11th May 2012, 21:58 | #1201 | Link |
Already supported.
Needs a recent enough driver to work properly though, 2696 seems fine.
12th May 2012, 07:49 | #1203 | Link |
VC-1 is WMV3 Advanced Profile, and WMV3 is VC-1 Simple/Main Profile. Its the same codec, just different profiles of it. Doesn't make sense to add an option for that.
Also, there is little space.
12th May 2012, 08:20 | #1205 | Link |
Just out of curiosity is it 3D capable? Would you mind sharing size and model?
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
12th May 2012, 08:23 | #1206 | Link | |
It is 3D capable, and i briefly tried the 3D, and quickly hated it. Was more fun in the cinema. Other then that, i'm pretty happy with it.
12th May 2012, 08:23 | #1207 | Link |
egur, there's still something wrong with MPEG2 interlaced.
With EVR CP of MPC HC it still jitters but it's deinterlaced. With madVR it doesn't jitter but the stream doesn't seem to be marked as interlaced so madVR doesn't deinterlace it. |
12th May 2012, 08:51 | #1208 | Link | |
It's normal to not like the 3D on size this small ... and on LCD TV. You should try it on a 100+ inch screen at a 1x width distance and of course with a bright projector not like most cinemas. but I won't hijack the thread with this any more.
12th May 2012, 12:53 | #1210 | Link | ||
QuickSync Decoder author
Could be that the iGPU isn't strong enough for this setup. I had many performance issues with EVR-CP. My favorite setup is EVR + vobsub (v2.0 or newer) for subs. Quote:
The hardest clip was 4K@50fps with ultra bitrates (>200mbps). The test machine was a laptop class i7 and 1333MHz ram. 4K really stretches the memory subsystem and implies that I need to export DXVA surfaces to avoid copying. This will be the next big feature after deinterlacing is fully functional. I need to work out the details with Nev so this will go smoothly. DXVA implies some changes on how a DirectShow decoder works. Also on the TODO list are (random ordered): * Support MVC (H264 stereo and MVC profiles). * Support MJPEG - MSDK 2012 added this support, usually an indication for future HW or driver support. * Support scaling - may provide a significant performance boost for 4K clips for users with a smaller resolution display (currently 99.999% of users).
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 12th May 2012 at 13:02. |
12th May 2012, 13:24 | #1211 | Link | |||
Since VC-1 interlaced works, I suppose it's just related to MPEG2. Not a drama, every phone can play 1080p MPEG2 in software (even that old ones with a turntable ). But it's a bug and why not fix it. I use LAV but afair it happened with ffdshow too. Quote:
Although I'd let madVR do the scaling with a Radeon HD 7770 if I created a HTPC. Hopefully with Haswell a dedicated graphics card will be completely superfluous for HTPC. |
12th May 2012, 20:09 | #1212 | Link | |
could you please test two more "special" 4K clips ? 1) http://p.gokuai.com/index.php?m=Inde...5Yj637KS6yyu75 This is a 4096 x 3072 H.264 clip at 117,586 fps and very low bitrate 6.6Mbps. The "special" thing about this clip is the ultra high resolution and frame rate. 2) http://115.com/file/clozg3pv# Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.part1.rar http://115.com/file/aqajzuuw# Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.part2.rar http://115.com/file/aqaj7hys# Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.part3.rar The way to download them That is a huge clip: Girls Generation Oh 4in1- 3840x2160@120fps-Ref16-100Mbps It has a resolution of 3840x2160 at 119,880 fps and 100Mbps bitrate. Both were indicated by wanezhiling. Good luck!
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
12th May 2012, 20:22 | #1213 | Link |
The bitrate is not a problem for QuickSync. Clips with 300-500mbps played fine.
120fps? I don't know. Should be in DXVA territory. I'll give them a try when I'm in the lab.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
13th May 2012, 10:18 | #1214 | Link | |
13th May 2012, 12:19 | #1215 | Link | |
@egur as nev said i tested under win7 and it was also ok according to the readme todo so as the driver was also for win7 despite the way it was categorized in the downloadcenter. The problems for now are mostly Video Related QS not working and Adobes Flash Player makes problems (shows some strange black stripes over the video surface renders sometime very weird Video results), if those are really known Win 8 optimized caused issues the driver shouldn't be allowed to install under Win 7 D3D 9 seems stable and slightly improved (especially latency feeling on Aero) but D3D 10 seems to suffer from Render issues http://img14.imageshack.us/img14/137...ssuewin7sb.png (could explain the much lower Game Graphic Benchmark Value in the Windows Performance Index with this Driver, compared to 2719 which doesn't show these D3D 10 Render issues i encountered, though it's hard to categorize these as they are random happening also how they look, sometimes i get flickering black stripes) So yeah on SB Win 7 it's not overall stable, but it shows some nice improvements that i would like to see in the new Win 7 driver also (Aero subjective Performance improvement, faster mode switching times)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 13th May 2012 at 13:20. |
13th May 2012, 13:18 | #1216 | Link |
The Win8 drivers are still in Beta and have an issues list a mile long (according to the release notes)...
I might be able to get hold of a Windows 8 system and start testing, but it will not be soon. I'm too busy with another project. At home I can try this driver family (15.28), but I'll wait for another release or two.
13th May 2012, 15:54 | #1217 | Link | |
Hi
Did you find a solution? Edit: Solution, there is a bug with the driver installer, see here for a fix: http://communities.intel.com/message/156486#156486 Regards Phil Last edited by Phil_L; 13th May 2012 at 17:36. |
13th May 2012, 18:28 | #1218 | Link | |
Maybe the installer was updated. Can you download again and compare the files. The config.ini file you refer to doesn't contain paths. All the files are located relative to setup.exe so it doesn't matter were you extract the files to. Please try again, and if you get errors, let me know.
13th May 2012, 19:00 | #1219 | Link |
Must be a bug in the 2712 installer, never had any such problems with 2696 or any previous drivers.
13th May 2012, 19:55 | #1220 | Link | |
Hi
I suspect if you already installed an older driver that worked you will have the SDK files already (albeit perhaps older ones), and these might be left in the correct location and are found by this installer, so as you update QuickSync still works based on previous installations of the SDK. For me it fixed the issue, and I'd already tried several un-installs/re-installs. This was a clean install of Windows 7 on the Ivy Bridge and I'd only ever installed the most recent graphic drivers. I'll download the one there now and check the Hash's and see if they have changed it since I had got it. Edit: The current file for download is identical to the one I downloaded and had issues with. Regards Phil Last edited by Phil_L; 13th May 2012 at 21:09. |
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
