1st May 2013, 21:58 | #1521 | Link |
The clip(s) are getting the x264 treatment right now. Will check the transition points to see if the trimpoints are noticeable. If they are, I'll try it with the +/- 50 frames first I guess - would take the work out of finding a good spot to do it
Right now, it looks like the combined time to process both operations will be around 43 hours. Thats much faster than any of my attempts with MT would have finished on (by at least a day actually) |
1st May 2013, 22:18 | #1522 | Link |
For QTGMC deinterlacing on many core CPU you can try MP_Pipeline with branching option. It's slower than splitting into many processes, but all in one go and piece
Also- anything above fast for HD is overkill, very fast is enough in most cases. Last edited by kolak; 1st May 2013 at 22:21. |
1st May 2013, 22:31 | #1523 | Link |
That's a very good point. I only noticed now that Johnnyas is using "very slow" which is painful even with the fastest CPUs for HD resolutions. I also have seen very good results with "Medium" and "Fast" presets. Not to mention that the memory requirements will most likely be lower.
2nd May 2013, 01:07 | #1524 | Link | |
For HD, I usually use very slow paired with the source match and lossless settings in qtgmc and veryslow with x264. I also use setmemorymax(1200) which I found was the most stable on my pc with those settings and split the encode in 4 with setmtmode set to 2 threads each. I also use avs2pipemod to pipe the avs to 64bit x264, mostly for the added stability piping provides since it doesn't seem faster than using the 32bit version. It usually take a little less than a day to make the lossless encode to FFV1 and a bit over a day for the final 10bit x264 one(so 8bit would be close to half the time) for a 2 hour movie. Last edited by SamKook; 2nd May 2013 at 01:18. |
2nd May 2013, 02:47 | #1526 | Link | |
Either way, both slower QTGMC and x264 settings affect file size(or quality at fixed bitrate) by a lot. I wish I would have kept my result from the last time I tested this. |
2nd May 2013, 12:07 | #1527 | Link | |
I would not waste 3x more time for even 25% smaller file size. I assume it's not close to 25% is it? If it works for you than fine |
2nd May 2013, 14:19 | #1528 | Link |
It indeed depends on your priorities. If I were encoding a lot of them, then I might reconsider how much time I'm willing to spend on it.
I don't care at all how long it takes as long as I can get all I can out of it. Everything is automated anyway once I've tweaked my settings for a particular video and it doesn't affect anything else I do on the computer at the same time so it doesn't bother me. I've even tried to encode a bluray without splitting it with crazy(and not so good) settings and 21 days later, it finished. I won't do that ever again, but it was a fun experiment. And I also doubt it's as much as 25%, but I remember being surprised by how much it was. I'll have to try it again when I have the time. |
2nd May 2013, 14:54 | #1529 | Link |
The files I'm encoding are our home movies, and I encode them to keep like this. Since these will be my archive files, I definately want to do it on the best quality possible (within reason). I know there isn't too much difference between the slower presets on HD (well, at least from medium and slower), but a I'm encoding to keep so, it's not a one-time watch thing. Also, as SamKook, I've seen files get smaller when I've had both QTGMC AND the x264 encoder set at Very Slow, as opposed to Slower on QTGMC/Very Slow on the x264 encoder.
5th May 2013, 13:14 | #1530 | Link |
Just an update here. Have done some testing, and the final renders on this movie at least - and I can't see the points where I join the movies at all, and that was with trimming from the exact frames (as opposed to doing some frames before/after). Very happy with the final results of this, so once again - thanks all!
14th May 2013, 06:33 | #1531 | Link |
Huh?
I am trying to use QTGMC with the plugin pack that uses the updated Avisynth 2.6 interface, and these filters from it:
mt_masktools-26 removegrainsse2 mvtools2 fft3dfilter Gave out an access violation error at an address and attempted to read from 0x00000000. Also, I got an error with nnedi3 that said arg0 needed to be a clip. Replacing these five DLLs with the ones from the original Modded Plugins Package seems to have solved the issues. What could be the cause of these error messages?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
14th May 2013, 06:42 | #1532 | Link | |
(read this thread and you will see that a bunch of people, me included, have problems with the modded plugins) |
14th May 2013, 07:14 | #1533 | Link | |
And if you are using MT 2.60a4:
28th May 2013, 06:09 | #1535 | Link |
Serious answer:
Never trust an automatical detection. There is always a chance that the samples catch frames with too little changes to detect field changes reliably. If there is a doubt about the structure, check the video manually by stepping frame-by-frame through a bobbed result (bobbing interpolates fields to whole frames for a convenient display), preceded with both AssumeTFF and AssumeBFF successively, counting how many fields are mostly equal or different over at least 30 fields in a row. QTGMC is usually only recommendable if you are certain that the material is plain interlaced. For telecined material, use an IVTC plugin instead. And special standard conversions (PAL/NTSC/Film; censorship cover-up) might require custom solutions even... |
29th May 2013, 05:15 | #1536 | Link |
After calling the following function:
# Anti-aliasing with contra-sharpening by Didée (thanks to Didée, modded for this case with nnedi3) # Is required VerticalCleaner function DAAMod(clip c) { nn = c.nnedi3(field=-2) dbl = mt_average(selecteven(nn),selectodd(nn),U=3,V=3) dblD = mt_makediff(c,dbl,U=3,V=3) shrpD = mt_makediff(dbl,dbl.removegrain((width(c)>1100) ? 20 : 14),U=3,V=3).verticalcleaner(mode=2) DD = shrpD.repair(dblD,9) return dbl.mt_adddiff(DD,U=3,V=3) } I get the following error message: Avisynth open failure: nnedi3: arg 0 must be a clip! The nnedi3 calling is in red. I was using version 2.6-Vit-nnedi3 (part of plugin pack for testing) and I had to return to the tritical's original version to run the script. I'm using the latest version of Avisynth 2.6.0 MT of SEt 2013.03.09. Last edited by GMJCZP; 29th May 2013 at 05:18. |
29th May 2013, 09:28 | #1537 | Link |
The problem might be outside this function, you may be calling DAAMod() with something that isn't a clip (e.g. in a context where the clip is not 'last', but a specific variable), and its parameter is passed on to NNEDI3().
29th May 2013, 20:24 | #1539 | Link | |
-0- On the other hand, I did something funny. I hung up the VirtualDub is processing a script more than once when appear 5 minutes (I have so configured in my PC) the screen saver. I had the idea of not carrying on the script the old version of nnedi3 (not was calling him!, only put #Load... nnedi3.dll) and incredibly the problem was solved. Coincidence? Last edited by GMJCZP; 29th May 2013 at 20:26. |
3rd June 2013, 11:05 | #1540 | Link | |
Hello, i need small help with qtgmc + JDL_ApplyRange
I need use this filter only on xxxx of frames, and recive error - Quote:
