16th January 2014, 07:10 | #18883 | Link | |
Anyway... After editing a TiVo file and exporting to MPG... I'm not able to reproduce a Progressive file with BD-RB as HandBrake does. If I drag an MPG file to HandBrake and select the Filters tab then select "Detelecine: Default" which is usually "Off", and change Video Framerate to 23.976 and switch from Peekframe Rate to Constant Framerate. The desired Progressive MKV is obtained. I have the following in BD-RB. SD_PROGRESSIVE=1 IVTC_TELECIDE=0 IVTC_SELECTION=1 IVTC_480i=0 IVTS for 3:2 pulldown is disabled. I've tried different combinations with BD-RB. It's not producing the same effect HangBrake is. Is this a bug? Seems like like BD-RB (or I) am missing something. If I use Media Player Classic - Home Cinema to "step" through the frames once passed I'm able to see repeated frames after using BD-RB (44.03). Wanting 1080i to 1280x720. Anyone have any ideas I may entertain?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
16th January 2014, 09:05 | #18884 | Link | |
x264 is really stronger at low bitrates IMHO, like those you get for BD5/9. In flat scenes with flat backgrounds the Intel Encoder tends to produce visible blocks and gop pulsing. Similar can happen at scene transitions. Such occasional transient effects may barely deteriorate the PSNR values, they are however clearly visible even by "uneducated" viewers at normal viewing distance (and unfortunately one tends to remember these occasional "ooops".... ) In motion and panning scenes details get suppressed (blurred), but this is less of a problem because it is usually not noticeable when watching the movie. I trust it may be different at BD25+ bitrates, but I didn't try as I still do all my backups on BD5/9. Not a big issue, it is really great to finally have a free and good quality MVC suite with FRIM/Intel, even though there seems to be some room for improvement. Last edited by Sharc; 16th January 2014 at 09:11. |
16th January 2014, 14:42 | #18885 | Link | |
16th January 2014, 20:10 | #18886 | Link |
DTS Express problem with Battle: Los Angeles
Thanks for your response. One of the movies I am having trouble with is Battle: Los Angeles. Everything works except the DTS Express track. When I choose the bonus material that uses it, the movie begins playing and occasionally a PiP video will pop up. The PiP video plays fine, but the audio that plays is the main DTS-HD track. I used tsMuxer and verified that the DTS Express track is there, but it is not playing. I believe I have provided everything below that is usually requested when reporting a problem. The text in these files would have spanned across 3-4 posts. So, I decided to attach them instead. If anything else is needed, please ask. Thanks for your help. Later.
Acerjen Last edited by Acerjen; 16th January 2014 at 20:26. Reason: post was too big |
16th January 2014, 21:42 | #18888 | Link |
The BD-RB quality setting is applied to FRIMEncode. In my PSNR tests I can confirm that the higher quality settings resulted in better PSNR results than lower settings. So the answer should be "yes", using a higher quality setting would make a difference -- remember, though, that different sources may have different degrees of results.
17th January 2014, 16:13 | #18889 | Link |
Running my first test with the new BD-RB, doing a movie-only 3D backup. I'm a bit puzzled as to why BD-RB began re-encoding the movie, because the ISO image is 24.3GB and the movie itself is only 22936MB (including two 5.1 channel DTS-HD MA tracks, one of which is disabled, saving approx. 1GB). I expected a quick 1:1 copy instead of a re-encode as I'm using a Custom output size of 24350MB.
17th January 2014, 18:31 | #18890 | Link | |
18th January 2014, 10:51 | #18892 | Link |
First movie-only 3D backup result: image is extremely corrupted.
Log: [01.18.14] BD Rebuilder v0.46.03 (beta) [20:08:32] Source: OUT_OF_INFERNO_3D_00001 - Input BD size: 27,36 GB - Approximate total content: [01:47:19.516] - Target BD size: 23,68 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Ultra High Quality (Extremely Slow), ABR - Output folder: T:\_ENCODES\ - X264 Tweak(s) enabled - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Subtitle [3] is defaulted ON. [20:08:35] PHASE ONE, Encoding - [20:08:35] Processing: VID_00000 (1 of 1) - [20:08:35] Extracting A/V streams [VID_00000] - [20:24:43] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 154*394 frames - Bitrate: 26*950 Kbs - Using FRIMEncoder for MVC reencoding - [20:24:43] Reencoding: VID_00000, Pass 1 of 1 - [06:53:07] Video Encode complete - [06:53:07] Processing audio tracks - Track 4352 (zho): Keeping original audio [06:53:07]PHASE ONE complete [06:53:07]PHASE TWO - Rebuild Started - [06:53:07] Rebuilding BD file Structure [06:57:31] - Encode and Rebuild complete [06:57:31] JOB: OUT_OF_INFERNO_3D finished. Similar image corruption took place several times when I was testing the command line versions of FRIMdecoder/encoder/transcode. It happened when decoding was done in hardware instead of software. I ran this backup job on a Core i7-3930K which supports HW acceleration for both decode and encode. Last edited by colinhunt; 18th January 2014 at 11:00. |
18th January 2014, 14:40 | #18893 | Link | |
18th January 2014, 19:23 | #18896 | Link | |
[update] It is indeed related to motherboard and one I am using does not have GPU built in which also explain why I can't turn it on.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 19th January 2014 at 00:31. |
19th January 2014, 02:03 | #18898 | Link |
Imported The Simpsons Season 3 from 4 DVDs to BD. The sound lags behind the video on all 24 episodes. The lag discrepancy grows longer as the further the episode is...here's the log and my settings. Plz. let me know if you want any other info:
========================== [12:54:00] BD Rebuilder v0.46.03 (beta) [12:54:00] BEGIN - BATCH SEQUENCE ========================== ----------------------- [12:54:00] PROCESSING BATCH FILE [1] ---------------------- [01/15/14] BD Rebuilder v0.46.03 (beta) [12:54:02] Source: SIMPSONS_S3 - Input BD size: 27.64 GB - Approximate total content: [09:12:09.203] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [12:54:03] PHASE ONE, Encoding - [12:54:03] Processing: VID_00001 (1 of 24) - [12:54:03] Extracting A/V streams [VID_00001] - [12:55:23] Reencoding video [VID_00001] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,479 frames - Bitrate: 5,169 Kbs - [12:55:24] Reencoding: VID_00001, Pass 1 of 2 - [13:05:15] Reencoding: VID_00001, Pass 2 of 2 - [13:52:56] Video Encode complete - [13:52:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:52:56] Multiplexing M2TS - [13:54:07] Processing: VID_00002 (2 of 24) - [13:54:07] Extracting A/V streams [VID_00002] - [13:56:02] Reencoding video [VID_00002] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,421 frames - Bitrate: 5,129 Kbs - [13:56:02] Reencoding: VID_00002, Pass 1 of 2 - [14:06:14] Reencoding: VID_00002, Pass 2 of 2 - [14:57:53] Video Encode complete - [14:57:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:57:53] Multiplexing M2TS - [14:58:39] Processing: VID_00003 (3 of 24) - [14:58:39] Extracting A/V streams [VID_00003] - [14:59:59] Reencoding video [VID_00003] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,301 frames - Bitrate: 4,905 Kbs - [14:59:59] Reencoding: VID_00003, Pass 1 of 2 - [15:09:23] Reencoding: VID_00003, Pass 2 of 2 - [15:55:03] Video Encode complete - [15:55:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [15:55:03] Multiplexing M2TS - [15:55:47] Processing: VID_00004 (4 of 24) - [15:55:47] Extracting A/V streams [VID_00004] - [15:57:38] Reencoding video [VID_00004] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,391 frames - Bitrate: 5,072 Kbs - [15:57:39] Reencoding: VID_00004, Pass 1 of 2 - [16:07:24] Reencoding: VID_00004, Pass 2 of 2 - [16:54:03] Video Encode complete - [16:54:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:54:03] Multiplexing M2TS - [16:54:49] Processing: VID_00005 (5 of 24) - [16:54:49] Extracting A/V streams [VID_00005] - [16:56:06] Reencoding video [VID_00005] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,479 frames - Bitrate: 4,897 Kbs - [16:56:07] Reencoding: VID_00005, Pass 1 of 2 - [17:05:43] Reencoding: VID_00005, Pass 2 of 2 - [17:52:18] Video Encode complete - [17:52:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:52:18] Multiplexing M2TS - [17:53:29] Processing: VID_00006 (6 of 24) - [17:53:29] Extracting A/V streams [VID_00006] - [17:55:45] Reencoding video [VID_00006] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,479 frames - Bitrate: 5,040 Kbs - [17:55:46] Reencoding: VID_00006, Pass 1 of 2 - [18:06:31] Reencoding: VID_00006, Pass 2 of 2 - [18:58:13] Video Encode complete - [18:58:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:58:13] Multiplexing M2TS - [18:59:29] Processing: VID_00007 (7 of 24) - [18:59:29] Extracting A/V streams [VID_00007] - [19:03:00] Reencoding video [VID_00007] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,361 frames - Bitrate: 5,527 Kbs - [19:03:01] Reencoding: VID_00007, Pass 1 of 2 - [19:14:02] Reencoding: VID_00007, Pass 2 of 2 - [20:06:55] Video Encode complete - [20:06:55] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:06:55] Multiplexing M2TS - [20:08:21] Processing: VID_00008 (8 of 24) - [20:08:22] Extracting A/V streams [VID_00008] - [20:10:09] Reencoding video [VID_00008] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,479 frames - Bitrate: 5,217 Kbs - [20:10:09] Reencoding: VID_00008, Pass 1 of 2 - [20:20:43] Reencoding: VID_00008, Pass 2 of 2 - [21:11:53] Video Encode complete - [21:11:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:11:54] Multiplexing M2TS - [21:13:06] Processing: VID_00009 (9 of 24) - [21:13:06] Extracting A/V streams [VID_00009] - [21:14:59] Reencoding video [VID_00009] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,271 frames - Bitrate: 5,071 Kbs - [21:15:00] Reencoding: VID_00009, Pass 1 of 2 - [21:26:54] Reencoding: VID_00009, Pass 2 of 2 - [22:22:04] Video Encode complete - [22:22:04] Processing audio tracks - Track 4352 (eng): Keeping original audio - [22:22:04] Multiplexing M2TS - [22:23:07] Processing: VID_00010 (10 of 24) - [22:23:07] Extracting A/V streams [VID_00010] - [22:24:54] Reencoding video [VID_00010] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,361 frames - Bitrate: 4,945 Kbs - [22:24:55] Reencoding: VID_00010, Pass 1 of 2 - [22:34:35] Reencoding: VID_00010, Pass 2 of 2 - [23:20:23] Video Encode complete - [23:20:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [23:20:23] Multiplexing M2TS - [23:21:08] Processing: VID_00011 (11 of 24) - [23:21:08] Extracting A/V streams [VID_00011] - [23:22:30] Reencoding video [VID_00011] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,361 frames - Bitrate: 3,758 Kbs - [23:22:31] Reencoding: VID_00011, Pass 1 of 2 - [23:31:38] Reencoding: VID_00011, Pass 2 of 2 - [00:14:14] Video Encode complete - [00:14:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:14:15] Multiplexing M2TS - [00:14:51] Processing: VID_00012 (12 of 24) - [00:14:51] Extracting A/V streams [VID_00012] - [00:16:40] Reencoding video [VID_00012] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,421 frames - Bitrate: 5,035 Kbs - [00:16:40] Reencoding: VID_00012, Pass 1 of 2 - [00:26:20] Reencoding: VID_00012, Pass 2 of 2 - [01:13:14] Video Encode complete - [01:13:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:13:15] Multiplexing M2TS - [01:14:00] Processing: VID_00013 (13 of 24) - [01:14:00] Extracting A/V streams [VID_00013] - [01:15:22] Reencoding video [VID_00013] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,449 frames - Bitrate: 5,265 Kbs - [01:15:22] Reencoding: VID_00013, Pass 1 of 2 - [01:25:18] Reencoding: VID_00013, Pass 2 of 2 - [02:13:08] Video Encode complete - [02:13:08] Processing audio tracks - Track 4352 (eng): Keeping original audio - [02:13:08] Multiplexing M2TS - [02:13:55] Processing: VID_00014 (14 of 24) - [02:13:55] Extracting A/V streams [VID_00014] - [02:15:48] Reencoding video [VID_00014] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,479 frames - Bitrate: 5,257 Kbs - [02:15:48] Reencoding: VID_00014, Pass 1 of 2 - [02:25:32] Reencoding: VID_00014, Pass 2 of 2 - [03:10:18] Video Encode complete - [03:10:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [03:10:19] Multiplexing M2TS - [03:11:05] Processing: VID_00015 (15 of 24) - [03:11:06] Extracting A/V streams [VID_00015] - [03:12:58] Reencoding video [VID_00015] - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 41,415 frames - Bitrate: 5,266 Kbs - [03:12:59] Reencoding: VID_00015, Pass 1 of 2 - [03:22:57] Reencoding: VID_00015, Pass 2 of 2 - [04:10:37] Video Encode complete - [04:10:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [04:10:37] Multiplexing M2TS - [04:11:24] Processing: VID_00016 (16 of 24) - [04:11:24] Extracting A/V streams [VID_00016] - [04:12:47] Reencoding video [VID_00016] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,421 frames - Bitrate: 5,448 Kbs - [04:12:47] Reencoding: VID_00016, Pass 1 of 2 - [04:22:40] Reencoding: VID_00016, Pass 2 of 2 - [05:09:42] Video Encode complete - [05:09:42] Processing audio tracks - Track 4352 (eng): Keeping original audio - [05:09:42] Multiplexing M2TS - [05:10:30] Processing: VID_00017 (17 of 24) - [05:10:30] Extracting A/V streams [VID_00017] - [05:12:24] Reencoding video [VID_00017] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,421 frames - Bitrate: 5,291 Kbs - [05:12:25] Reencoding: VID_00017, Pass 1 of 2 - [05:22:21] Reencoding: VID_00017, Pass 2 of 2 - [06:10:13] Video Encode complete - [06:10:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [06:10:13] Multiplexing M2TS - [06:11:00] Processing: VID_00018 (18 of 24) - [06:11:00] Extracting A/V streams [VID_00018] - [06:12:23] Reencoding video [VID_00018] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,449 frames - Bitrate: 5,459 Kbs - [06:12:24] Reencoding: VID_00018, Pass 1 of 2 - [06:22:23] Reencoding: VID_00018, Pass 2 of 2 - [07:11:39] Video Encode complete - [07:11:39] Processing audio tracks - Track 4352 (eng): Keeping original audio - [07:11:39] Multiplexing M2TS - [07:12:27] Processing: VID_00019 (19 of 24) - [07:12:27] Extracting A/V streams [VID_00019] - [07:14:19] Reencoding video [VID_00019] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,001 frames - Bitrate: 5,278 Kbs - [07:14:20] Reencoding: VID_00019, Pass 1 of 2 - [07:24:21] Reencoding: VID_00019, Pass 2 of 2 - [08:12:46] Video Encode complete - [08:12:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - [08:12:46] Multiplexing M2TS - [08:13:33] Processing: VID_00020 (20 of 24) - [08:13:33] Extracting A/V streams [VID_00020] - [08:14:57] Reencoding video [VID_00020] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,361 frames - Bitrate: 5,477 Kbs - [08:14:58] Reencoding: VID_00020, Pass 1 of 2 - [08:24:46] Reencoding: VID_00020, Pass 2 of 2 - [09:12:52] Video Encode complete - [09:12:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [09:12:53] Multiplexing M2TS - [09:13:41] Processing: VID_00021 (21 of 24) - [09:13:41] Extracting A/V streams [VID_00021] - [09:15:04] Reencoding video [VID_00021] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,391 frames - Bitrate: 5,273 Kbs - [09:15:04] Reencoding: VID_00021, Pass 1 of 2 - [09:24:57] Reencoding: VID_00021, Pass 2 of 2 - [10:13:17] Video Encode complete - [10:13:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:13:17] Multiplexing M2TS - [10:14:04] Processing: VID_00022 (22 of 24) - [10:14:04] Extracting A/V streams [VID_00022] - [10:15:33] Reencoding video [VID_00022] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,301 frames - Bitrate: 4,108 Kbs - [10:15:33] Reencoding: VID_00022, Pass 1 of 2 - [10:24:45] Reencoding: VID_00022, Pass 2 of 2 - [11:08:00] Video Encode complete - [11:08:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:08:01] Multiplexing M2TS - [11:08:40] Processing: VID_00023 (23 of 24) - [11:08:40] Extracting A/V streams [VID_00023] - [11:09:54] Reencoding video [VID_00023] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 41,449 frames - Bitrate: 4,344 Kbs - [11:09:55] Reencoding: VID_00023, Pass 1 of 2 - [11:19:18] Reencoding: VID_00023, Pass 2 of 2 - [12:03:47] Video Encode complete - [12:03:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:03:48] Multiplexing M2TS - [12:04:28] Processing: VID_00024 (24 of 24) - [12:04:28] Extracting A/V streams [VID_00024] - [12:05:36] Reencoding video [VID_00024] - Source Video: MPEG-2, 720x480, Hybrid - Rate/Length: 29.970fps, 40,911 frames - Bitrate: 4,078 Kbs - [12:05:37] Reencoding: VID_00024, Pass 1 of 2 - [12:14:34] Reencoding: VID_00024, Pass 2 of 2 - [12:56:08] Video Encode complete - [12:56:08] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:56:08] Multiplexing M2TS [12:56:47]PHASE ONE complete [12:56:47]PHASE TWO - Rebuild Started - [12:56:47] Rebuilding BD file Structure [12:57:02] - Encode and Rebuild complete [12:57:02] Writing BD structure to ISO file - ImgBurn completed successfully - SIMPSONS_S3 folder removed. - WORKFILES folder removed. [13:25:04] JOB: SIMPSONS_S3 finished. ========================== [13:25:04] END - BATCH SEQUENCE ========================== [Options] VERSION=0.46.0.3 MODE=0 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=23500 AUTO_BURN=2 PRIORITY_CLASS=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=1 COMPLETION_BEEP=0 DGDECNV=0 OUTPUT_3D=0 NEROAAC=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 ENABLE_TEST=1 QUICK_EXTRAS=0 ENABLE_BLANKING=1 IMPORT_THRESHOLD=21 [Paths] SOURCE_PATH=E:\BDS\SIMP_S3\IMPORTS\SIMPSONS_S3\ WORKING_PATH=F:\BDS\SIMP_S3\ Last edited by jdobbs; 19th January 2014 at 02:17. |
19th January 2014, 02:19 | #18899 | Link |
@slvrsrfr
Could you post the content of one of the .AVS files so I can look at it? I'm guessing it has something to do with the fact that these are hybrid files. That means that parts of them are telecined and other parts aren't. |
19th January 2014, 05:01 | #18900 | Link |
You bet - I appreciate your alacrity!
So, the season 3 files were wiped, but I had the same behavior on season 8. There were 2 acs files per episode, let me know if you want anything else! VID_00001.AVS contents: #Created by BD Rebuilder - v0.46.03 (beta) DirectshowSource("F:\BDS\SIMP_S8\IMPORTS\SIMPSONS_S7\BDMV\STREAM\00001.m2ts", fps=29.97, framecount=41999, ConvertFPS=true, audio=false) ConvertToYV12() LoadPlugin("C:\Temp\Software\BD_Rebuilder\tools\decomb521.dll") FieldDeinterlace(blend=true) ConvertToYV12().AssumeFPS(30000,1001) AUD_00001_4352.AVS contents: #Created by BD Rebuilder - v0.46.03 (beta) LoadPlugin("C:\Temp\Software\BD_Rebuilder\tools\nicaudio.dll") audio=NicAC3Source("00001.track_4352.ac3") audio = (AudioChannels(audio) > 6) ? GetChannel(audio,1,2,3,4,7,8) : audio ConvertAudioTo16bit(ResampleAudio(audio, 48000)) |
