Old 15th March 2012, 23:25   #341  |  Link
SubJunk
Thanks a lot for these updates, SET. I find your builds are the best ones!
It seems that env->GetMTMode() is missing, is there a reason for this? I have a plugin that relies on that function
SubJunk is offline   Reply With Quote
Old 18th March 2012, 15:36   #342  |  Link
GMJCZP
GMJCZP's Avatar
Originally Posted by GMJCZP View Post
Please, I need an answer!
I had to go back to version 2.5.8 MT. I can use there are the VirtualDub fliters.
Any comments or suggestions?
GMJCZP is offline   Reply With Quote
Old 18th March 2012, 22:39   #343  |  Link
pbristow
pbristow's Avatar
With this version of Avisynth yesterday I tried to load a plugin for VirtualDub with LoadVirtualDubPlugin the way I've always done and then VirtualDubMod crashes, what is that?
In 2.5.8 MT I could perfectly.
I'll be doing something wrong or need to install anything?
Hi GMJCZP,
To get any answers, you'll need to supply a bit more information, such as what specific plugin you're trying to load and exatcly how (the simplest and best way to do this is to post the exact script you're using), what exact symptoms you get (e.g. any error messages that occur before the crash), what other plugins have you tried and did they behave the same way, etc. Otherwise, the only suggestion anyone can reasonably make is "investigate the problem".
Also, you need to post the question in the Usage forum, not here in the Development forum.
Good luck!
pbristow is offline   Reply With Quote
Old 20th March 2012, 04:04   #344  |  Link
GMJCZP
GMJCZP's Avatar
Originally Posted by pbristow View Post
Hi GMJCZP,
Good luck!
Sorry if use this thread.
The problem is straightforward: All plugin Virtualdub I try to carry this latest version of Avisynth, to boot, for example, VirtualDubMod, I get the error message that this program will close.
That's all.
Old 31st March 2012, 20:12   #345  |  Link
SEt
Update:
1) Updated to CVS, so everyone can try new interfaces: http://forum.doom9.org/showthread.ph...92#post1567792
2) Some bugfixes/improvements, mostly exceptions-related.
3) VirtualDub plugins now work again.
4) Changed compiler to VS2010 - something could break due to this.
SubJunk, it's not missing - just moved in tables due to 2.6 stuff. Rebuild your plugin with new headers and it should work fine.
SEt is offline   Reply With Quote
Old 31st March 2012, 20:31   #346  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, I'll download and start using the new build right away.
Old 31st March 2012, 22:09   #347  |  Link
SubJunk
Thanks a lot for the new release!
If I rebuild with the new headers is there a risk of 2.5 incompatibility? Do you think 2.6 will eventually require most 2.5.8 plugins to recompile?
Old 31st March 2012, 22:38   #348  |  Link
SEt
SubJunk, since it uses MT functions it's already incompatible with regular Avisynth, it will be incompatible with 2.5.8 MT due to new placement of MT functions, but there is nothing bad in it - 2.5.8 shouldn't be used anyway. If MT functions are called conditionally - you can still build it and maintain compatibility with 2.5.
2.6 will likely support 2.5 plugins without changes, but I hope they'll be recompiled if just to remove the ancient bad code that is compiled into all plugins and the main reason of "instability" of MT Avisynth mode.
Old 31st March 2012, 23:53   #349  |  Link
SubJunk
OK, thanks for the explanation
Old 1st April 2012, 04:26   #350  |  Link
GMJCZP
GMJCZP's Avatar
Thanks a lot.
Old 2nd April 2012, 13:50   #351  |  Link
ryrynz
ryrynz's Avatar
Yeah, this is very great news. Avisynth development moves at such a slow pace is great to see new revisions.
Everything's working well here with no stability issues. Performance might even be slightly higher judging from the quick test I did. Thanks to you, IanB and everyone else involved.
Old 2nd April 2012, 14:25   #352  |  Link
SEt
Oh, I forgot one minor thing in change log:
5) This version accepts brackets-less function calls like official Avisynth.
Old 2nd April 2012, 21:13   #353  |  Link
SubJunk
Working well for me too so far
Old 3rd April 2012, 06:56   #354  |  Link
GMJCZP
GMJCZP's Avatar
I tried to load the VirtualDub filter "MSUSmartSharpen", and although not hung up VirtualDubMod, I just could not carry it, gave me error, as if the configuration that before worked now does not work.
Old 3rd April 2012, 10:06   #355  |  Link
tormento
Acid fr0g
tormento's Avatar
Newer revision works fine and solved some seeking problem too.
Thank you
@turment on Telegram
Old 3rd April 2012, 11:49   #356  |  Link
hydra3333
Fresh Win7-64 install, i7-3820 16Gb. Copied 2.6 over the top of tsp's 2.5.7, used VIT functions for QTGMC plus loaded a few other relevant ones for a vanilla QTGMC script with DGindex. Opened script into avs2yuv, and it crashed with no avisynth message. Put 2.5.7 back, backed out to use non-VIT functions in same script and presto, it worked.
In hindsight maybe because I left (only) tsp's "MT" DLLs in the plugins folder and they autoloaded ?
Old 3rd April 2012, 17:46   #357  |  Link
SEt
Minor update:
1) Some more VirtualDub plugins compatibility fixes.
2) Issue with Overlay and YV24.
hydra3333, MT dlls are not supported. And as base you should start from 2.6 alpha or 2.5.8, not earlier.
Old 3rd April 2012, 19:27   #358  |  Link
titlis
Sorry but the latest mt build keep crashing upon loading avspmod.
Other builds work properly.
titlis is offline   Reply With Quote
Old 3rd April 2012, 19:48   #359  |  Link
SEt
Can't reproduce.
Latest as 2012.04.03 or 2012.03.31?
Old 3rd April 2012, 19:56   #360  |  Link
titlis
Originally Posted by SEt View Post
Can't reproduce.
2012.04.03
I'm using AvsPmod 2.2.1
