9th September 2011, 09:52 | #9722 | Link |
This is on all content. I have pretty much default settings i think. i have enabled v-sync on my nvidia 570 and adjusted the flushing a bit in madvr. reclock is setting the content to 24frames. Madvr says it drops a frame about every 5minutes but i dont see them croping up in the stats. but i clearly see it if a frame is droped during panning shots. It seems like a commen problem not getting a perfect sync in this scenario.
any ideas? |
9th September 2011, 10:59 | #9724 | Link | |
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
9th September 2011, 17:02 | #9727 | Link | |
(I believe that the Cyberlink and Arcsoft decoders use DXVA and thus don't work with madVR. They are very tricky to make work outside of their players, anyway.) |
9th September 2011, 17:17 | #9728 | Link |
Not true for Cyberlink decoders. For AMD, it's the only decoder I know of to use GPU assisted software decoding. It's what I was using for a decoder until LAV Video was released. At least on my AMD machines. Works fine with madVR.
9th September 2011, 17:58 | #9729 | Link | |
Note, however, that LAV Video (as opposed to LAV CUVID) does not work with VC-1 interlaced (which is what the OP was inquiring about). |
9th September 2011, 17:59 | #9730 | Link |
Yup, that's absolutely true about VC-1i and LAV Video. Fortunately I don't have too much of that kicking around and J River's MC16 offers a smart way of handling that which is why I can use LAV Video and not worry about it.
9th September 2011, 19:20 | #9731 | Link |
I have a question about screen savers and blanking one of the screens in a dual monitor setup if only one of the monitors are being used to watch a clip in windowed or exclusive mode.
For example: I have a dual monitor setup in which I am watching a movie in exclusive mode on Monitor #2 and I am using Monitor #1 sometimes or not using it at all for long periods of time in which the screen still remains on. Normally if I don't move the mouse or touch the keyboard for 2 minutes then I have set the screen to "shut-off signal" and both monitors go blank. Is there a way to apply this same rule on Monitor #1 or Monitor #2 if only the other is being used with madVR? In other words, is it possible for Monitor #1 to shut-off signal and go blank if Monitor #2 is displaying a movie in exclusive mode? |
9th September 2011, 21:30 | #9733 | Link |
It doesn't do any deinterlacing, as far as i am aware.
9th September 2011, 21:54 | #9734 | Link | |
10th September 2011, 18:08 | #9737 | Link |
I seem to have a bit of lag and audio/video sync issues when i set my samsung ue40d6505 tv at 24z. ether with madvr or a blurayplayer. can any1 explain this? it dosnt do it in 60hz mode. this is regardles of content framerate.
Also motion interpolation dosnt work on the pc. It does with bluray and tv. The signal must be different somehow from that of the bluray player yes? I like to turn it up just at 1 setting out of 10 wich makes quete a difference yet keeping af film-feel. Is there a way to do adjustable motion interpoltion with mpc-hc madvr ect. and how does this work? I know i can set the tv to pc mode but its crap and unsuitable for watching movies from a pc. |
11th September 2011, 00:17 | #9739 | Link |
RGB levels problem
I'm trying to calibrate my LG 50PK550 using AVS HD 709 patterns.
I've fired up Black Clipping sample, ahd have a very strange problem. I set Black level to high on my LG(0-255). But if I tell madVR that my display expects 0-255, i only see bars 18-25 flashing. If I set to 16-235 then I see bars 2-25 flashing. Should that be other way around? Of course, if I set LG black level to low, I see only bars 18-25 flashing... My LG is connected through Marantz SR5004 receiver(maybe this causes problems), and HTPC is Zacate (AMD E-350 Fusion). |
11th September 2011, 01:08 | #9740 | Link |
Hi. I have a problem.
When I enable full screen and then minimize my player (potplayer), i get an error (resetting Direct3D device failed (88760868) and the player crashes. I saw that this bug was fixed in a previous update but i still having it. How could it be solved? Other thing, do I recomend a configuration for a nvidia GTX 470? Thanks a lot. |
