6th February 2013, 15:14 | #12101 | Link |
So, for playlists like this, until fully supported (if at all possible in future), should eac3to then report that this is a timed playlist and either refuse to work on it, or display an additional caveat to the user?
6th February 2013, 15:54 | #12102 | Link |
No, the BDInfo below shows that the referenced segments are contiguous:
00000.M2TS 0:00:00.000 0:01:31.991 0 0 00000.M2TS 0:01:31.991 0:08:43.856 0 0 00000.M2TS 0:10:15.848 0:10:26.092 0 0 00000.M2TS 0:20:41.940 0:00:43.243 0 0 00008.M2TS 0:21:25.183 0:00:00.333 0 0 The first time is the start time and the second is the duration. So, adding the duration to the start time gives the start time of the following segment. It's possible that there is extra unreferenced material at the end of 00000.M2TS but it seems unlikely. Last edited by Guest; 6th February 2013 at 15:57. |
6th February 2013, 18:53 | #12103 | Link |
@neuron2, I've been told "eac3to 00000.m2ts+00008.m2ts" does not produce the expected runtime, so there *must* be extra unreferenced material at the end of either 00000.m2ts or 00008.m2ts. That's the only explanation that makes sense to me.
6th February 2013, 19:25 | #12106 | Link |
If the files as listed in the playlist had no extra material, we could calculate the overall runtime of [0+0+0+0+8] like this:
00000.m2ts: 0:21:25.183 00008.m2ts: 0:00:00.333 Overall runtime of [0+0+0+0+8] = 4 * 00:21:25.183 + 00:00:00.333 = 5141.065 seconds = 01:25:41.065 However, eac3to reported an overall runtime for [0+0+0+0+8] of exactly 01:30:00.000, so there must be some extra material somewhere, not referenced by the playlist. |
6th February 2013, 19:28 | #12108 | Link |
eac3to.exe f:\BDMV\STREAM\00000.m2ts M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 0:22:30, 60i /1.001 1: VC-1, 1080i60 /1.001 (16:9) 2: DTS, German, 2.0 channels, 384kbps, 48kHz 3: DTS, English, 2.0 channels, 384kbps, 48kHz 4: Subtitle (PGS), German Code:
eac3to.exe f:\BDMV\STREAM\00008.m2ts M2TS, 1 video track, 0:00:00 1: VC-1, 1080i60 /1.001 (16:9) |
6th February 2013, 19:36 | #12110 | Link |
General ID : 0 (0x0) Complete name : F:\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 2.93 GiB Duration : 23mn 0s Overall bit rate mode : Variable Overall bit rate : 18.2 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : Advanced@L3 Codec ID : 234 Duration : 22mn 30s Bit rate : 16.7 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.269 Stream size : 2.63 GiB (90%) Code:
General ID : 0 (0x0) Complete name : F:\BDMV\STREAM\00008.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 54.0 KiB Duration : 270ms Overall bit rate : 1 491 Kbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : Advanced@L3 Codec ID : 234 Duration : 334ms Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Last edited by XadoX; 6th February 2013 at 19:38. |
7th February 2013, 05:34 | #12111 | Link | ||
I have a question about the 24-bit-depth outputted by eac3to for use in lossy formats such as AAC which use floating point bit-depth. I am usually downmixing 6ch DTS files to 2ch AAC through piping to the qaac encoder. I am wondering if there would be better quality through having eac3to pass qaac its original 64-bit-depth file instead of a dithered 24-bit-depth file. I am trying to maintain best quality possible by doing as few bit-depth dithering operations as possible.
eac3to.exe "movie_6chdts.mkv" 2: stdout.wav -downDpl | qaac.exe --tvbr 127 --quality 2 --rate keep --ignorelength --no-delay - -o "2chaac.m4a" eac3to tells me: [a02] Reducing depth from 64 to 24 bits [a02] Writing WAV Code:
Even using the internally used neroaacenc does a down dithering operation. Why not pass the aac encoder the original 64-bit-depth data? [a02] Reducing depth from 64 to 32 bits [a02] Encoding AAC <1.00> with NeroAacEnc Reference: http://wiki.jriver.com/index.php/Audio_Bitdepth Quote:
7th February 2013, 07:48 | #12112 | Link |
Most encoders only accept up to 32-bit floating point ("float"), and not 64-bit ("double"), which is most likely why you're seeing the conversion for Nero.
If you think qaac supports 64-bit floating point input, you can use the "-full" switch, which lets eac3to output 64-bit float (or so i remember) Note that most decoders also only produce 32-bit floating point (however eac3to might produce 64-bit after the downmixing)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 7th February 2013 at 07:51. |
7th February 2013, 08:14 | #12113 | Link |
An intermediate 64-bit result based on the decoding of an already lossy source, with even more loss due to the downmixing...
Will someone rather be able to hear the difference between 24 and 32 bit samples, or between original and lossy encoding instead? — Does he have a separate home cinema room with audiophile wall covers, or just a living room with furnitures? And most important: Does he use gold-capped digital cables? Get that steam out of here ... |
7th February 2013, 11:46 | #12114 | Link | |
eac3to.exe "video_6chdts.mkv" 2: stdout.wav -downDpl -full | qaac.exe --tvbr 127 --quality 2 --rate keep --ignorelength --no-delay - -o "2chaac.m4a" I recommend adding the -full switch to the documentation (I could not find it anywhere). Also I advise anyone piping to qaac to use the -full switch for better quality - down dithering operations make a difference and if it can be avoided with a simple switch it should be. The m4a filesize produced by qaac with the "eac3to -full" switch is also approx. same - it just feeds qaac a more accurate source for it to apply its compression to. Last edited by robertcollier4; 7th February 2013 at 12:40. |
7th February 2013, 18:21 | #12117 | Link |
Chop off the extra stuff using 'Output Trimmed TS' in DGIndexNV. Then load the trimmed 00000.m2ts and 00008.m2ts (if that 1/3 second of video is crucial!) in DGIndexNV and off you go.
Alternatively, trim out the extra material in your Avisynth script. Last edited by Guest; 7th February 2013 at 18:27. |
9th February 2013, 01:27 | #12119 | Link | |
French Love
If I missed the topic that interests me here talking
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
9th February 2013, 09:20 | #12120 | Link |
@frencher
About your question: "I wanted to know if others have had the same problem as me for demuxing 3D Bluray PGS subtitles tracks (.sup)" Seems the answer is "Nope", at least not for me. Please put the log file, if show any <ERROR> or <WARNING>, or more info about your problem.
eac3to |
