Old 24th September 2013, 09:44   #1  |  Link
whitezombie455
MeGUI encountered a fatal error...???
Hi there, I am trying to continue using MeGUI but for some reason it is now giving me a problem. When I load an AVS Script I receive a Fatal error: "MeGUI encountered a fatal error and may not be able to proceed. Reason: Object reference not set to an instance of an object".
Here is the simple AVS Script I am trying to load:
DirectShowSource("C:\Users\******\Downloads\FIX\NAME OF TITLE.mkv", fps=29.970)
ConvertToYV12()
Now idk why it is doing this as it was working perfectly fine yesterday without issue and now it is doing this... Anyone know what I can do to fix this???
P.S. I have tried reinstalling the Microsoft .Net Framework 3.5 and 4.5 but it didn't solve the issue.
whitezombie455 is offline
Old 24th September 2013, 10:42   #2  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
This is the real path of your input file ?
DirectShowSource relies on your A/V directshow filters installed on your machine...Are you able to play this script in Virtualdub or any decent dshow player like mpc-hc ?
It might be great for you to use FFVideoSource instead of DirectShowSource for mkv files...
Kurtnoise is offline
Old 24th September 2013, 17:58   #3  |  Link
Zathor
And please post your full log file.
Zathor is offline
Old 24th September 2013, 18:25   #4  |  Link
Closed pending rule 6 clarification from OP.
Guest is offline
avs, error, fatal error, issues, megui
