Old 11th February 2012, 06:48   #8961  |  Link
MaxMan23
Hi, i have a problem with lav 0.45 and cuvid. i get no video (black screen) when cuvid is selected in the settings (dxva2 works). Tested with mediaportal und mpc. But why? My PC is a q6600 @ 3.6 ghz, Geforce 560 Ti
MaxMan23 is offline   Reply With Quote
Old 11th February 2012, 07:09   #8962  |  Link
boyumeow
boyumeow's Avatar
Xvid do not work with nvidia driver more than 285, if I'm not wrong. Thanks.
boyumeow is offline   Reply With Quote
Old 11th February 2012, 09:31   #8963  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by RBG View Post
ryrynz
I just tried, and I have no delay opening files over the network with File Source Async in the chain, well at least with Windows Server and gigabit ethernet.
I know it's an issue limited to my HTPC but I don't know what's causing it, was just wondering if anyone had seen it before.
What driver version you using? What is the file type are your attempting to play back? Tried a fresh install of LAV filters?
Old 11th February 2012, 09:32   #8964  |  Link
nevcairiel
If you dont have issues using LAV as the source directly -> problem solved?
Old 11th February 2012, 09:57   #8965  |  Link
Tacio
How can I use LAV Splitter Source as file source instead File Source Async? I set Prefer merit for LAV Splitter Source and block File Source Async, but mpc shows that it can't render stream at all. In LAV Splitter Source I checked all formats.
Tacio is offline   Reply With Quote
Old 11th February 2012, 10:04   #8966  |  Link
nevcairiel
You need to install via the Installer, it'll set that up automatically.
Old 11th February 2012, 10:39   #8967  |  Link
cremor
Could there be a bug in the installer that was introduced in one of the last few versions?
I'm using all four "LAV x" external filter options as prefer in MPC-HC since I started using LAV and previously that was everything that was needed. But some time ago I noticed that AVIs are using File Source Async (and LAV Splitter) whereas MKVs still use LAV Splitter Source.
I didn't change any of the format options in the installer or the splitter configuration.
cremor is offline   Reply With Quote
Old 11th February 2012, 10:48   #8968  |  Link
nevcairiel
You may have installed something else that reset the extension mapping. In any case, the next version has a basically completely rewritten installer, so if there were bugs, they are no more (but i'm sure new ones instead!)
Old 11th February 2012, 15:25   #8969  |  Link
MaxMan23
My driver version is 290.36 and the files are xvid (avi).
Old 11th February 2012, 15:27   #8970  |  Link
nevcairiel
If you activate CUVID acceleration for XVID, you do so at your own risk. If it doesn't work, turn it off.
There is a reason its off by default, because it doesnt work properly.
Old 11th February 2012, 16:34   #8971  |  Link
RBG
Actually on forceware 285.62 I haven't encountered any problems yet, everything plays fine. Can you upload any DivX/Xvid sample which can not be played, I wanna test it.
RBG is offline   Reply With Quote
Old 11th February 2012, 18:08   #8972  |  Link
zerowalker
Can you fix the Splitter to prevent it from crashing Recycle bin and COM Surrogate?
Or is it something i myself can fix?
Sorry asked this before;O
zerowalker is offline   Reply With Quote
Old 11th February 2012, 18:15   #8973  |  Link
nevcairiel
You have to find out which file it crashes on, and then send me a sample of such a file.
Old 11th February 2012, 19:24   #8974  |  Link
zerowalker
Itīs pretty much every file i think, as long as i try to make a thumbnail of it;S
It may also be MKV files which i Direct Stream copied so they became "AVI" that mess up.
But itīs the thumbnail thing i think, and if i deactivate AVI splitting on LAV itīs solved, though i want to use it;S
Old 11th February 2012, 20:03   #8975  |  Link
dead_screem
I have a hard-limit of i think 125 fps, if the header reported value is above that i don't trust it and use the (somewhat inaccurate) measured value (417225 isn't exact)
This is also the reason why i rather use the timestamps instead of basing any calculations on the fps.
Hmmm, does the fact that this file is VFR further make calculations difficult? I notice lav sets 23.968fps should anything be added that would round the calculated fps to a more standard value such as 23.976 in this case?
Also does the fact that this was a mov>mp4 re-mux have any thing to do with that the file is broken?
dead_screem is offline   Reply With Quote
Old 11th February 2012, 20:11   #8976  |  Link
nevcairiel
Well as i've stated numerous times before, the fps in the mediatype is just a hint, its not to be taken as absolute truth.
The MSDN even says that for VFR is perfectly valid for this value to be zero, however that seems to not work with alot of decoders/renderers.
In any case, i try to supply a somewhat valid value, but if the header information are totally screwed up, i just give it what ffmpeg measured from the first few frames, which may or may not be very accurate.
How the actual frames are timed is entirely up to the timestamps, not the fps value - at least if the decoder is doing a proper job, which is why the fps aren't all that important.
Just calculating from fps would most likely not work properly with VFR anyway, not to mention cases of missing frames like with Live TV (or recordings of that)
PS:
The header info inside the H264 data seems to be broken, don't think a remux would cause that, but i guess everything is possible.
Old 11th February 2012, 20:44   #8977  |  Link
entrecour
nevcariel, First of all Thank You for LAV!
I think I have found a problem with LAV Video on certain titles.
I get video corruption (pixelation? incomplete decoding?) occasionally on X-Men BD's (I have seen the problem on 2 or 3 different titles).
Here is a screenshot
I do not get this problem with Microsoft Dtv-Dvd decoder.
This is on Windows 7 32bit, Intel i3 (no external video card, no hardware acceleration).
General
Complete name                            : C:\Users\Public\Rip\XMEN_WOLVERINE\BDMV\PLAYLIST\00010.mpls
Format                                   : Blu-ray Playlist
File size                                : 786 Bytes
Duration                                 : 1h 47mn
Overall bit rate mode                    : Variable
Overall bit rate                         : 0
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : 27
Duration                                 : 1h 47mn
Bit rate mode                            : Variable
Maximum bit rate                         : 26.7 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 23.976 fps
Bit depth                                : 8 bits
Scan type                                : Progressive
Color primaries                          : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics                 : BT.709-5, BT.1361
Matrix coefficients                      : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Source                                   : 00074.m2ts
I have the LAV Splitter pin info if that helps.
I can upload a clip if needed (how long? what tool do you recommend to extract?).
Let me know if you need anything else.
entrecour is offline   Reply With Quote
Old 11th February 2012, 23:52   #8978  |  Link
clsid
Writing to HKCR\Media Type\{E436EB83-524F-11CE-9F53-0020AF0BA770} fails here for the AVI and mpeg-ps subkeys. The other keys are fine.
MPC-HC 2.2.1
Old 11th February 2012, 23:53   #8979  |  Link
nevcairiel
Probably protected by Windows, nothing i really want to override automatically. Even with UAC elevation those are hard to change.
Does the installer actually complain? If so, do you know how to shut it up?
For MPEG-PS, the installer is basically only writing the default windows values, so if its still protected, it should be fine.
For AVI, it writes the default windows values plus 2 extra values for more files. But overall, it should also not hurt if the write fails - as long as it doesnt complain to the user.
Old 12th February 2012, 00:14   #8980  |  Link
clsid
There is no user visible error. The functions will simply return false. It is just something I noticed and found strange since it used to work fine afaik when it was done by the filter. Error code is 5, which is access denied, so it indeed seems to be some kind of protection 'feature' of Windows.
MPC-HC 2.2.1
