17th July 2011, 21:22 | #8661 | Link |
I must admit, I'm a little skeptical about the decoder thing.
Having the decoder and renderer in one component defeats the whole purpose of DirectShow: its flexibility. I know madVR still accepts pre-decoded (raw) video, but still… I'm a big fan of the "Do one thing and do it well" principle, and this clearly contradicts it. It's your software madshi, but I really wonder what made you integrate this into madVR instead of developing a standard DirectShow decoder filter like everyone else. What if someone wants to put a filter (e.g. IVTC) between the decoder and the renderer? Right now, with your decoder, he can't. I'm really worried about where this is going. What's the next step? The splitter? The audio decoder/renderer? Will we end up with madPlayer, with everything conveniently locked in? "Sponsored by Apple"? |
17th July 2011, 21:24 | #8662 | Link | |
Not sure what consequences "whitelisting" in MC16 would have exactly. FWIW, I wouldn't recommend to use the madVR internal decoders as default yet. |
17th July 2011, 21:29 | #8663 | Link | |
madshi, just fyi, I've found bad stuttering with the internal decoders on my playback monitor if I have it set at 24Hz for 23.976fps material (w/Reclock). Also, MPC-HC shows that it's paused in the taskbar, but it actually playing back with heavy stuttering. Setting the monitor to 60Hz, there is no stuttering. dual-mon with playback on the second monitor, using LAVSplitter. |
17th July 2011, 21:33 | #8664 | Link | |
17th July 2011, 21:35 | #8665 | Link |
Then they may not work in MC16 at all. MC16 requires you to define a splitter, decoder, and renderer. If madVR can't be selected as a decoder according to DS rules, then it probably won't work. Admittedly, I've not had a chance to even look at this yet so I don't know. In any case, I would talk to the JRiver devs and see what they think.
17th July 2011, 21:39 | #8666 | Link | |||
I've a bit confused that MPC-HC still shows "paused" state! What happens if you disable the new pre-buffer option. Does the incorrect paused state problem then still occur? |
17th July 2011, 21:41 | #8667 | Link | ||
madshi, I've noticed that your internal filters may not be report fps upstream, at least Reclock isn't getting anything from the decoder. Perhaps this is related to the timestamp issue you mentioned above, so you probably already know about this.... Quote:
17th July 2011, 21:42 | #8668 | Link |
Ok, so, in that case then if Matt whitelists them in MC16, you'll be able to select them as the decoder when you use ROHQ + additional. So that's good. We just need to get them to whitelist it. Shouldn't be hard.
17th July 2011, 21:56 | #8669 | Link |
<(ovO)>
finally i can watch mpeg2 videos with madvr, nice update!
btw i dont have any startup or seeking delays like some people reported ?
MadVR 0.92.9 x64, MPC-HC, LAV 0.70.2, GV-N1060G1 GAMING-6GD @ 385.41, LG OLED65B7D, Denon AVR-1912, Windows 10 Pro 1709 x64, i7-6700k |
17th July 2011, 21:56 | #8670 | Link |
I also prefer to have the decoder and renderer fully separated. I assume they are integrated now primarily because it greatly simplifies the colorspace handling? Perhaps you can join forces with nevcariel to create a full featured LAV Video decoder that can output high bitdepth colorspaces to madVR. It would be a waste to do things twice.
With regard to the buffering, perhaps it would better to have two options, one for buffering at start, and one for buffering after seeking. I think most people will prefer instant seeking, while a short delay at start is probably less of a problem.
MPC-HC 2.2.1 |
17th July 2011, 22:00 | #8671 | Link | ||
Yeah, I could have written a full blown separate DirectShow decoder filter. But that would have cost me a *LOT* more time. Like 5x or maybe even 10x the time. It would have required a separate installer, a separate download, a separate configuration dialog. It would have required me to test the decoder will all sorts of downstream filters (post processing, other renderers). It would have been too big a job for me. And what would have been the benefit? You're mentioning an IVTC filter. Is there only one IVTC (or any other post processing filter) available today which supports more than 8bit? Nope. So post processing benefit = 0. Ok, one potential benefit would have been that a separate DS filter would have worked with other renderers, too. Haha, why should I want THAT?? Furthermore, other renderers don't support more than 8bit input, either. So again, no real benefit. There's a good reason why I implemented the software decoders internally, which I'll explain sometime in the future. Maybe I should have kept the software decoders secret/hidden until I'm ready to reveal the whole plan. But then, I thought, why keeping back functionality? So I decided to make what I have now available, although it's in experimental state and only half of the final solution. Quote:
Let me say it like this: I will add to madVR only what is strictly video related and what in integrated form has benefits over being external. |
17th July 2011, 22:01 | #8672 | Link | |
I started a thread at jR, fwiw. |
17th July 2011, 22:05 | #8673 | Link | |
17th July 2011, 22:08 | #8674 | Link | |
In any case, yes, the additional filters that show up in MC16 are whitelisted. There was a lot of debate about this at first, and this situation exemplifies the points that were made about it. However, that being said, we need to give J River a chance to address the situation. To expect them to do so a few hours after something brand new is released before they have a chance to evaluate the ramifications is a bit unfair. My guess is that it'll go to the beta team first so we can beat on it, and then once it's determined how well it works or not, they will decide to release it to the general audience. This, IMO, is a really good methodology so that new toys can be vetted by people who understand and can tolerate bugs.
17th July 2011, 22:10 | #8675 | Link | |||||
Yes, if the majority of people prefer it that way, I'll have to make two options, although I generally prefer to keep the number of options as low as possible. Hopefully I'll get a lot of feedback from users so I can find out how many people prefer to have this option set which way. |
17th July 2011, 22:12 | #8676 | Link | |
In theory it can output up to 16-bit YUV, but i don't know if any codec in ffmpeg supports that.
17th July 2011, 22:15 | #8678 | Link |
Thanks. I wanted it to fix the green colourcast in LoTR:FoTR BluRay. Looks like I might have to tweak my HDTV settings for now (setup a seperate profile perhaps).
I think the ability to screencap is of more importance right now. It's the one thing missing from MadVR for me that would make it near perfect. Is the screencap ability forthcoming? BTW subtitles vanish when I pause. Just going to test 0.67 but was wondering if that was fixed. |
17th July 2011, 22:16 | #8679 | Link |
I need a few more days to polish some things. jeez. patience.
17th July 2011, 22:18 | #8680 | Link |
Looking forward to it. I'm really at a point where I'd like to get rid of the PDVD11 HAM decoder on my main HTPC. So, these new toys you and madshi are coming up with are EXTREMELY welcome and highly appreciated.
