Old 25th April 2015, 12:51   #21  |  Link
Originally Posted by stax76 View Post
@huhn
There is devices support applying some restrictions, I try to add at least some tooltips and help. I like adding new encoders even with GUI, my design makes this a very very easy task, I'm not really C++ programming (future maybe...) so no AMD support until there is a tool (which I didn't search hard for).
maybe useful for you maybe not: https://obsproject.com/forum/threads...support.13996/
Old 25th April 2015, 13:03   #22  |  Link
burfadel
There is a good chance most comes back in the next release.
That's good, deinterlacing vital for encoding .
Old 25th April 2015, 13:09   #23  |  Link
stax76
stax76's Avatar
There are various plugins but I don't know yet the quality of the port and the compatibility.
https://sites.google.com/site/avisyn...lugin/download
http://web.archive.org/web/201309222...kazu.110mb.com
http://members.optusnet.com.au/squid_80
https://code.google.com/p/avisynth64/wiki/PluginLinks
Old 25th April 2015, 14:08   #24  |  Link
luigizaninoni
staxrip64 and avisynth+
Hello, I have been using Staxrip for some months, and so far I have been very pleased with the results.
My usual workflow is as follows:
- record movie from DVB-T with dvbviewer
- remove ads with Videoredo
- encode with Staxrip-32bit – avisynth qtgmc – x265 10bit slow - crf 19
The introduction of Staxrip 64-bit is very welcome (qtgmc is so slooooow … and x265 10bit does not help). However I am trying to have it work properly but I am totally stuck – I am not a total noob, but certainly I am not an expert either.
My difficulties:
- How can I install Avisynth+, given that the existing installer is very old and not updated to most recent version ?
- How do I implement Qtgmc ? As far as I can understand, I would need Mvtools, MaskTools v2, NNEDI3, RemoveGrain + Repair, SSE2Tools, NNEDI2, NNEDI, EEDI3, EEDI2, Tdeint. All 64-bit plugins. I do not use the other plugins. I have been able to find some of these plugins in 64-bit version, but where can I find all of them ?
luigizaninoni is offline   Reply With Quote
Old 25th April 2015, 14:32   #25  |  Link
stax76
stax76's Avatar
I try to get a newer installer, Qtgmc and x64 might be a problem.
Old 25th April 2015, 15:18   #26  |  Link
Reel.Deel
Originally Posted by luigizaninoni View Post
My difficulties:
I used the AviSynth+ r1576 installer (make sure you install 32 and 64-bit) and then I manually replaced the respective files using the updated build from here. 32-bit avisynth.dll and devil.dll go in the SysWOW64 folder, 64-bit goes in the System32 folder. Also replace the core plugins in the AviSynth autoload folder with the included plugins.
Really you don't need all these plugins for it to work, QTGMC() with all default settings only needs MVtools2, MaskTools2, RemoveGrain/Repair, and NNEDI3. Some of the other plugins like NNEDI, NNEDI2, EDDI2 can be considered deprecated. SSE2Tools is only used to process YUY2, it's closed source and the author is no longer around so we won't see a 64-bit version of that (this is probably a good thing, it was just an ugly hack anyways).
Anyways you can download the core plugins here:
Old 25th April 2015, 15:30   #27  |  Link
luigizaninoni
Old 25th April 2015, 16:28   #28  |  Link
luigizaninoni
Ok, thanks to Reel.Deel, now Avisynth+ and Qtgmc "might" be in place.
However, I am still stuck with Staxrip 64-bit. When I try to open a source I get this error message:
Exception
Overflow di un'operazione aritmetica.
System.OverflowException: Overflow di un'operazione aritmetica.
in System.IntPtr.op_Explicit(IntPtr value)
in StaxRip.TaskDialog`1.AllocateAndMarshalButtons(List`1 structs) in C:\Daten\Projekte\GitHub\staxrip\UI\TaskDialog.vb:riga 379
in StaxRip.TaskDialog`1.MarshalDialogControlStructs() in C:\Daten\Projekte\GitHub\staxrip\UI\TaskDialog.vb:riga 361
in StaxRip.TaskDialog`1.Show() in C:\Daten\Projekte\GitHub\staxrip\UI\TaskDialog.vb:riga 302
in StaxRip.MainForm.OpenSourceFiles() in C:\Daten\Projekte\GitHub\staxrip\Forms\MainForm.vb:riga 4858
in StaxRip.MainForm.lTip_Click() in C:\Daten\Projekte\GitHub\staxrip\Forms\MainForm.vb:riga 5297
in StaxRip.MainForm._Lambda$__163(Object a0, EventArgs a1) in C:\Daten\Projekte\GitHub\staxrip\Forms\MainForm.vb:riga 0
in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.Label.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Old 25th April 2015, 18:08   #29  |  Link
stax76
stax76's Avatar
Looks like a bad pointer size so 64-bit port bug number two, this kind of bug was to be expected, I'll upload a fix shortly.
Old 25th April 2015, 18:31   #30  |  Link
stax76
stax76's Avatar
The code works here, which OS are you using and what were you doing when it happens?
Old 25th April 2015, 18:45   #31  |  Link
luigizaninoni
Windows 8.1 64-bit. Main windows of staxrip, click on "source-single file" or right-click on "source-open"
Old 25th April 2015, 19:08   #32  |  Link
stax76
stax76's Avatar
It's the same line of code described here:
https://github.com/aybe/Windows-API-...k-1.1/issues/3
What I don't understand is why it's another type of exception, my code was casting to int while the code that is said to work uses intptr.ToInt64, maybe the integer size is different on your system, I don't get it, anyway, I upload a build in a few minutes which I hope will work.
Old 25th April 2015, 19:20   #33  |  Link
stax76
stax76's Avatar
alpha 1.3.0.1
http://1drv.ms/1DwnJsY
Old 25th April 2015, 19:25   #34  |  Link
luigizaninoni
now source opens, thanks
I'll try an encode with qtgmc and report back
Old 25th April 2015, 19:28   #35  |  Link
luigizaninoni
source opens now, thanks
Old 25th April 2015, 19:44   #36  |  Link
luigizaninoni
thanks, now no error while opening source.
However, tried to encode (with qtgmc); gives error message "AviFile open failed" (strange, because it's a .ts and it should open with directshowsource)
Old 25th April 2015, 19:48   #37  |  Link
luigizaninoni
Exception
AVIFileOpen failed
System.Exception: AVIFileOpen failed
in StaxRip.AVIFile..ctor(String path) in C:\Daten\Projekte\GitHub\staxrip\General\AVIFile.vb:riga 66
in StaxRip.AviSynthDocument.Synchronize() in C:\Daten\Projekte\GitHub\staxrip\General\AviSynth.vb:riga 146
in StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean autoMode) in C:\Daten\Projekte\GitHub\staxrip\Forms\MainForm.vb:riga 1946
Old 25th April 2015, 19:50   #38  |  Link
stax76
stax76's Avatar
Is there a full log file you can upload to pastebin?
Old 25th April 2015, 19:57   #39  |  Link
luigizaninoni
loaded crash.srip to dropbox:
https://dl.dropboxusercontent.com/u/...0PC/crash.srip
Old 25th April 2015, 20:03   #40  |  Link
stax76
stax76's Avatar
Is there a log file?
*_StaxRip.log
Try to remove all plugins from the auto load folder, it could be a problem with your system or avisynth.
