21st January 2011, 10:13 | #41 | Link |
Yes, HD 4000 series. It doesn't support a workgroup size of 256. There's a way round this so there's a decent chance I'll make an additional path specifically for that series, when I do other changes I'm planning.
21st January 2011, 22:24 | #43 | Link |
Have a collection of DV home videos - quite a lot of it shot in low light conditions thus noisy. Over last few days extensively tested FFT3Dfilter with various setting to improve the videos.
Found about Deathray and was eager to test it, because had read promising things about NLM denoising. For testing i wrote simple script that loops 100+ frames thru filter at different settings and outputs filtered video + video with original minus filtered image (contrast enlarged). This gives very good visual of what filter is doing without much pixel peeking. If filter removes only white noise, then only white noise appears in differential image. If there is some structure visible then either that area is not denoised or denoised more or some structure degradation is happening. I am testing only luma channel for now. Win7 64bit, ATI Radeon HD57xx 1Gb RAM latest versions of Catalyst and Stream SDK installed yesterday. Today experimented with Deathray for an hour or so and not a single crash/problem. Some observations (based on my noisy dark video sampe). In low temporal settings - ty = 1,2 there are substantial areas which are not denoised at all. Going up to tY=5 improves, but there are still areas which are less denoised. FFT3DFilter is better in this respect, as there is much less structure in the noise removed. I tested deathray up to ty=5, hy=2 and s = 1. I could not see difference between hy 1.5 and 2. Will go up from there later. Deathray was removing about same amount of noise as FFT3Dfilter, but much differently - FFT removed noise was mostly high contrast pixels, where Deathray removed less contrasted pixels and left high contrast noise. As result FFT3Dfilter produced smoother picture. Higher contrast gives effect of seemingly more detail in deathray'ed picture, but it is less pleasing to look at because of high contrast noise. Neither of filters at reasonable settings take away any structure. I noticed that FFT3 tends to denoise more areas which Deathray tends to avoid and tested FFT3 on deathrayed video. This produced most pleasing result as FFT3 removed high contrast pixels. Both filters seem somehow to complement each other. As of now i would not use Deathray alone because of the high contrast noise. On neither of filters i used extreme settings as i prefer some grain to complete smootheness. I upload some screenshots, but static images do not really give a good impression - moving image is much better and informative. Here is simple script i use for testing. Code:
fr = 100 # number of frames to be looped sigma_start = 0.5 # start value for sigma range sigma_incr = 0.1 # sigma increment sigma_finish = 1.0 # end value for sigma range hY_start = 2.0 # denoise strength luma hY_finish = 2.0 # denoise strength luma tY = 5 # temporal radius luma c = DirectShowSource ("2001 03 229.avi", audio=false).viewfields.crop(0,0,-0,-288).trim (0,fr).grayscale.converttoyv12 gray = BlankClip(c, length=fr, color = $808080) cf = BlankClip(c, 0) co = BlankClip(c, length=0) co = Stackvertical (co,co) GScript (""" while (hY_start <= hY_finish) { ssigma = sigma_start while (ssigma <= sigma_finish) { if (FrameCount(cf) > 0) {NOP} else {cr = gray} cf = deathray (c, hy = hY_start, huv = 0.0, ty = tY, s =ssigma) cd = subtract (c, cf) Stackvertical ( \ cf.Subtitle("sigma = " + String(ssigma) + "\n hY = " + String(hY_start)+ "\n tY = " + String(tY), align=6, lsp=0), \ cd.histogram(mode="luma").Subtitle("Difference original - filtered", align=9, lsp=0)) co = co + last ssigma = ssigma + sigma_incr } hY_start = HY_start + 1 } """) return (co) |
22nd January 2011, 12:28 | #44 | Link | ||||||
Though I've been doing it by hand, single stepping through clips and tweaking parameters. My reference filter, for what it's worth, is FizzKiller. Have you evaluated motion-compensated MDegrain (from MVTools 2)? It's slow, but extremely good. Obviously I also make encodes and watch them, too. Quote:
It's too weak at settings that are required not to destroy fine detail. The most recent "NVidia Debug" version contains a crude averaging with the original image. This is considerably better, but the averaging I'm using is not the averaging that is described here: http://hal.archives-ouvertes.fr/docs...le_revised.pdf I'm currently getting my head round that. The NVidia Debug version (110120004) is preferable to 1.00. Quote:
The sample-radius factor, x, is also useful, but has to be used with care (turn h up to 1000 and set x=3 to see what I'm talking about). A planned change to the filter incidentally makes x safer, though truthfully with sane values of h and s, x=2 or 3 is quite safe (and slow...). I think temporal 5 is too strong. I hope the regression correction I'm working on is worth it. It should require re-evaluation of settings... Quote:
Generally I would say don't rush and use lots of test clips. --- A little sidenote on one aspect of the NVidia "problems". The problem with the max() function turns out to be a difference between OpenCL 1.0 and OpenCL 1.1. |
14th December 2011, 00:09 | #46 | Link | |
14th December 2011, 01:02 | #49 | Link |
Rather than try to recreate the post I just lost, I'll just briefly link this, which is DeathrayNV110120004.zip:
http://www.mediafire.com/?yyiaqbqp77h236p This is just the DLL. It is a slightly different algorithm (which I think is better) and it solves the original problem with failure on NVidia. This version of the DLL always creates a deathray.log file. If there are problems this file should help me help you. I have a caveat: when I wrote this OpenCL code AMD's and NVidia's compilers were a little bit loose. I think they are stricter now and there's a chance this will not compile with recent drivers. I didn't fix this issue due to a general lack of interest, so this may be more of an experiment than you wanted. Fingers-crossed! EDIT: oh yeah, my website is down because my host took it down for going over the 250MB daily limit |
17th November 2012, 10:46 | #51 | Link |
No news, dead due to lack of interest (mostly my lack of interest, it seems).
My lack of interest is due to the fact that I prefer the results from MDegrain. My website is available. There are 3 files: Deathray_1_00.zip - see post 1 Deathray_1_00_DLL.zip - see post 1 DeathrayNV110120004.zip - see post 36 Please note that the source code I've provided in post number 1 does not match the source code for post 36. Please read the entire thread to learn how best to use this. For the best quality I recommend DeathrayNV110120004.zip. This contains a tweaked algorithm (hence the improved quality) as well as a fix to ensure it works on NVidia. This DLL works with AMD, too. The downside with this version is that it creates a deathray.log file in the same folder as the Avisynth script. I have no idea whether Deathray works with recent AMD or NVidia drivers. In theory the newest drivers will reject my code because they are more strict. Obviously, anyone is welcome to play with the code. |
17th November 2012, 13:09 | #52 | Link | |
you mean MVTools+MDegrain...¿?
---Intel i5 3570k --Asrock z77 ext. 4 --Skill 4x4GB dd3 --amd r9 270 --S.O Gentoo & Win 8.1 64bits --Dell u2414h"
17th November 2012, 18:42 | #53 | Link |
契約者
So how about porting Mdegrain to gpu then? Porting motion search proved to be possible and if i'm not mistaken its opensource (since mvtools is opensource). But they had different purpose and ported only mflowfps(and renderer part of that is closed source). However they claim their motion search is better than original, which I so far can't see, unfortunately. So maybe it requires some tweaks.
17th November 2012, 19:10 | #54 | Link | |
One of those things I just didn't get round to, and now behind other things.
I logged on to this forum today for the first time in quite a while and discovered VapourSynth. Previous time I logged in, I discovered people are doing 10-bit encodes. I'm out of touch. Quote:
16th July 2013, 21:34 | #55 | Link |
Git repository
I've just realised I could make a git version of this:
Deathray on github.com This is v1.00 without any of the bug fixes or improvements that I created during the debugging work done for NVidia users. It's also for an ancient SDK. It will definitely require work to get it working with latest drivers and/or SDKs. --- And for those of you who understand Git branches, the branch called FindFixes is my attempt to identify the code that makes the DeathrayNV110120004 version. Last edited by Jawed; 16th July 2013 at 23:55. |
24th August 2013, 05:30 | #56 | Link |
i have a question.
I just brought a new nvidia graphic for encoding purposes, and when I did test on both deathray and nlmeanscl with avsmeter, the default nlmeanscl setting gave me 252fps with 70% gpu loaded, while deathray in default setting gave me 47fps and over 90% gpu loaded. It makes me wonder what's the difference between the two to have a huge different in speed like this? |
24th August 2013, 10:53 | #57 | Link | ||
Alternatively a temporal radius of 2 would produce 100% GPU usage (tY=2, tUV=2) on standard definition clips. Because I coded for AMD, it uses on-chip memory in a way that's potentially "unfriendly" towards NVidia. In other words I took advantage of the very large register capacity on AMD and I wouldn't be surprised if NVidia cards ran out of registers. The newest NVidia cards (Kepler) have much better register capacity, so in theory even if this was a problem a few years ago, it shouldn't be a problem for the latest NVidia cards. Due to lack of interest, no performance comparisons were made between AMD and Nvidia, so I don't know if this is really true or not. I don't know the size of the window in nlmeanscl. Deathray uses a 7x7 size, and the larger it is the more effort involved. Also I don't know the search area in nlmeanscl. Deathray does not search the entire frame to get other 7x7 windows, it only searches near the pixel being filtered (it looks at 48 other 7x7 windows). Again, searching more of the frame is more effort. In fact searching the entire frame is counter-productive, it is better to search a limited area near the pixel being filtered. I don't think there's much point in the nlmeans algorithm. It is only mildly useful when used with temporal settings and pretty much a waste of time without temporal settings. I prefer MDegrain, which is why I don't use Deathray. Do you like the results of either Deathray or nlmeanscl? Do you prefer it when you use temporal settings? Have you used MDegrain? |
24th August 2013, 16:07 | #58 | Link |
mdegrain didn't fit my taste in which it manipulated the image too much. It's going to be either a hit or miss. On moving scene, sometime it gives a good result, and sometime it smooths out the original shape.
I'd did some test with this sample, i uploaded here: sample Both deathray and nlmeanscl pretty much gave the same result, except in some low light area with thin lines, deathray at default desaturated the color by a little. This sample also gives the reason why i don't use mdegrain, notice the panning scene from 2-6 second, there're some spider webs across the screen. When i used smdegrain, it pretty much wiped out half of them. While deathray and nlmeanscl still preserved them. well on the temporal side, smdegrain did a better job at calming the grains. Last edited by lansing; 24th August 2013 at 16:10. |
24th August 2013, 21:56 | #59 | Link |
Not Deathray
I trimmed off the first frame, which is broken:
http://www.mediafire.com/download/0w..._sample_JA.mp4 I have to say I'm horrified that apparently recent anime can be such a disaster zone. |
