16th October 2015, 16:18 | #19801 | Link |
Please open your own thread if you want to continue your discussions, its entirely unrelated to LAV at this point.
18th October 2015, 16:13 | #19802 | Link |
Nev, are there any features you're looking to include before the release of 1.0? Just curious, as it seems LAV Filters is really stable at this point and not much is blocking such a release except features.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
18th October 2015, 23:02 | #19803 | Link |
I don't put much meaning in such version numbers. I don't have any concrete plans when or what to do specifically for a 1.0. Maybe one day it'll feel right, and I'll use the chance to re-do some of LAVs control interfaces (a bunch of cruft accumulated that I never removed because of backwards compat).
20th October 2015, 17:37 | #19805 | Link |
After "Switched ASF/WMV demuxing to a new demuxer from Libav", the splitter no longer plays all of my wmv's. "wm asf reader" is used instead when that happens. I went back to 0.65.0.25 and it can handle all of them. The ones that are having problem shows "... unneeded bytes at end of file" in gspot. Trying to fix the wmv's index might fix the problem, but I will no longer be able scan for duplicates and some are on read-only media. Can you make LAV Splitter fall back to the old demuxer when that happens? Thanks.
20th October 2015, 18:34 | #19806 | Link |
Please provide samples that don't work instead, that way they can be fixed instead of worrying about some fallback.
21st October 2015, 23:22 | #19807 | Link | |
If you really want to, you can cheat the options box by editing the channel layout in the registry entry (HKCU\Software\LAV\Audio -> MixingLayout), 3.1 would likely be hexadecimal 0x0F (0x1+2 for L/R, 0x4 for C, 0x8 for LFE) Maybe I should add a custom option and let you specify hex channel layouts in the options panel, huh.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 21st October 2015 at 23:58. |
22nd October 2015, 05:06 | #19808 | Link | |
Will using the hex values allow the sliders to vary the mixing of the back/side L/R channels into the front L/R? The ffdshow custom matrix mapping/mixing tab is probably overkill, but still a nice flexible solution IMHO.
ASUS H97 Plus, Intel i5-4690 2.50Ghz, 16GB DD3 1600, XFX R9 270X 2GB DDR5, LynxTwo B Win 8.1 Pro with WMC 64Bit, Kodi, MPC-HC 1.7.8, LAV 0.65.0, Reclock 1.8.8.5, HD AnyDVD |
22nd October 2015, 13:46 | #19809 | Link |
Angel of Night
I just found Equalizer APO, which has support for reordering and regaining channels, although it requires you to set each channel's gain manually, and cannot mix multiple channels into one. It doesn't support compression/limiting, because the author is mostly all about EQ, but with some prodding it could happen. Still, it's easy to get in the chain. This is the kind of thing DirectShow was made for; LAV shouldn't have be the whole audio chain end-to-end.
There must be other filters out there that do generic audio processing well. Better to discover them than beg nev to do something he won't. |
22nd October 2015, 16:56 | #19811 | Link |
No plans.
23rd October 2015, 15:46 | #19812 | Link | |
Latest nightly, of course.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 23rd October 2015 at 15:48. |
23rd October 2015, 16:17 | #19813 | Link |
Maybe related to the Windows update?
https://support.microsoft.com/en-us/kb/3001554
MPC-HC 2.2.1 |
23rd October 2015, 22:12 | #19814 | Link | |
Matroska find' ich toll
I will try it with the Latest nightly. With another DVD(series) "EUREKA" there are no problems. EDIT: it works with the latest nightly! Last edited by hubblec4; 24th October 2015 at 08:31. |
24th October 2015, 06:44 | #19815 | Link |
Nev
Is it possible to put release notes on nightly builds so we know what to test? Thanks
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
24th October 2015, 09:59 | #19816 | Link | |
Otherwise you can read the commit logs: https://github.com/Nevcairiel/LAVFilters/commits/master I'll not write a proper user-readable changelog for the nightly versions otherwise, sorry. There is no VP8 or VP9 hardware acceleration in LAV Video of any kind (yet). The main reason for this is that until recently there was no specification on how to access the VP8/9 hardware decoders. Microsoft has released this specification recently, so now all we have to do is hope that new drivers show up which actually implement hardware acceleration compatible to this spec. For VP9 its at least possible on Broadwell, Braswell and Skylake (and I have this nearly finished implementing in LAV). Haven't seen any VP8 support exposed in drivers yet.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 24th October 2015 at 16:42. |
24th October 2015, 17:56 | #19818 | Link |
25th October 2015, 12:57 | #19819 | Link |
Hi nev,
I see that you changed the wmv splitter in LAV .66. I have many wmv files that will not seek and/or play now with .66 but worked fine with LAV .65 so this leads me to believe that this new wmv splitter (Changed: Switched ASF/WMV demuxing to a new demuxer from Libav) perhaps isn't quite ready for general use yet (?). I have included two samples here (I have many more but they are much bigger to upload) : http://depositfiles.com/files/nksp2h699 Note: This should be easy to duplicate... I have LAV .66 set as wmv splitter and LAV as wmv decoder and the sample vids won't seek and or play. As soon as I switch the wmv splitter in Zoom Player to WMReader or use LAV .65 as the wmv splitter the files play and seek fine. Thank you |
