Old 26th September 2017, 19:41   #301  |  Link
x265_Project
Posts: n/a
Originally Posted by easyfab View Post
HS : x265_Project, is this someone from your team ? https://bambuser.com/v/6909221#t=205
Yes, that's Pradeep Ramachandran, who runs the x265 development team (also known as pradeeprama)
Old 29th September 2017, 08:44   #302  |  Link
Clare
Evolution of the AV1 codec between October 2016 and July 2017
http://wyohknott.github.io/image-for...omparison.html
I'll add another data point after bitstream freeze.
Clare is offline   Reply With Quote
Old 29th September 2017, 16:59   #303  |  Link
Tommy Carrot
Tommy Carrot's Avatar
Clare, in your image comparison page, the old and the new AV1 images are completely identical. Other than that, it's a very useful page, much appreciated.
Tommy Carrot is offline   Reply With Quote
Old 29th September 2017, 21:39   #304  |  Link
Clare
I don't know the files got mixed but it should work now.
Old 29th September 2017, 21:43   #305  |  Link
mzso
Wow. the new one is even worse than the old (which is pretty bad alread) on that factory image. Large almost flat areas.
Old 30th September 2017, 13:56   #306  |  Link
easyfab
@clare
could you add PIK ( https://github.com/google/pik ) in a next comparison ?
easyfab is offline   Reply With Quote
Old 30th September 2017, 14:56   #307  |  Link
Tommy Carrot
Thanks Clare.
Unfortunately, i have to agree. AV1 still image encoding has improved in some regards (less ringing), but it smoothes a bit too much for my liking. In many cases the old AV1 looks better than the new in my opinion.
Old 5th October 2017, 00:27   #308  |  Link
IgorC
I've watched some images from here http://wyohknott.github.io/image-formats-comparison/
And yes, AV1 and HEVC don't retain fine details as much as Daala but they have less blocking though.
IgorC is offline   Reply With Quote
Old 8th October 2017, 12:59   #309  |  Link
Clare
@clare
Yeah some guy from Mozilla asked for Pik too, but the thing seems to require a lot of CPU power and I just have a mobile CPU.
Old 9th October 2017, 19:11   #310  |  Link
MoSal
@Clare Here you go:
subset1 | subset2
Encoded with --distance 3 (maximum compression). Images are still larger than the ones used in your current comparison, especially the more compressible ones.
https://github.com/MoSal
MoSal is offline   Reply With Quote
Old 20th October 2017, 20:34   #311  |  Link
bstrobl
Demuxed 2017 videos are on their Youtube channel (https://www.youtube.com/channel/UCIc...9UgUSTvWVNCmpA). Apparently the AV1 still image format will be called AVIF.
bstrobl is offline   Reply With Quote
Old 21st October 2017, 02:19   #312  |  Link
hajj_3
This is a screenshot from the October 5th Demuxed video in the post above this. Its a shame the version of x265 is old that they are comparing this to and no x264 to compare to.
Old 22nd October 2017, 17:12   #313  |  Link
benwaggoner
Also, these aren't particularly great metrics for moving images; none of them include any temporal component to detect things like keyframe strobing.
DMOS is the gold standard of course, but is expensive and non-automatable. I would like to see at least VMAF scores, as VMAF looks to be the substantially best objective video metric available, at least for SDR <=1080p and >300 Kbps.
I am baffled by the use of such an old x265 build. Even in placebo it'll run a ton faster than the current AV1 reference implementation. So it'd be trivial to rerun the test at the same time the final tests for AV1 are done for a presentation like this.
Are the different command lines used for the different codecs listed somewhere?
Ben Waggoner
My Compression Book
Old 24th October 2017, 14:15   #314  |  Link
dapperdan
In case anyone else was confused like I was, the still image format based on AV1 called AVIF is mentioned (briefly) in a video mostly on other topics, given by Netflix at the Demuxed conference, not in either of the two videos that mention AV1 in their titles:
https://www.youtube.com/watch?v=PSdhW-R9u6s
dapperdan is offline   Reply With Quote
Old 25th October 2017, 08:06   #315  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
AV1 status report (Oct 20, 2017)
https://www.youtube.com/watch?v=yKEDf5-2sT4
birdie is offline   Reply With Quote
Old 25th October 2017, 09:26   #316  |  Link
mzso
A timecoded link would have been nice. Or a mention of what was said. Not everyone has time for these long-ass videos.
Old 25th October 2017, 13:20   #317  |  Link
dapperdan
It's at 1:30 through to about 4 minues though it pretty much only says "We expect to have a new image format based on [AV1] called AVIF" and about 3 minutes makes clear this is just a I-Frame of AV1 and aimed towards distribution rather than storage.
Old 25th October 2017, 17:44   #318  |  Link
dapperdan
AV1 status update talk from Gstreamer conference, very similar content to the Demuxed talk.
https://gstconf.ubicast.tv/videos/av...arly-complete/
Old 25th October 2017, 17:47   #319  |  Link
dapperdan
A PhD-level internship for working on AV1 at Mozilla is open for applications:
https://careers.mozilla.org/position/gh/881961
Old 25th October 2017, 21:34   #320  |  Link
bstrobl
Hope not too many issues crop up in the reference implementation due to the final rush to get things done.
