Old 18th July 2019, 20:38   #61  |  Link
RanmaCanada
So stupid question, with the 3950x being released in September, and the current 3900 available now, does the advice in this thread work well with those processors, or is it even needed? Looking to upgrade to one of them come black friday, and just curious!
Old 18th July 2019, 23:58   #62  |  Link
Stereodude
The 3950X should have about 33% more performance than the 3900X for 50% more money. Whether it's worth it or not is up to you.
Stereodude is offline   Reply With Quote
Old 21st July 2019, 19:59   #63  |  Link
blublub
Always use UMA. Video encoders unlike games do not need super low latency when accessing memory.
I used numa in my test and on the default settings x265 also chose numa.
Since I only have 1 16 core I'll try UMA next time with --pool 52 or something like that.
blublub is offline   Reply With Quote
Old 21st July 2019, 20:00   #64  |  Link
blublub
Only if you are able to utilize all of those cores. If not then the 12c is likely the much better buy.
Old 21st July 2019, 20:01   #65  |  Link
blublub
The number of frame threads can have a significant impact on quality. It was pretty overwhelming on early versions of x265, and it's still ideal to run at -F 1 if possible for high quality/efficiency encoding.
Lookahead threading is reduced in slower presets, but I'm fuzzy on if and how it actually impacts quality much.
Other than that, I don't think that thread count impacts quality so much.
For Intel dual-socket systems at least, I've often found that pinning a job to just one socket ala --pools "-,+" has minimal impact on performance, although that probably varies with encoded frame size and number of cores per socket.
Since at default frame-thread was 5 and I am currently setting it to 2 or 3
I am already improving quality - so with frame-thread 2 or 3 I doubt that anyone will see a difference.
Old 21st July 2019, 22:14   #66  |  Link
Stereodude
Well, you can make the same argument until you're using the 6c or 4c model.
Old 21st July 2019, 22:21   #67  |  Link
blublub
No u can't.
With x265 it's easy to saturate 8c 16t but it's hard to do 16c 32t at 100% - if u leave the defaults you are only utilizing 60 to 70% so about a 10c 20t CPU on UHD resolution.
With tweaking u can get close to 100% but it's not yet clear if that degrades image quality or not - I can't see a difference but that doesn't mean there isn't any.
Old 22nd July 2019, 00:46   #68  |  Link
Stereodude
No u can't.
Sure I can.
I can saturate any number of cores, even 64, with x265 without degrading quality.
Old 22nd July 2019, 05:19   #69  |  Link
blublub
With default settings? Which software and material are u using?
Old 22nd July 2019, 12:29   #70  |  Link
Stereodude
I didn't say with a single x265 instance. Break your source up into pieces and encode them at the same time. Or, run more than one encoding job at the same time. Think a little outside the box.
Old 22nd July 2019, 14:58   #71  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Just activate Distributed Encoding in Ripbot264 and done
This way I can saturate hundreds of threads!
Old 22nd July 2019, 15:54   #72  |  Link
Stereodude
How does Ripbot264 decide where to splice? Does it correctly handle breaking up a qpfile between the segments?
Old 22nd July 2019, 15:57   #73  |  Link
Atak_Snajpera
Splitting is done at keyframes reported by FFMS.
Old 29th July 2019, 12:03   #74  |  Link
blublub
Mhh gotta try that
