20th January 2009, 03:39 | #6002 | Link | |
internal mkv splitter don't load any embedded text subs with some files, but haali's splitter does. |
20th January 2009, 05:13 | #6003 | Link |
Anybody else getting a thin grey line at the very bottom of some of their videos while using Beliyaal's version 6?
XP SP3 Nvidia 8400 GS 181.2 Just the MPC decoder on VMR9 Renderless Lockback buffer enabled, 3D surfaces Last edited by neoufo51; 20th January 2009 at 07:43. |
20th January 2009, 06:56 | #6004 | Link |
I've tried the Beliyaal's version 6 - it seems I need to add an audio delay of approximately -80 milliseconds to keep A/V sync. Hopefully this will be fixed!
Also, it seems DScaler5 (mpeg2 decoder) doesn't work very well with it - I get flashes of different video frames that get randomly inserted during playback. Very odd. I don't know if this is specific to Beliyaal or the recent MPC-HC releases. All I know is that MPC 1.0.11.0 works fine with it. Oh well! I forgot to add: This is on Windows XP SP3 with all updates. NVIDIA 8800GT, 178.24 drivers. DScaler5 5.008 with IVTC patch. Lockback buffer enabled. VMR9, VMR9 mixing mode, 3D surfaces. It doesn't matter if Direct3D Fullscreen is enabled or not. YUV Mixing setting doesn't matter. It doesn't matter if alternative vsyns is enabled or not. Last edited by Rectal Prolapse; 20th January 2009 at 07:11. |
20th January 2009, 10:51 | #6005 | Link |
MPC-BE DEV
Media Player Classic HomeCinema (x86/x64), svn 981
Supported languages: CN, CZ, DE, ES, FR, HU, IT, KR, PL, RU, SK, TR, UA Changes log Fix : seek range (show current position more than the end).
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. Last edited by alexins; 24th January 2009 at 02:04. |
20th January 2009, 11:36 | #6006 | Link | |
MPC-HC 2.2.1 Last edited by clsid; 20th January 2009 at 11:39. |
20th January 2009, 16:20 | #6007 | Link |
MPC and MPC-HC have an issue playing an .mkv video containing :
- one H264 video track ; - one AC3 stereo audio track ; - one SRT subtitle file. Only the audio track is found and its duration is wrong. Other player (MPlayer, VLC) play the same file correctly. I replaced the AC3 track with an AAC-Hev2 and now both versions of MPC can play the file. |
20th January 2009, 17:13 | #6009 | Link | |
MPC-HC Project Manager
It is probably your sample(which in that case you should post part of for testing) or as Kurtnoise13 said your AC3 decoder. So what AC3 decoder are you using? |
20th January 2009, 17:54 | #6010 | Link |
It's kinda weird.
I installed Haali Media Splitter and the problem went away. Then, I uninstalled it but MPC can still play the file and all its tracks If my problem happens again, I will upload a sample of the .mkv and the mkvmerge settings. To decode AC3 I use FFDShow > Audio Decoder > libavcodec. |
20th January 2009, 18:17 | #6011 | Link |
I am currently using build 980 (original), everything is working as excpected, smooth 24p, sound is in sync, but, I notice black crush/washed out colours when using EVR CP, D3D, lock back buffer, buffered 20, aero disabled, 9400gt with 181.20 drivers, Vista 32bit.
Currently using media portal as my media manager, it launches MPC-HC as the external player for my movies. I can see the black turn grey when MPC-HC starts to playback the video. But when VMR 9 is used, everything is ok, black stays black. I don't use VMR 9 as I am running two monitors, one for work, one for playback of media. If playing back a media file using VMR 9 Renderless, and i click anywhere else on my main work screen, MPC-HC minimizes. Is there anything I can do to resolve the colour issues when using EVR CP? Or is this something that needs to be fixed within MPC-HC? I am using purely the internal mpc filters, I have stopped ffdshow A/V being used within MPC-HC, black crush is visible. When using ffdshow video, i still get black crush, this is apparent when setting 0-255 colourspace (Full range) and 16-255, any ideas? It's the only thing bugging me, verything else is perfect Is there anything within the nvidia control panel I can do to overide this? Last edited by spida_singh; 20th January 2009 at 18:39. |
20th January 2009, 18:17 | #6012 | Link | |
I have the same problem. Beliyaal version 6, VMR9, Windows XP Sp3, D3D9X_35.dll, NVIDIA 8800GT.
20th January 2009, 18:51 | #6013 | Link |
@spida_singh
Read this for several solutions for the "washed out" video: http://forum.doom9.org/showthread.php?t=143689
MPC-HC 2.2.1 |
20th January 2009, 18:57 | #6014 | Link |
I'm getting broken playback of .dts files when using the internal DTS/AC3 source filter. It seems to be playing them back ~5% too fast: the reported duration is too short and the pitch is too high. For what it's worth, all of the files are at 20 or 24-bit depths; I don't know if normal, 16-bit DTS files are affected.
Regardless, the same files play correctly both in VLC and in MPC-HC, if I use this source filter instead: http://ac3filter.net/projects/ac3file |
20th January 2009, 19:31 | #6015 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
20th January 2009, 20:03 | #6016 | Link | |
And it would be very unlikely to be true, because the majority of HT-PC owners use SPDIF. (If you check the AC3FILTER site, you will see that roughly 95% of the questions involve SPDIF.) In fact, Haali Splitter works fine with two audio streams that both use SPDIF. I just tested it again with MPC-HC build 979 and an MKV file with both DTS and AC3 audio, and it works fine. (That file also works fine with internal matroska splitter and internal audio splitter.
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote Last edited by ADude; 20th January 2009 at 20:07. |
20th January 2009, 21:19 | #6017 | Link |
UPDATE:
On a hunch, I installed "CoreVorbis 1.1.0.79" external Vorbis filter, and unchecked the MPC-HC internal Vorbis decoder. After that, Haali Splitter worked fine to switch between the DTS and Vorbis audio streams in the MKV file that previously did not work. So, three possibilities: - Haali Splitter cannot change between an Internal Filter and an External Filter in MPC-HC (it can change between two internal filters or two external filters), but MPC-HC's internal audio splitter can change between any combination. OR - MPC-HC's Internal Vorbis Filter somehow prevents Haali Splitter from switching audio streams, but does not pose a problem for MPC-HC's internal audio splitter (possible, but seems unlikely to me) OR - Some other possibility I have not thought of.
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote Last edited by ADude; 20th January 2009 at 21:25. |
20th January 2009, 21:55 | #6018 | Link | |
20th January 2009, 22:44 | #6019 | Link |
The internal filters are invisible for Haali splitter and DirectShow itself (since they are private and not globally registered), so they will never be used when the filter graph is modified by something else than MPC. This is a limitation of using internal filters. It is not a bug that can be fixed.
MPC-HC 2.2.1 |
21st January 2009, 00:26 | #6020 | Link |
Otaku
You can always dump all the MPC filters in system32 folder and register them so they can be used! That defeats the purpose of having internal filters though...
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
