Old 4th October 2011, 00:06   #13161  |  Link
Treasurer121
The problem is that the ISO that is made without the Certificate file included will not play. Says unsupportable format now. I am always used to finding the Certificate file right under the BDMV file.
Same thing just happened with my backup of one of my "Pacific" episodes.,..
[16:31:55] BD Rebuilder v0.39.01 (beta)
- Source: PACIFIC_DISC5
- Input BD size: 17.00 GB
- Approximate total content: [00:57:46.504]
- Target BD size: 4.36 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), Two Pass
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[16:31:58] PHASE ONE, Encoding
- [16:31:58] Processing: VID_01100 (1 of 1)
- [16:31:58] Extracting A/V streams [VID_01100]
- [17:05:08] Reencoding video [VID_01100]
- Rate/Length: 23.976fps, 83,113 frames
- Bitrate: 8,969 Kbs
- [17:05:08] Reencoding: VID_01100, Pass 1 of 2
- [17:58:49] Reencoding: VID_01100, Pass 2 of 2
- [18:53:46] Video Encode complete
- [18:53:46] Reencoding audio tracks (if req'd)
- [18:55:41] Multiplexing M2TS
[18:58:08]PHASE ONE complete
[18:58:08]PHASE TWO - Rebuild Started
- [18:58:08] Rebuilding AVCHD file Structure
[19:00:32] - Encode and Rebuild complete
[19:00:32]JOB: PACIFIC_DISC5 finished.
_________________________________________
Will try the adjustment you stated and start again.
Treasurer121 is offline   Reply With Quote
Old 4th October 2011, 01:09   #13162  |  Link
JJB
Just un-check the strict avchd mode and try again. I assume your player just does not recognize that structure.
Once again I assume it is a stand alone player and not a software player, correct?
JJB is offline   Reply With Quote
Old 4th October 2011, 01:37   #13163  |  Link
Treasurer121
Software/DVD/Blue Ray combo player/ DVD recorder...
Thus the BD-5 settings. It used to work just fine.
Old 4th October 2011, 04:20   #13164  |  Link
Treasurer121
Ok, unchecked Strict AVCHD and rechecked the other settings to concur with earlier thread settings. Still didnt see the CERTIFICATE file after rebuild, BUT since I selected auto burn ISO with IMGBURN it made a usable and bootable copy of my Pacific Episode. Thanks JJB, I appreciated the help. It had my perplexed.
Thanks again,
Dan.
Here's the log anyway for this last run....
[20:43:47] BD Rebuilder v0.39.01 (beta)
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448
[20:43:47] PHASE ONE, Encoding
- [20:43:47] Processing: VID_01100 (1 of 1)
- [20:43:47] Extracting A/V streams [VID_01100]
- [21:17:38] Reencoding video [VID_01100]
- Bitrate: 8,377 Kbs
- [21:17:38] Reencoding: VID_01100, Pass 1 of 2
- [22:09:52] Reencoding: VID_01100, Pass 2 of 2
- [23:02:35] Video Encode complete
- [23:02:35] Reencoding audio tracks (if req'd)
- [23:02:35] Multiplexing M2TS
[23:04:21]PHASE ONE complete
[23:04:21]PHASE TWO - Rebuild Started
- [23:04:21] Rebuilding AVCHD file Structure
[23:07:02] - Encode and Rebuild complete
[23:07:02] Writing BD structure to ISO file
- ImgBurn completed successfully
[23:09:35]JOB: PACIFIC_DISC5 finished.
Old 4th October 2011, 08:33   #13165  |  Link
jfcarbel
Programmer
tsmuxer gives ability to cut from front and back of streams, I believe BD-Rebuilder uses tsmuxer on the last step.
Is there a way to pass a command line parm to tsmuxer to do the cuts? This is useful sometimes to eliminate long credits. I have 2 movies where credits are like 10 minutes long.
--cut-end is the parm, I believe its specified value is ## + units (i..e. --cut-end 30s).
jfcarbel is offline   Reply With Quote
Old 4th October 2011, 08:37   #13166  |  Link
omegaman7
omegaman7's Avatar
With dvd rebuilder, it's typical(but not always) to have the credits within a single stream. I usually highly compress that, since obviously it can afford a great deal of loss. One day, I'm sure Jdobbs will implement the ability to allocate bandwidth accordingly to specified streams
I prefer not cut the credits. It's informative at times Besides, the difference would be negligible.
omegaman7 is offline   Reply With Quote
Old 4th October 2011, 15:48   #13167  |  Link
jakobkraft
Originally Posted by worknstiff View Post
@jakobkraft: RE: Quote- I did upgrade everything -- what I did was just delete first the previous BDRebuilder folder (which I always kept in 'Program Files') -
Per instructions on (FIRST PAGE) Per Step 3 -3. Unzip the BD-RB.zip file. Put it in a directory of its own. I'd recommend putting it somewhere other than "C:\Program Files" until it has been tested more (because of the virtualization that began with Vista).
Maybe this will help by moving it, and also sometimes you need to uninstall all the helper apps and reboot and reinstall. goodluck, woirknstiff
Oops, just saw the post from RobertM, sorry
Ok, I THINK I've solved the problem. I moved the BD-Rebuilder folder from Program Files to C:\ drive (didn't know about the Win7 virtualization thing) and I updated the Haali Splitter. That's all. No more x264.exe error for now...
jakobkraft is offline   Reply With Quote
Old 4th October 2011, 16:50   #13168  |  Link
jfcarbel
Programmer
Not always, I have two titles were I saved close to 1GB in space.
Old 4th October 2011, 17:19   #13169  |  Link
omegaman7
omegaman7's Avatar
Transformers 3 seemed rather long. But even if it were ten minutes, that'd only improve the main(or over all compression) title by 6.4%(If my math is correct) :S
But if laserfan is correct, it wouldn't even be that. The credits already have a low bitrate.
Old 4th October 2011, 18:03   #13170  |  Link
laserfan
Aging Video Hobbyist
I don't think this is worth messing with if BD-RB is doing a two-pass x264 conversion, because x264 will minimize the bit-allocation to the credit sequence anyway.
laserfan is offline   Reply With Quote
Old 4th October 2011, 21:41   #13171  |  Link
sonate
To J Dobbs
I just put Dr. Strangelove through BD REB using these audio settings - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
The audio in was Dolby True HD 5.1, and what I ended up in the final rebuild was AC3-640.
Is this just a simple case of transferring the compressed audio without processing with the metadata? And is it correct to assume that an audio re encode was not performed by BD Rebuilder?
If so, will these settings consistently give that result with Dolby True HD?
sonate is offline   Reply With Quote
Old 4th October 2011, 22:40   #13172  |  Link
Rany
- Source Video: MPEG-2, 1920x1080
- Rate/Length: 23,976fps, 3.661 frames
- [17:44:02] Reencoding: VID_00029, Pass 1 of 1
- [17:50:40] Video Encode complete
- [17:50:40] Reencoding audio tracks (if req'd)
- [17:50:40] Multiplexing M2TS
- [17:50:48] Processing: VID_00030 (7 of 12)
- [17:50:48] Extracting A/V streams [VID_00030]
- [17:51:13] Reencoding video [VID_00030]
- Rate/Length: 23,976fps, 3.338 frames
- [17:51:13] Reencoding: VID_00030, Pass 1 of 1
- [17:58:18] Video Encode complete
- [17:58:18] Reencoding audio tracks (if req'd)
- [17:58:18] Multiplexing M2TS
- [17:58:27] Processing: VID_00016 (8 of 12)
- [17:58:27] Extracting A/V streams [VID_00016]
- [17:59:41] Reencoding video [VID_00016]
- Rate/Length: 23,976fps, 9.703 frames
- [17:59:41] Reencoding: VID_00016, Pass 1 of 1
- [18:18:15] Video Encode complete
- [18:18:15] Reencoding audio tracks (if req'd)
- [18:18:15] Multiplexing M2TS
- [18:18:36] Processing: VID_00014 (9 of 12)
- [18:18:36] Extracting A/V streams [VID_00014]
- [18:19:31] Reencoding video [VID_00014]
- Rate/Length: 23,976fps, 10.796 frames
- [18:19:31] Reencoding: VID_00014, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.39.01 (beta)
- Windows Version: 5.2 [3790]
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: 1.11.96.14, Ok
- FFDSHOW: 3882, Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[18:19:38] - Failed video encode, aborted
Help.
Rany is offline   Reply With Quote
Old 4th October 2011, 23:35   #13173  |  Link
setarip_old
setarip_old's Avatar
@Rany
Once again, as in your previous post(s), it appears that you've intentionally cut off the required beginning information from the log you've submitted. The following (from another member's post) shows the lines you've deleted (The specific names and title numbers and sizes are simply examples):
setarip_old is offline   Reply With Quote
Old 5th October 2011, 04:10   #13174  |  Link
jdobbs
What was your target size? If it was BD-5/9 -- it acted as it should. BD-5/9 is not large enough to retain True HD.
Website: www.jdobbs.net
Old 5th October 2011, 04:14   #13175  |  Link
jdobbs
@Rany
Usually an issue like you've reported is an indicator that something else has intercepted or is interfering with the CODECs provided by FFDSHOW. Make sure you remove any "codec packs" you have installed. Then uninstall and reinstall HAALI and FFDSHOW. If something has "gummed up the works" reinstallation will often fix it.
Old 5th October 2011, 04:43   #13176  |  Link
sonate
Well it was BD-25, but I was trying to reduce the size for audio. But my major question is whether there was an audio re encode. Does the AC3 640kbs already exist as part of the Dolby THD track?
Old 5th October 2011, 13:29   #13177  |  Link
jdobbs
Yes it does. The core of the True HD track would be 640Kbs DD5.1. Since you have "Keep HD" and "Reencode AC3" both set off and you're going to BD-25 -- your output should consist of the core of the original audio (without reencoding).
Old 5th October 2011, 14:47   #13178  |  Link
Capsbackup
Please correct me if I am wrong... If there are audio file/s in the Workfiles folder that are named AUD_xxxxx_xxxx, then those audio files were reencoded. So if the AUD_xxxx_xxxx corresponds to the title in question, audio was reencoded.
Capsbackup is offline   Reply With Quote
Old 5th October 2011, 16:23   #13179  |  Link
jdobbs
Not necessarily. The extracted core can be renamed simply to make the rebuild less complex under certain circumstances.
But generally, yes, that's the case.
Old 6th October 2011, 05:24   #13180  |  Link
Rany
Originally Posted by setarip_old View Post
@Rany
i have new windows fresh instalation windows server 2008 R2 standard Sp1,some problems check log:
[00:01:23] BD Rebuilder v0.39.01 (beta)
  - Source:  THE.PURSUIT.OF.HAPPYNESS.2006.1080P.BLU-RAY.EUR.H.264-HDMONSK
  - Input BD size: 45,81 GB
  - Approximate total content: [03:16:18.925]
  - Target BD size: 22,95 GB
  - Quality: Highest (Very Slow), ABR
[00:01:24] PHASE ONE, Encoding
 - [00:01:24] Processing: VID_00034 (1 of 12)
 - [00:01:24] Extracting A/V streams [VID_00034]
 - [00:01:39] Reencoding video [VID_00034]
   - Rate/Length: 23,976fps, 3.231 frames
 - [00:01:39] Reencoding: VID_00034, Pass 1 of 1
 - [00:06:18] Video Encode complete
 - [00:06:18] Reencoding audio tracks (if req'd)
 - [00:06:18] Multiplexing M2TS
 - [00:06:24] Processing: VID_00033 (2 of 12)
 - [00:06:24] Extracting A/V streams [VID_00033]
 - [00:06:40] Reencoding video [VID_00033]
   - Rate/Length: 23,976fps, 3.650 frames
 - [00:06:40] Reencoding: VID_00033, Pass 1 of 1
 - [00:12:38] Video Encode complete
 - [00:12:38] Reencoding audio tracks (if req'd)
 - [00:12:38] Multiplexing M2TS
 - [00:12:43] Processing: VID_00032 (3 of 12)
 - [00:12:43] Extracting A/V streams [VID_00032]
 - [00:13:01] Reencoding video [VID_00032]
 - [00:13:01] Reencoding: VID_00032, Pass 1 of 1
 - [00:15:13] Video Encode complete
 - [00:15:13] Reencoding audio tracks (if req'd)
 - [00:15:13] Multiplexing M2TS
 - [00:15:15] Processing: VID_00031 (4 of 12)
 - [00:15:15] Extracting A/V streams [VID_00031]
 - [00:15:33] Reencoding video [VID_00031]
   - Rate/Length: 23,976fps, 3.696 frames
 - [00:15:33] Reencoding: VID_00031, Pass 1 of 1
 - [00:22:01] Video Encode complete
 - [00:22:01] Reencoding audio tracks (if req'd)
 - [00:22:01] Multiplexing M2TS
 - [00:22:08] Processing: VID_00028 (5 of 12)
 - [00:22:08] Extracting A/V streams [VID_00028]
 - [00:22:28] Reencoding video [VID_00028]
   - Rate/Length: 23,976fps, 3.658 frames
 - [00:22:28] Reencoding: VID_00028, Pass 1 of 1
 - [00:28:29] Video Encode complete
 - [00:28:29] Reencoding audio tracks (if req'd)
 - [00:28:29] Multiplexing M2TS
 - [00:28:34] Processing: VID_00029 (6 of 12)
 - [00:28:34] Extracting A/V streams [VID_00029]
 - [00:28:55] Reencoding video [VID_00029]
 - [00:28:55] Reencoding: VID_00029, Pass 1 of 1
 - [00:36:01] Video Encode complete
 - [00:36:01] Reencoding audio tracks (if req'd)
 - [00:36:01] Multiplexing M2TS
 - [00:36:08] Processing: VID_00030 (7 of 12)
 - [00:36:08] Extracting A/V streams [VID_00030]
 - [00:36:29] Reencoding video [VID_00030]
 - [00:36:29] Reencoding: VID_00030, Pass 1 of 1
 - [00:43:35] Video Encode complete
 - [00:43:35] Reencoding audio tracks (if req'd)
 - [00:43:35] Multiplexing M2TS
 - [00:43:45] Processing: VID_00016 (8 of 12)
 - [00:43:45] Extracting A/V streams [VID_00016]
 - [00:44:30] Reencoding video [VID_00016]
 - [00:44:30] Reencoding: VID_00016, Pass 1 of 1
 - [01:08:02] Video Encode complete
 - [01:08:02] Reencoding audio tracks (if req'd)
 - [01:08:02] Multiplexing M2TS
 - [01:08:29] Processing: VID_00014 (9 of 12)
 - [01:08:29] Extracting A/V streams [VID_00014]
 - [01:09:19] Reencoding video [VID_00014]
 - [01:09:19] Reencoding: VID_00014, Pass 1 of 1
  - FFDSHOW: 3882, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[01:09:26] - Failed video encode, aborted
Please help
