Old 20th January 2011, 00:46   #21  |  Link
Jawed
Originally Posted by TheProfileth View Post
Really want to test this filter out, so I will hope you fix it soon
also I am able to get nlmeanscl to run fine on my computer, I have a GTX 260 and a AMD Phenom quad core
Thanks for your report.
I don't know why but AvsP has that trouble when Deathray throws an error message. Playing the script in MPC is fine, reporting the messages that the others have posted.
In my experience, sometimes that message is true, there really was a null pointer access. I just can't tell.
In SingleFrameInit Deathray has tried to create two buffers on the GPU, input and output, for each of the 3 planes - so 6 in total. It does this once when Deathray is loaded and re-uses them for each frame.
Jawed is offline   Reply With Quote
Old 20th January 2011, 01:43   #22  |  Link
Jawed
Oh, I've just noticed from ChaosKing's capabilities dump that GTX260 is OpenCL 1.0.
I will have to research the differences between 1.0 and 1.1 to see if I've done something 1.1 that's causing problems for 1.0 cards. The obvious thing, the size of local memory, shouldn't be an issue. I'm allocating ~11KB of local memory out of the 16KB available on OpenCL 1.0 devices.
I'm doubtful this is the source of the problem, but...
Old 20th January 2011, 01:58   #23  |  Link
Jawed
ARGH
I've just discovered that if the DLL is named Deathray.DLL it's OK, but if the DLL is named like the debug versions I provided earlier, it fails.
SIGH. I forgot that Deathray asks Windows for a handle to "Deathray.dll" as part of compilation. So this has wasted quite a bit of time. Sorry.
Versions 3 or 4 may actually work if the NV110119003/4 suffix is deleted. That's what I get for testing before renaming the file for distribution.
Old 20th January 2011, 02:19   #24  |  Link
TheProfileth
Leader of Dual-Duality
TheProfileth's Avatar
ooh let me try
Edit:
damn, renaming it did not work by renaming them
I'm Mr.Fixit and I feel good, fixin all the sources in the neighborhood
My New filter is in the works, and will be out soon
TheProfileth is offline   Reply With Quote
Old 20th January 2011, 13:42   #25  |  Link
Jawed
If someone can report the error status numbers from the 4th debug DLL I uploaded, that would be cool, thanks.
Old 20th January 2011, 15:37   #26  |  Link
ChaosKing
debug v4: Single-Frame initialisation failed, status=6 and OpenCL status= -48
I also updated to the newest Nvidia driver, but it changed nothing.
Old 20th January 2011, 16:27   #27  |  Link
Jawed
That error happens to correspond with the DLL filename being wrong, although of course it could be the real error.
Please make sure that the DLL is called deathray.dll and that there is only one deathray DLL in the plugins folder.
If that doesn't solve the problem, then I need to make an even simpler piece of code to test the OpenCL compilation.
Old 20th January 2011, 19:01   #28  |  Link
ChaosKing
I tested both filenames (also deleted other deathray* dlls), same error :/
Old 20th January 2011, 19:29   #29  |  Link
Jawed
Thanks very much for your patience.
OK, this version of Deathray will produce a file called Deathray.log. This file appears in the same folder as your Avisynth script.
This file contains the output from the OpenCL compiler, if an error occurs during compilation. If no error occurs, the file will have 0 bytes as its file size.
www.cupidity.f9.co.uk/DeathrayNV110120001.zip
If Deathray.log contains some text it would be useful if you can post the text here. Thanks.
Old 20th January 2011, 20:58   #30  |  Link
ChaosKing
Here's my Debug Log:
<program source>:300:22: error: no matching function for call to 'max'
        int2 sample_start = max(target - sample_radius, 3);
<built-in>:3696:26: note: candidate function
ulong16 __OVERLOADABLE__ max(ulong16, ulong16);
<built-in>:3695:25: note: candidate function
ulong8 __OVERLOADABLE__ max(ulong8, ulong8);
<built-in>:3694:25: note: candidate function
ulong4 __OVERLOADABLE__ max(ulong4, ulong4);
<built-in>:3690:25: note: candidate function
ulong2 __OVERLOADABLE__ max(ulong2, ulong2);
<built-in>:3689:25: note: candidate function
long16 __OVERLOADABLE__ max(long16, long16);
<built-in>:3688:24: note: candidate function
long8 __OVERLOADABLE__ max(long8, long8);
<built-in>:3687:24: note: candidate function
long4 __OVERLOADABLE__ max(long4, long4);
<built-in>:3683:24: note: candidate function
long2 __OVERLOADABLE__ max(long2, long2);
<built-in>:3682:25: note: candidate function
uint16 __OVERLOADABLE__ max(uint16, uint16);
<built-in>:3681:24: note: candidate function
uint8 __OVERLOADABLE__ max(uint8, uint8);
<built-in>:3680:24: note: candidate function
uint4 __OVERLOADABLE__ max(uint4, uint4);
<built-in>:3676:24: note: candidate function
uint2 __OVERLOADABLE__ max(uint2, uint2);
<built-in>:3675:24: note: candidate function
int16 __OVERLOADABLE__ max(int16, int16);
<built-in>:3674:23: note: candidate function
int8 __OVERLOADABLE__ max(int8, int8);
<built-in>:3673:23: note: candidate function
int4 __OVERLOADABLE__ max(int4, int4);
<built-in>:3669:23: note: candidate function
int2 __OVERLOADABLE__ max(int2, int2);
<built-in>:3668:27: note: candidate function
ushort16 __OVERLOADABLE__ max(ushort16, ushort16);
<built-in>:3667:26: note: candidate function
ushort8 __OVERLOADABLE__ max(ushort8, ushort8);
<built-in>:3666:26: note: candidate function
ushort4 __OVERLOADABLE__ max(ushort4, ushort4);
<built-in>:3662:26: note: candidate function
ushort2 __OVERLOADABLE__ max(ushort2, ushort2);
<built-in>:3661:26: note: candidate function
short16 __OVERLOADABLE__ max(short16, short16);
<built-in>:3660:25: note: candidate function
short8 __OVERLOADABLE__ max(short8, short8);
<built-in>:3659:25: note: candidate function
short4 __OVERLOADABLE__ max(short4, short4);
<built-in>:3655:25: note: candidate function
short2 __OVERLOADABLE__ max(short2, short2);
<built-in>:3654:26: note: candidate function
uchar16 __OVERLOADABLE__ max(uchar16, uchar16);
<built-in>:3653:25: note: candidate function
uchar8 __OVERLOADABLE__ max(uchar8, uchar8);
<built-in>:3652:25: note: candidate function
uchar4 __OVERLOADABLE__ max(uchar4, uchar4);
<built-in>:3648:25: note: candidate function
uchar2 __OVERLOADABLE__ max(uchar2, uchar2);
<built-in>:3647:25: note: candidate function
char16 __OVERLOADABLE__ max(char16, char16);
<built-in>:3646:24: note: candidate function
char8 __OVERLOADABLE__ max(char8, char8);
<built-in>:3645:24: note: candidate function
char4 __OVERLOADABLE__ max(char4, char4);
<built-in>:3641:24: note: candidate function
char2 __OVERLOADABLE__ max(char2, char2);
<built-in>:3640:27: note: candidate function
double16 __OVERLOADABLE__ max(double16, double16);
<built-in>:3639:26: note: candidate function
double8 __OVERLOADABLE__ max(double8, double8);
<built-in>:3638:26: note: candidate function
double4 __OVERLOADABLE__ max(double4, double4);
<built-in>:3634:26: note: candidate function
double2 __OVERLOADABLE__ max(double2, double2);
<built-in>:3633:26: note: candidate function
float16 __OVERLOADABLE__ max(float16, float16);
<built-in>:3632:25: note: candidate function
float8 __OVERLOADABLE__ max(float8, float8);
<built-in>:3631:25: note: candidate function
float4 __OVERLOADABLE__ max(float4, float4);
<built-in>:3627:25: note: candidate function
float2 __OVERLOADABLE__ max(float2, float2);
<built-in>:3474:27: note: candidate function
double16 __OVERLOADABLE__ max(double16 x, double y) ;
<built-in>:3473:27: note: candidate function
double8  __OVERLOADABLE__ max(double8 x, double y)   ;
<built-in>:3472:27: note: candidate function
double4  __OVERLOADABLE__ max(double4 x, double y)   ;
<built-in>:3468:27: note: candidate function
double2  __OVERLOADABLE__ max(double2 x, double y)   ;
<built-in>:3458:26: note: candidate function
float16 __OVERLOADABLE__ max(float16 x, float y) ;
<built-in>:3457:26: note: candidate function
float8  __OVERLOADABLE__ max(float8 x, float y)   ;
<built-in>:3456:26: note: candidate function
float4  __OVERLOADABLE__ max(float4 x, float y)   ;
<built-in>:3452:26: note: candidate function
float2  __OVERLOADABLE__ max(float2 x, float y)   ;
<built-in>:3449:24: note: candidate function
ulong __OVERLOADABLE__ max(ulong, ulong);
<built-in>:3448:23: note: candidate function
long __OVERLOADABLE__ max(long, long);
<built-in>:3447:23: note: candidate function
uint __OVERLOADABLE__ max(uint, uint);
<built-in>:3446:22: note: candidate function
int __OVERLOADABLE__ max(int, int);
<built-in>:3445:25: note: candidate function
ushort __OVERLOADABLE__ max(ushort, ushort);
<built-in>:3444:24: note: candidate function
short __OVERLOADABLE__ max(short, short);
<built-in>:3443:24: note: candidate function
uchar __OVERLOADABLE__ max(uchar, uchar);
<built-in>:3442:23: note: candidate function
char __OVERLOADABLE__ max(char, char);
<built-in>:3441:25: note: candidate function
double __OVERLOADABLE__ max(double, double);
<built-in>:3440:24: note: candidate function
float __OVERLOADABLE__ max(float, float);
Old 20th January 2011, 22:12   #31  |  Link
Jawed
Ooh, that should be a simple fix. Fingers crossed it's the last thing.
First, try this:
www.cupidity.f9.co.uk/DeathrayNV110120002.zip
This contains a fix for the bug above. I think it's my fault, I think the AMD compiler is mistakenly accepting that line as valid.
If that works, then try this:
www.cupidity.f9.co.uk/DeathrayNV110120003.zip
It will actually filter the video instead of doing nothing to it. It will do spatial or temporal, so all the options are available. It also produces the log file, so let's hope that it's empty.
The filtering is different from version 1.00. This is an experimental linear correction. I don't think the math is correct though, so I'm still working on it. Despite that I prefer it to version 1.00...
Old 20th January 2011, 22:15   #32  |  Link
TheProfileth
Will test now
Edit:
Woohoo it works!
time to take a look at this thing
Edit2:
Works pretty well, and retains decent details,
http://screenshotcomparison.com/comparison/21410
http://screenshotcomparison.com/comparison/21411
my only issue is that if something is surrounded by black, the area it sort of gets washed into it
the color sort of gets sucked out of those areas too
I wonder if there is a way to give things that border black areas more weight
Old 20th January 2011, 22:27   #33  |  Link
Jawed
Yay. Thanks guys. Hope it works for you all.
I'll produce a proper version 1.01 tomorrow, probably.
Old 20th January 2011, 22:36   #34  |  Link
ChaosKing
Yeah it works!
I get 28~ fps on my gtx260
I will play with the filter tomorrow.
Old 20th January 2011, 22:39   #35  |  Link
Didée
Aaahh, waitaminute ...
With 110120003:
Avisynth read error:
"Single-frame initialisation failed, status=6 and OpenCL status=-48"
log:
:310: error: incompatible type initializing 'int', expected 'float4'
                        float4 euclidean_distance = 0;
:396: error: incompatible type initializing 'int', expected 'float4'
        float4 average = 0;
:397: error: incompatible type initializing 'int', expected 'float4'
        float4 weight = 0;
Old 20th January 2011, 22:53   #36  |  Link
Jawed
Sigh, I'm normally over-zealous with zeroes.
Try this:
www.cupidity.f9.co.uk/DeathrayNV110120004.zip
Old 20th January 2011, 22:59   #37  |  Link
Jawed
Try more temporal, 2 or 3. Also don't be afraid to lower s (sigma) and increase h at the same time.
It's a bit tricky. Version 1.00 is a lot harder to use and inferior. As I say, I'm still working on the linear correction.
Old 20th January 2011, 23:06   #38  |  Link
Didée
Hooray, that 110120004 finally works for me, too.
Old 20th January 2011, 23:14   #39  |  Link
Jawed
Great.
Just need to get my brain around the variance of a single sample and get the linear correction working. Then ponder whether I want to attempt a first or second order regression correction. Gulp.
Old 21st January 2011, 08:52   #40  |  Link
aNToK
Hi, read in the literature that this doesn't work with AMD 4xxx series, but wasn't clear whether that was the regular Radeon 4xxx series or the HD 4xxx series. Did you mean the HD ones as well?
aNToK is offline   Reply With Quote
