broken. Audio goes out of sync, subtitles are also affected.
SquallMX is offline   Reply With Quote
Old 28th October 2019, 08:46   #14862  |  Link
l00t
Where's my loot?
Not just for new titles, but for almost every seamless branched UHD discs. For these it is recommended to use DGDecNV or MakeMKV.
l00t is offline   Reply With Quote
Old 28th October 2019, 16:13   #14863  |  Link
SquallMX
Special SeeD
Yeah, I using MakeMKV as a workaround, unfortunately ac3to also fails when transcoding TrueHD to WAV/FLAC if the MKV was created from a Seamless Branched disc using MakeMKV.
Old 28th October 2019, 16:24   #14864  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I think you should create an issue at http://bugs.madshi.net/main_page.php, madshi has fixed critical bugs even if the application is not actively developed.
Old 28th October 2019, 16:37   #14865  |  Link
redbtn
redbtn's Avatar
It's already there over 1.5 years
http://bugs.madshi.net/view.php?id=542
redbtn is offline   Reply With Quote
Old 28th October 2019, 16:50   #14866  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Uh, doesn't look too good then
I wonder if ffmpeg can handle such streams joined by MakeMKV?
Old 28th October 2019, 16:59   #14867  |  Link
redbtn
redbtn's Avatar
I've heard that DGDecNV can demux this correctly, but I don't have it to check.
It fails with error or output flac doesn't sync with video?
Old 28th October 2019, 17:47   #14868  |  Link
videoh
The latest version can indeed correctly demux all elementary streams, subtitles, and chapters in sync with the video. It's been tested on several disks, such as the UHD version of Cars 2 (which has boatloads of M2TS files in the playlist). If any other streams are not handled correctly please let us know and they'll be addressed straight away. Here is an interesting thread on the matter:
http://rationalqm.us/board/viewtopic.php?f=8&t=780
wherein Bullwinkle advised how to do this sync correction correctly. Possibly madshi is interested in his HW offerings these days.
Old 28th October 2019, 17:51   #14869  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by videoh View Post
The latest version can indeed correctly demux all streams in sync with the video. I have tested it on several disks, such as Cars 2. If any other streams are not handled correctly please let me know and I will address them straight away. Here is an interesting thread on the matter:
Hehe, must have been the best 15 bucks I ever spent that I put in the DGDecNV license
Old 28th October 2019, 18:34   #14870  |  Link
videoh
DGDecNV wants to thank you for all your great contributions over the years, Boulder, and for your contributions to the entire video community!
Old 28th October 2019, 19:21   #14871  |  Link
videoh
We could make a stand-alone demuxer that doesn't require an nVidia card.
Old 28th October 2019, 19:43   #14872  |  Link
l00t
Where's my loot?
It's definitely worth buying
That would be like Christmas
Old 29th October 2019, 02:23   #14873  |  Link
videoh
Ordering my Santa outfit.
We can make it freeware, why not? DGDemux sounds good. Take a bluray/uhd playlist and deliver all elementary streams, subtitles, and chapters in sync.
MakeMKV uses container timestamps to fix things up AFAIK, for ES demuxing you are in trouble.
Old 29th October 2019, 10:24   #14874  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Amazing
Old 29th October 2019, 16:07   #14875  |  Link
SquallMX
Special SeeD
It fails with an 'Lossless Check Failed - Expected XX, Calculated YY' error, usually around a seamless branching scene.
Old 29th October 2019, 16:53   #14876  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I think those errors are not an issue, they've always been there as far as I remember.
Old 29th October 2019, 17:01   #14877  |  Link
redbtn
redbtn's Avatar
It happens often when I convert DTS XXL to FLAC. But with TrueHD I didn't notice it. And of course any not lossless format gives this messages.
Old 30th October 2019, 17:26   #14878  |  Link
SquallMX
Special SeeD
I think MakeMKV is not fixing the truehd audio properly.
TrueHD audio from seamless branching title created by DGIndexNV to FLAC conversion works OK
TrueHD audio from seamless branching title created by eac3to to FLAC conversion works OK but is out of sync
TrueHD audio from seamless branching title created by MakeMKV to FLAC conversion fails
Looks like DGIndexNV is the best tool for the job,
who would have thought that, best 15 dollars I've ever spent.
Old 30th October 2019, 18:02   #14879  |  Link
videoh
Are you using the TrueHD stream or its embedded AC3?
Looks like I got lucky, because I don't even do gap processing for TrueHD (although I do for the embedded AC3). It appears to not be necessary for TrueHD, and perhaps the problem for eac3to is that it does this processing when not needed. The eac3to algorithm does not look good to me (deleting duplicated audio frames AFAIK). Can you try with that -no2ndpass thingie (assuming you are using the TrueHD and not its embedded AC3)?
Old 31st October 2019, 02:30   #14880  |  Link
videoh
Originally Posted by SeeMoreDigital View Post
Amazing
He he, now I have to deliver it. No way I can let you down.
Created the project today and started coding... Whee!
eac3to
