Old 16th January 2010, 01:03   #3081  |  Link
Havokdan
Havokdan's Avatar
@Havokdan
So the temp dir was ending with 'temp files' and it wasn't deleted even though the option was enabled, the log file was in the target dir?
Let's see, when the temporary folder in the hd is my operating system (Unit "E") they are not deleted after the end of the operation, even if this option is checked and the log in the temporary folder in this case.
Even when I set the temporary folder to "C" drive (NTFS - empty, no operating system), the folders are deleted and the log goes to target dir as you said.
For me this is no problem, but I found this strange behavior.
Havokdan is offline
Old 16th January 2010, 09:25   #3082  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
i been running different projects and the errors seem to be related to DGIndexNV cause i havent been able to duplicate it with any of the other indexers hope that helps
MuLTiTaSK is offline
Old 16th January 2010, 10:33   #3083  |  Link
Desaster Dan
Desaster Dan's Avatar
x264_wrapper
@multitask
did a 2 pass coding last night, with the x264_64 workarround.
The result looks this way:
To crosscheck i muxxed the compcheck.h264 into mkv this morning.
This one looks normal.
what's that?
@Stax
Maybe it is a good idea to stick native x264_64 support inside Staxrip.
Desaster Dan is offline
Old 16th January 2010, 11:54   #3084  |  Link
Maeggor
StaxRip doesnt initiate in Win7 x64
Hi people
I have used this fantastic program in XP without problems but I have update my system to Win7 x64 and the 1.1.3 doesnt initiate when I click it
Any ideas or you have the similar problem¿
Thanks!
Maeggor is offline
Old 16th January 2010, 13:31   #3085  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Desaster Dan
please post the .log for that project
Old 16th January 2010, 13:35   #3086  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Maeggor
where you using any other version before 1.1.3 on Win7 x64?
Old 16th January 2010, 15:07   #3087  |  Link
Maeggor
Originally Posted by MuLTiTaSK View Post
@Maeggor
I dont know what you mean!
In the same computer (with the same hardware but only adding a SSD) and with Windows XP 32bits, and 1.1 Staxrip version!
Maeggor is offline
Old 16th January 2010, 15:32   #3088  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Maeggor
download this .NET Version Detector copy and paste the results here
Old 16th January 2010, 15:51   #3089  |  Link
stax76
stax76's Avatar
StaxRip wouldn't do anything different than what the workaround does. I don't have x64 so couldn't test it. Such issues are exactly the reason why it's not supported directly, higher potential for hard to track bugs, same issue with patched x264 builds.
The error handling was intended to be improved so if the source fails to load it will automatically try ffms2 without blocking which is useful for batch processing. There was a bug however causing this not working correctly not even showing a message about the error but only write it to the log file which finally gave me a idea what was happening. It applies to most errors, not only dgi.
@Havokdan
so was the temp dir ending with 'temp files', only then it gets deleted and using the file browser instead of manually entering always results in a 'temp files' ending.
stax76 is offline
Old 16th January 2010, 15:53   #3090  |  Link
Zathor
with this workaround i'am noticing a speed increase of about 8% a very nice boost
maybe you can add a option for the user to choose what build to use x86 or x64 depending on there cpu then have StaxRip avs4x264.exe->x264.exe(x86) or avs4x264.exe->x264_64.exe(x64)
You have to use vfw4x264.exe instead of avs4x264.exe. If you use avs4x264.exe some videos look like the one from Desaster Dan. I can reproduce it with mpeg2 videos with DGDecode_mpeg2source. There is no know problem with vfw4x264 and even with the new x264 1391 build with no vfw input support (removed since 1379) it is still working.
Zathor is offline
Old 16th January 2010, 15:56   #3091  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Zathor
i was just able to reproduce this
Old 16th January 2010, 15:56   #3092  |  Link
Desaster Dan
@Multitask
Here we go:
Stream Type: Program
Video Type: MPEG2
Profile: main@main
Coded Size: 720x576
Display Size: [not specified]
Aspect Ratio: 16:9 [3]
Frame Rate: 25.000000 fps
Colorimetry: BT.470-2 B,G*
Frame Structure: Frame
Frame Type: I
Coded Number: 179174
Playback Number: 179174
Frame Repeats: 0
Field Repeats: 0
Bitrate: 5.672
Bitrate (Avg): 4.883
Bitrate (Max): 7.428
Audio Stream: 80: AC3 3/2 48 448
Audio Stream: 81: AC3 3/2 48 448
Audio Stream: 83: AC3 1/0 48 192
Audio Stream: 8a: DTS C+L+R+SL+SR 48 768
Elapsed: 0:04:31
Remain: 0:00:00
FPS:
Info: Finished!
Oops, too late ;o)
Old 16th January 2010, 15:59   #3093  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Desaster Dan
vfw4x264.exe->x264.exe
Old 16th January 2010, 16:01   #3094  |  Link
stax76
stax76's Avatar
@MuLTiTaSK
Do you have experience with MakeMKV? I'm ripping some Tom Cruise Nazi Film right now, first Blu-ray rip. I don't have AnyHD.
stax76 is offline
Old 16th January 2010, 16:06   #3095  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
!!URGENT!! x264 x64 DGDecode FIX !!URGENT!!
@StaxRip Nation
to use x64 builds of x264 in StaxRip follow this very simple workaround
1)download x264x64 Wrapper by alwa
2)rename vfw4x264.exe->x264.exe then place it in x264 folder
3)download x64 build of x264 from your favorite builder
4)rename build to x264_64.exe then place it in x264 folder as in step 2
DONE!
Old 16th January 2010, 16:10   #3096  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
welcome to the world of Blu-ray
Inglourious Basterds is a funny flick you having troubles with MakeMKV?
Old 16th January 2010, 17:57   #3097  |  Link
Desaster Dan
Speeeeed
@multitask
Thank you,
It's running like hell now on My Gforce 9600
~95 fps on first pass
~25 fps on second pass.
Old 16th January 2010, 18:01   #3098  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Desaster Dan
nice speeds x264x64 builds give a nice boost
Old 16th January 2010, 18:07   #3099  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
you using MakeMKV 1.4.11
Old 16th January 2010, 18:18   #3100  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@stax76
Download latest MakeMKV combined SVQ file for BD+
Usage
In order to use SVQ file just download it into "SVQ directory" set in MakeMKV preferences (on BD+ tab). MakeMKV will automatically pick-up the SVQ file and all discs that are enabled in SVQ file will start working. You must set "SVQ directory" in preferences, but you need to do it only once.
gui, h.264, h.265, hevc, mkv, x264, x265
