19th March 2012, 23:18 | #12821 | Link | |
20th March 2012, 00:42 | #12822 | Link | |
I'm pretty sure about the cause though. Some "windows" that always present make madVR think that there are windows elements that are showing and thus does not go into exclusive mode. Those are Charmbar, Desktop, Start screen, etc. I occasionally get drop frames, but with ReClock it's very rare and I usually don't notice it when that happen, so I'm good with window mode. I have a similar setup: one LCD, one projector. I use one at a time and not extended/mirrored.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. Last edited by Hypernova; 20th March 2012 at 00:50. |
20th March 2012, 01:36 | #12824 | Link |
We might try to request an option to turn exclusive mode on regardless of what're on the screen, similar to what MPC-HC has for EVR stuff. I.e. Manual as oppose to automatic exclusive mode. If it's a quick enough job maybe madshi might consider that for the time being.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
20th March 2012, 11:44 | #12825 | Link | |
Btw, what is the difference between "upstream" and "bitstream" ? Is upstream the container? |
20th March 2012, 12:26 | #12826 | Link |
"Upstream" means the decoder supplied this information, while "bitstream" means madVR figured this out on its own from the format headers of the video.
21st March 2012, 20:12 | #12827 | Link |
Hi, I got a hang just now seeking in a bdmv. mpc-hc was still responsive, audio continued for a few minutes in the background, just the image froze. Also double clicking on the mpc-hc window to resize to fullscreen, I can see the image doesn't fill the screen so madVR isn't completing the resize to the full width of the screen while in this state.
http://pastebin.com/GTyQ9sAg I'm using mpc-hc 4164, madVR v0.82.5, LAV from here http://files.1f0.de/lavf/LAVFilters-...1-gd935c59.zip Apologies if it has nothing to with madVR. |
21st March 2012, 21:06 | #12829 | Link | |
Very few people will start playing a file and not seek or change some player option or fullscreen the video throughout playback from start to finish. |
21st March 2012, 21:23 | #12830 | Link | |
But now I was given information that it seems means I am not really using Madvr at all. "the dxva native option wont work with madvr" dxva is the only option that runs smoothly with my hd2600 pro. So is that true? Am I not really getting any benefits? Thanks |
21st March 2012, 21:49 | #12831 | Link | |
New version noticeably delays playback after seek, and I've always used low queues. |
21st March 2012, 23:20 | #12832 | Link | |
22nd March 2012, 04:18 | #12833 | Link |
@madshi
Seems Nvidia changed something very massively in the upcoming new 300 series Driver people report MadVr brakes entirely with a Black Screen http://forums.guru3d.com/showthread.php?t=360359 Though i dunno if they might left FXAA enabled and that Shader interferes with MadVR instead of just blurring everything causing a black screen possible
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 22nd March 2012 at 04:23. |
22nd March 2012, 05:53 | #12834 | Link |
Broadband Junkie
If the 300.99 Kepler drivers are causing madVR a black screen, I'd suspect it would have something to do with the new VSync modes, Adaptive VSync, and other VSync enhancements in that driver.
Edit: Looks like 301.10 Kepler drivers are out now as well. Last edited by cyberbeing; 22nd March 2012 at 11:59. |
22nd March 2012, 07:26 | #12835 | Link |
Madshi, I caught a crash I believe to be MadVR related. It happened on initial playback in MPC.
I just now had another MPC crash with an abnormal termination error window being displayed, the video and audio was still playing but the video output was playing back in slow stages as if the CPU was being stressed. I also get crashes when the next file is played in the folder which is most likely the same issue, using LAV with QuickSync and MPC build 4170. http://www.mediafire.com/download.php?o5o29wnxj329lc3 *Edit* The crash was most likely not MadVR related, I'm no longer having any issues. Last edited by ryrynz; 2nd April 2012 at 02:25. |
22nd March 2012, 12:07 | #12836 | Link | |
FXAA shouldn't be a problem neither, I suppose. Nvidia is aware of the issue but it should be faster if madshi takes a look, I guess. |
22nd March 2012, 12:48 | #12837 | Link |
Broadband Junkie
I don't believe you can fully disable VSync with madVR, at least in Windowed mode. A couple ways I could see madVR producing a black screen is if NVIDIA changed how the default D3D buffer flipping (VSYNC) modes function, or flat-out broke refresh-rate/scan-line reading. Hopefully it's nothing more serious like broken texture uploading/downloading.
Even if NVIDIA is aware of the issue, they don't always have a quick turnaround releasing driver fixes. Has anybody tested 301.10 yet? Same issue? Edit: I wonder is this even occurs with an actual GTX 680. Supposedly Adaptive VSync is only supposed to work with GTX 680, but people claimed to be using it with other cards. It's possible madVR not working is just a case of people incorrectly modifying the inf, and installing driver features which are unsupported by their hardware. Last edited by cyberbeing; 22nd March 2012 at 14:35. |
22nd March 2012, 16:32 | #12839 | Link |
Can somebody do a little sanity check for me on this file:
https://rapidshare.com/files/2764315045/clip_0.wtv It's a plain vanilla video recording, but regardless of whether I set deinterlacing: if in doubt activate, or automatic source detection: force film mode, I get the same result - it leaves the display in 60hz and leaves deinterlacing off. I can manually turn on deinterlacing or IVTC from the keyboard, but I can't tell if that results in a better picture. What's the preferred behavior in this case? |
22nd March 2012, 17:35 | #12840 | Link | ||
Forced off means off, no matter what applications want. Even in windowed mode. With AMD forcing Vsync off doesn't work. Quote:
301.10 is affected too. |
