8th June 2011, 22:48 | #12181 | Link |
@jdobbs, RE:Normally for interlaced or hybrid sources I do no filtering and reencode it as interlaced.
So for most 1080i and 1080i hybrid "**", if playing on STB just leave the use DEINTERLACER off, and no pulldown. Thanks for your input, that helps me with these music disks alot. Are these disks encoded in 1080i just because they originally for broadcast or for some technical reason? It seems like a lot of the music and documentary disks are encoded as 1080i. I was using a Hauppauge HD-1212 for a DVR and had success just changing the video to 720p for playback and got rid of the interlaced altogether but I don't think I could easily do these videos like that. |
8th June 2011, 22:51 | #12182 | Link | |
@sandrino3867
Hi! Quote:
9th June 2011, 00:30 | #12183 | Link | |
[Status] LABEL=PACIFIC_DISC3 VERSION=v0.38.03 (beta) SOURCE_SIZE=39397548002 SOURCE_VIDEO_SIZE=37854277632 TARGET_SIZE=24641536000 REDUCTION=.610189047973642 RESIZE_1080=0 AUDIO_TO_KEEP=eng KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=1 ENCODE_STEP=0 COMPLETED=43 REBUILD_COMPLETE=1 [00088] AUDIO=1 PGS= M2TS_TARGET=4671256 VIDEO2=0 V2MBRATE=0 NSTART=27000000 NEND=27630720 NSIZE=3354624 FLINK=0 MLINK=0 [00017] AUDIO=10 PGS=111011 M2TS_TARGET=20410728 VIDEO2=1572551.47058824 V2MBRATE=7000 RATE=9081 NSTART=27000000 NEND=27675360 NSIZE=6291456 FLINK=0 MLINK=0 [01019] AUDIO=10 PGS=111011 M2TS_TARGET=39379594 VIDEO2=2689534.66386555 V2MBRATE=7000 RATE=9150 NSTART=27000000 NEND=28306080 NSIZE=11550720 FLINK=0 MLINK=0 [01018] AUDIO=10 PGS=111011 M2TS_TARGET=39543577 VIDEO2=3118910.71428571 V2MBRATE=7000 RATE=9082 NSTART=27000000 NEND=28306080 NSIZE=11974656 FLINK=0 MLINK=0 [01047] AUDIO=10 PGS=111011 M2TS_TARGET=39681151 VIDEO2=1660669.11764706 V2MBRATE=7000 RATE=9491 NSTART=27000000 NEND=28306080 NSIZE=10500096 FLINK=0 MLINK=0 [01035] AUDIO=10 PGS=111011 M2TS_TARGET=39738972 VIDEO2=2640671.2184874 V2MBRATE=7000 Last edited by jdobbs; 9th June 2011 at 02:19. |
9th June 2011, 02:22 | #12185 | Link |
@sandrino3867
Did you edit the LOG you posted? There seems to be debug information missing after "- FFDSHOW: 3326, Ok". But since this appears to be a downloaded source I don't think I can help anyway -- there is too much likelihood that there are problems even before the encode. A lot of people who reencode and post those things are clueless and screw it up royally. Besides, it violates DOOM9 forum rules. |
9th June 2011, 14:33 | #12186 | Link |
Here is my latest unsuccessful attempt at converting a blu ray to dvd-video using BDRebuilder.
21:35:38] BD Rebuilder v0.38.03 (beta) - Source: THE_WAY_BACK - Input BD size: 19.97 GB - Approximate total content: [02:13:21.910] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-9, 720x480/576, AC3 Audio - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [21:35:38] PHASE ONE, Encoding - [21:35:38] Extracting A/V streams [VID_00012] - [21:38:58] Reencoding: VID_00012 (1 of 2) - [21:38:58] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 240 frames - Bitrate: 7,996 Kbs - [21:38:58] Reencoding: VID_00012 - [21:39:41] Video Encode complete - [21:39:41] Reencoding audio tracks (if req'd) - [21:44:21] Multiplexing M2TS - [21:44:21] Extracting A/V streams [VID_00006] - [21:48:08] Reencoding: VID_00006 (2 of 2) - [21:48:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 191,614 frames - Bitrate: 7,659 Kbs - [21:48:08] Reencoding: VID_00006 - [04:38:55] Video Encode complete - [04:38:55] Multiplexing M2TS [04:38:55]PHASE ONE complete [04:38:55]PHASE TWO - Rebuild Started - [04:38:55] Rebuilding stream 00012 [1 of 2] - [04:38:55] Rebuilding stream 00006 [2 of 2] - [04:38:55] Building ALTERNATE OUTPUT Structure - [04:42:09] Converting 1 subtitles to DVD format. - [04:43:05] Starting MPLEX. - ERROR in attempt to mux (MPLEX) [04:46:38] - Failed to REBUILD I took the m2v file and the ac3 audio from the WorkFiles folder and authored in DVDLab Pro successfully, so I've got a good result, but thought you might want to see the log. |
10th June 2011, 03:52 | #12188 | Link |
I am having problems with King's Speech.
I get to 8.80% then I get this error... ----------------------- [19:45:36] BD Rebuilder v0.38.03 (beta) - Source: BD_VIDEO - Input BD size: 31.51 GB - Approximate total content: [01:58:28.142] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [19:45:36] PHASE ONE, Encoding - [19:45:36] Extracting A/V streams [VID_00015] - Error in attempt to extract audio/subs. - Not enought buffer for parse video stream. Current frame num 0 [19:46:59] - Failed to retrieve audio, aborted Goodfellas worke fine. Using W7 64 Ultimate. |
10th June 2011, 15:40 | #12190 | Link | |
(screenshot) How do I decide between "libavcodec" and "libmpeg2" options? Thanks! |
10th June 2011, 16:17 | #12191 | Link |
Missing metadata: Cover Artwork when playing back on player
Go easy on me. I hope this isnt too off topic as I dont know if its something to do with bd rebuilder or not but does anyone know what bd rebuilder may be doing to the files that keeps my Sony BDP-CX7000ES from finding the cover art and metadata for title, description etc. that would otherwise be pulled from Gracenote on the original disk?
10th June 2011, 16:31 | #12193 | Link | |
10th June 2011, 16:41 | #12194 | Link | |
I ran "The Pacific", Disc 3 overnight and it sized to 24,336,711,840 bytes -- which will easily fit on a BD-25. |
10th June 2011, 16:56 | #12195 | Link |
Highest (very slow) and High Speed Option (BD-25)
Backing up to 25 gb disks and doing full backkups and wanted to know (generally speaking) what is the difference between Highest (very slow) and High Speed Option (BD-25)? Which one provides the best quality audio/video output?
thanks in advance! I would also like to know if this thread is for bug reports only is there another thread for usage questions? Does it help if I say it like the Double Rainbow Guy: "What Does it Mean!!" Last edited by jabberwockie; 10th June 2011 at 23:06. |
10th June 2011, 16:58 | #12196 | Link | |||
Thanks for all your hard work, jdobbs! [edit] Also: If this how-to thread is meant for bug reports (as stated in the OP), is there another thread for usage questions? Last edited by Ichinisan; 10th June 2011 at 18:38. |
10th June 2011, 17:38 | #12197 | Link |
I would see the Bitrate displayed on my TV (via my Blu-Ray player)...which does show very short lived high rates. But after posting this question, I installed BDInfo and then Scanned the Bitrates on a number of Blu-Ray titles, including the original of A.I. and the copy. It includes categories for Peak Bitrates for 1 sec, 5 sec, and 10 sec duration. The original of A.I. only exceeded 40 mbps a few times in the 1 sec category. Never in the 5 or 10 sec category. The copy exceeded 40 mbps in both the 1 sec and 5 sec categories.
Now that was done using the Highest Quality setting to a target size of 24500 (which is normally what I use, as it works 98% of the time). Last night re-encoded A.I. with a target size of 23500 to see if could reduce the high bit rates, and it helped. The copy only exceeds 40 mbps in the 1 sec category...though the highest at the 1 sec category exceeds the highest bit rate the original had (about 48 mbps). I have not burned that to a BD yet, but will shortly and will check it out. I'm thinking it's my player and not the encode...as I rarely encounter such problems. Though I did note a two occurances of a few dropped frames on another film last night. In one of the two cases, backing up and replaying did not reproduce the dropped frames and in the other case it was reproduceable. Not sure if the two are related. And once again. As I did this film (A.I.) in all the quality modes, I did note that the High-Speed only included two such freezes, whereas the Highest Quality mode dozens of them. The various in-between showed more than the High-Speed mode but less than the Highest Quality mode. So my assuption is (without knowing for sure) is that as you go higher on the quality scale, the encoder is able to better determine where it should boost the bitrate, and where it can slack off a bit...to fit the target size. And the smaller the target size, the lower the max bit rate... I have an I7-930 system (not overclocked) with 9GB memory. A.I. took about 9.5 hours at the highest quality setting. Which is quite a bit more than most films...which average anywhere between 4 and 6 hours using the Highest Quality mode. BTW, the WB encode of A.I. looks fabulous. No DNR, no EE. Very sharp. Very detailed. |
10th June 2011, 23:54 | #12200 | Link |
@jdobbs;
I ran a full backup to BD5, and forgot to delete the extra files copied from the Anydvd HD rip. (ANY!, PS3_UPDATE, PS3_VPRM, PS3_DISC.SFB) These files total 177MB. Normally I would not think this is a big deal since I have selected "Keep only BDMV/CERTIFICATE folders" in Setup. The total file size of the backup was only 4.06GB. So out of curiosity, I ran the same backup again using the exact same settings, except I deleted these files from the source folder. I noticed in the log of this new backup that the bitrates are higher on all files reencoded, and the final output was 4.22GB. Could it be that BD-RB is not subtracting for these folders to allow for this extra available room when "Keep only BDMV/CERTIFICATE folders" is selected in Setup? Code:
Test 1 ----------------------- [20:36:33] BD Rebuilder v0.38.03 (beta) - Source: TALL_DARK_STRANGER - Input BD size: 21.09 GB - Approximate total content: [01:58:54.458] - Target BD size: 4.44 GB - Windows Version: 6.1 [7601] - SHUTDOWN at completion enabled - Quality: High Quality (Default), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [20:36:33] PHASE ONE, Encoding - [20:36:33] Extracting A/V streams [VID_00000] - [20:36:35] Reencoding: VID_00000 (1 of 10) - [20:36:35] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 346 frames - Bitrate: 1,897 Kbs - [20:36:35] Reencoding: VID_00000, Pass 1 of 1 - [20:36:45] Video Encode complete - [20:36:45] Reencoding audio tracks (if req'd) - [20:36:46] Multiplexing M2TS - [20:36:46] Extracting A/V streams [VID_00001] - [20:36:53] Reencoding: VID_00001 (2 of 10) - [20:36:53] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,124 frames - Bitrate: 2,804 Kbs - [20:36:53] Reencoding: VID_00001, Pass 1 of 1 - [20:37:48] Video Encode complete - [20:37:48] Reencoding audio tracks (if req'd) - [20:37:48] Multiplexing M2TS - [20:37:50] Extracting A/V streams [VID_00011] - [20:52:01] Reencoding: VID_00011 (3 of 10) - [20:52:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 141,792 frames - Bitrate: 4,533 Kbs - [20:52:01] Reencoding: VID_00011, Pass 1 of 1 - [23:14:49] Video Encode complete - [23:14:49] Reencoding audio tracks (if req'd) - [23:16:36] Multiplexing M2TS - [23:18:41] Extracting A/V streams [VID_00021] - [23:18:52] Reencoding: VID_00021 (4 of 10) - [23:18:52] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,360 frames - Bitrate: 2,877 Kbs - [23:18:52] Reencoding: VID_00021, Pass 1 of 1 - [23:20:39] Video Encode complete - [23:20:39] Reencoding audio tracks (if req'd) - [23:20:41] Multiplexing M2TS - [23:20:42] Extracting A/V streams [VID_00022] - [23:20:56] Reencoding: VID_00022 (5 of 10) - [23:20:56] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,343 frames - Bitrate: 2,664 Kbs - [23:20:56] Reencoding: VID_00022, Pass 1 of 1 - [23:23:08] Video Encode complete - [23:23:08] Reencoding audio tracks (if req'd) - [23:23:10] Multiplexing M2TS - [23:23:12] Extracting A/V streams [VID_00081] - [23:23:18] Reencoding: VID_00081 (6 of 10) - [23:23:18] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,440 frames - Bitrate: 2,947 Kbs - [23:23:18] Reencoding: VID_00081, Pass 1 of 1 - [23:23:42] Video Encode complete - [23:23:42] Reencoding audio tracks (if req'd) - [23:23:42] Multiplexing M2TS - [23:23:43] Extracting A/V streams [VID_00101] - [23:23:49] Reencoding: VID_00101 (7 of 10) - [23:23:49] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,012 frames - Bitrate: 4,212 Kbs - [23:23:49] Reencoding: VID_00101, Pass 1 of 1 - [23:24:33] Video Encode complete - [23:24:33] Reencoding audio tracks (if req'd) - [23:24:34] Multiplexing M2TS - [23:24:35] Extracting A/V streams [VID_00104] - [23:24:41] Reencoding: VID_00104 (8 of 10) - [23:24:41] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,012 frames - Bitrate: 4,249 Kbs - [23:24:41] Reencoding: VID_00104, Pass 1 of 1 - [23:25:26] Video Encode complete - [23:25:26] Reencoding audio tracks (if req'd) - [23:25:26] Multiplexing M2TS - [23:25:27] Extracting A/V streams [VID_00205] - [23:25:28] Reencoding: VID_00205 (9 of 10) - [23:25:28] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 120 frames - Bitrate: 3,543 Kbs - [23:25:28] Reencoding: VID_00205, Pass 1 of 1 - [23:25:31] Video Encode complete - [23:25:31] Reencoding audio tracks (if req'd) - [23:25:31] Multiplexing M2TS - [23:25:31] Extracting A/V streams [VID_04999] - [23:25:36] Reencoding: VID_04999 (10 of 10) - [23:25:36] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 4,303 Kbs - [23:25:36] Reencoding: VID_04999, Pass 1 of 1 - [23:26:23] Video Encode complete - [23:26:23] Reencoding audio tracks (if req'd) - [23:26:23] Multiplexing M2TS [23:26:25]PHASE ONE complete [23:26:25]PHASE TWO - Rebuild Started - [23:26:25] Rebuilding BD file Structure [23:26:42] - Encode and Rebuild complete - Computer SHUTDOWN initiated. Test 2 ----------------------- [11:52:10] BD Rebuilder v0.38.03 (beta) - Source: TALL_DARK_STRANGER - Input BD size: 20.92 GB - Approximate total content: [01:58:54.458] - Target BD size: 4.44 GB - Windows Version: 6.1 [7601] - Quality: High Quality (Default), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [11:52:10] PHASE ONE, Encoding - [11:52:10] Extracting A/V streams [VID_00000] - [11:52:12] Reencoding: VID_00000 (1 of 10) - [11:52:12] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 346 frames - Bitrate: 2,005 Kbs - [11:52:12] Reencoding: VID_00000, Pass 1 of 1 - [11:52:26] Video Encode complete - [11:52:26] Reencoding audio tracks (if req'd) - [11:52:28] Multiplexing M2TS - [11:52:28] Extracting A/V streams [VID_00001] - [11:52:36] Reencoding: VID_00001 (2 of 10) - [11:52:36] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,124 frames - Bitrate: 2,989 Kbs - [11:52:36] Reencoding: VID_00001, Pass 1 of 1 - [11:53:52] Video Encode complete - [11:53:52] Reencoding audio tracks (if req'd) - [11:53:52] Multiplexing M2TS - [11:53:56] Extracting A/V streams [VID_00011] - [12:08:21] Reencoding: VID_00011 (3 of 10) - [12:08:21] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 141,792 frames - Bitrate: 4,754 Kbs - [12:08:21] Reencoding: VID_00011, Pass 1 of 1 - [14:59:03] Video Encode complete - [14:59:03] Reencoding audio tracks (if req'd) - [15:00:53] Multiplexing M2TS - [15:03:17] Extracting A/V streams [VID_00021] - [15:03:29] Reencoding: VID_00021 (4 of 10) - [15:03:29] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,360 frames - Bitrate: 3,025 Kbs - [15:03:29] Reencoding: VID_00021, Pass 1 of 1 - [15:05:18] Video Encode complete - [15:05:18] Reencoding audio tracks (if req'd) - [15:05:20] Multiplexing M2TS - [15:05:21] Extracting A/V streams [VID_00022] - [15:05:36] Reencoding: VID_00022 (5 of 10) - [15:05:36] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,343 frames - Bitrate: 2,803 Kbs - [15:05:36] Reencoding: VID_00022, Pass 1 of 1 - [15:07:49] Video Encode complete - [15:07:49] Reencoding audio tracks (if req'd) - [15:07:52] Multiplexing M2TS - [15:07:53] Extracting A/V streams [VID_00081] - [15:07:59] Reencoding: VID_00081 (6 of 10) - [15:07:59] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,440 frames - Bitrate: 3,068 Kbs - [15:07:59] Reencoding: VID_00081, Pass 1 of 1 - [15:08:24] Video Encode complete - [15:08:24] Reencoding audio tracks (if req'd) - [15:08:24] Multiplexing M2TS - [15:08:25] Extracting A/V streams [VID_00101] - [15:08:32] Reencoding: VID_00101 (7 of 10) - [15:08:32] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,012 frames - Bitrate: 4,396 Kbs - [15:08:32] Reencoding: VID_00101, Pass 1 of 1 - [15:09:17] Video Encode complete - [15:09:17] Reencoding audio tracks (if req'd) - [15:09:17] Multiplexing M2TS - [15:09:18] Extracting A/V streams [VID_00104] - [15:09:25] Reencoding: VID_00104 (8 of 10) - [15:09:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,012 frames - Bitrate: 4,434 Kbs - [15:09:25] Reencoding: VID_00104, Pass 1 of 1 - [15:10:10] Video Encode complete - [15:10:10] Reencoding audio tracks (if req'd) - [15:10:11] Multiplexing M2TS - [15:10:12] Extracting A/V streams [VID_00205] - [15:10:13] Reencoding: VID_00205 (9 of 10) - [15:10:13] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 120 frames - Bitrate: 3,690 Kbs - [15:10:13] Reencoding: VID_00205, Pass 1 of 1 - [15:10:15] Video Encode complete - [15:10:15] Reencoding audio tracks (if req'd) - [15:10:15] Multiplexing M2TS - [15:10:16] Extracting A/V streams [VID_04999] - [15:10:21] Reencoding: VID_04999 (10 of 10) - [15:10:21] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 720 frames - Bitrate: 4,481 Kbs - [15:10:21] Reencoding: VID_04999, Pass 1 of 1 - [15:11:09] Video Encode complete - [15:11:09] Reencoding audio tracks (if req'd) - [15:11:09] Multiplexing M2TS [15:11:11]PHASE ONE complete [15:11:11]PHASE TWO - Rebuild Started - [15:11:11] Rebuilding BD file Structure [15:11:28] - Encode and Rebuild complete [15:11:28]JOB: TALL_DARK_STRANGER finished. Last edited by jdobbs; 11th June 2011 at 00:13. |
