24th August 2011, 16:55 | #1861 | Link |
Thank you for your quick reply. To use the labels instead is what is wanted to try next.
But I wonder what is the edit title textbox is good for? You extract the original titlename from the filename so you can 100% sure it is valid. So it would be good it AVStoDVD would use the original title internally for temp files and so on and the edited name for the label. Or you change the behaviour of the textbox to read-only, because who would need a titlename that has to be changed a second time for the label... ggtop Last edited by ggtop; 24th August 2011 at 16:58. |
24th August 2011, 20:27 | #1862 | Link |
@MrC..Sorry one more time..I am trying to understand and learn..You suggested Muxman refuse to retain audio track. I used tool with two .mkv files. Boths files had DTS 6.1. File1 is success and file2 is half the size of actual .mkv file and no audio.
file1 log__________________________ <8/23/2011 3:31:34 PM> TITLE 1 SOURCE FILES Video: C:\Users\xyz\Downloads\file1.mkv Info: AVC - 3014 kbps - 1280x560 - DAR 2.286 - 23.976 fps (CFR) - Progressive - 2:17:52 hours - 198340 frames Audio 1: C:\Users\xyz\Downloads\file1.mkv Info: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 2:17:52 hours (0 ms delay) - Internal [MediaInfoLib - v0.7.47] <> <8/23/2011 3:31:34 PM> AVISYNTH SCRIPT Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") Video = A2DVideoSource("C:\Users\xyz\Downloads\file1.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp", FrameRate=23.976, VFR=false) # Audio is frameserved by AviSynth just for Preview and Edit purposes. Audio = A2DAudioSource("C:\Users\xyz\Downloads\file1.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp") Video = Video.ConvertToYV12 #Using DGPulldown/HCenc to upsize FPS Video = Video.AddBorders(0,80,0,80) Video = Video.Spline64Resize(720,480) AudioDub(Video, Audio) <> <8/23/2011 3:31:34 PM> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 3883.3 MB HCenc Parameters: -ini "C:\Users\xyz\AppData\Local\Temp\DVD_0_file1.HCenc.ini" HCenc ini file: *INFILE C:\Users\xyz\AppData\Local\Temp\DVD_0_file1_1.avs *AVSRELOAD *OUTFILE C:\Users\xyz\Videos\DVD_0_file1.m2v *LOGFILE C:\Users\xyz\AppData\Local\Temp\DVD_0_file1.HCenc.log *MAXBITRATE 9000 *BITRATE 3938 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *TFF *PULLDOWN *BIAS 40 *DC_PREC 8 *MATRIX MPEG *AQ 1 *LUMGAIN 1 *SMP *PRIORITY IDLE *WAIT 2 <> <8/23/2011 5:49:13 PM> END VIDEO ENCODING OPERATIONS A2DVideoSource: DirectShowSource Created File: C:\Users\xyz\Videos\DVD_0_file1.m2v (3885 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 3965 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:17:52 hours - 198339 frames <> <8/23/2011 5:49:14 PM> START AUDIO ENCODING OPERATIONS (Track 1) FFmpeg Parameters: -threads 2 -i "C:\Users\xyz\AppData\Local\Temp\DVD_0_file1_1.avs" -y -vn -acodec ac3 -ac 6 -ar 48000 -ab 448k "C:\Users\xyz\Videos\DVD_0_file1_1.ac3" <> <8/23/2011 6:43:56 PM> END AUDIO ENCODING OPERATIONS (Track 1) Created File: C:\Users\xyz\Videos\DVD_0_file1_1.ac3 (441.8 MB) OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 2:17:52 hours (0 ms delay) <> <8/23/2011 6:43:56 PM> START DVD AUTHORING OPERATIONS BatchMux Parameters: -arglist "C:\Users\xyz\AppData\Local\Temp\DVD_0_BatchMux.ini" BatchMux ini file: -d "C:\Users\xyz\Videos\DVD_0\VIDEO_TS" -mxp "C:\Users\xyz\AppData\Local\Temp\DVD_0_MuxMan.mxp" -l "C:\Users\xyz\AppData\Local\Temp\DVD_0_MuxMan.log" -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan" -prio LOW -palette "C:\Users\xyz\AppData\Local\Temp\DVD_0_Palette.txt" -v "C:\Users\xyz\Videos\DVD_0_file1.m2v" -vidmode LB -a1 "C:\Users\xyz\Videos\DVD_0_file1_1.ac3" -a1lang en -cellfr "C:\Users\xyz\Videos\DVD_0_file1_Chapters.txt" -progfr "C:\Users\xyz\Videos\DVD_0_file1_Chapters.txt" -chapfr "C:\Users\xyz\Videos\DVD_0_file1_Chapters.txt" <> <8/23/2011 7:00:58 PM> CHECK DVD SIZE DVD Folder (actual) Size: 4427 MB vs Estimated Size: 4450 MB -> 0.5% undersize vs Assets Size: 4326.8 MB -> OK <> <8/23/2011 7:00:58 PM> END DVD AUTHORING OPERATIONS Created Folder: C:\Users\xyz\Videos\DVD_0 (4427 MB) <> <8/23/2011 7:00:58 PM> Log file created by AVStoDVD Release 2.4.1 <> file2 log (failure)_________________________________________________________ <8/23/2011 7:48:02 PM> START PROCESS <> <8/23/2011 7:48:02 PM> PROJECT SETTINGS DVD Video Standard: NTSC DVD Titles number: 1 DVD Size: 4450/4450 MB (100%) DVD Output Setup: DVD Folder DVD Label: DVD DVD Menu: No Menu Output Folder: C:\Users\xyz\Videos Delete Temp Process Files: Yes Delete Working Files: Yes Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES MultiThread: 1 AVS Source Filter: A2DSource AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize Video Resolution: 0 Video BitRate Min: 2500 Video BitRate Level 1: 6500 Video Profile Level 2: 4500 Video BitRate Max: 8500 Keep DVD Compliant Video: 1 AC3 Audio Encoder: 0 PAL SpeedUp: 0 Force FFmpeg for Long Audio: 1 DVD Audio Format: 0 DVD Audio BitRate: 192 Keep DVD Compliant Audio: 1 Normalize Audio: 0 Auto Delay Audio: 1 DVD Audio Language (Primary): EN - English DVD Audio Language (Secondary): EN - English DVD Subs Language (Primary): EN - English DVD Subs Language (Secondary): EN - English DVD Subs Font: Tahoma 18pt (255,255,255) Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: E: hp DVDRAM GT30L mP06 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Save Log file: 1 Display errors messages: 1 Unload ActiveMovie library: 0 Adjust ffdshow mixer: 1 Save General Settings: 0 <> <8/23/2011 7:48:02 PM> TITLE 1 SOURCE FILES Video: C:\Users\xyz\Downloads\file2.mkv Info: AVC - 2802 kbps - 1280x544 - DAR 2.353 - 24 fps (CFR) - Progressive - 2:25:07 hours - 208983 frames Audio 1: C:\Users\xyz\Downloads\file2.mkv Info: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 2:25:07 hours (0 ms delay) - Internal [MediaInfoLib - v0.7.47] <> <8/23/2011 7:48:02 PM> AVISYNTH SCRIPT Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi") Video = A2DVideoSource("C:\Users\xyz\Downloads\file2.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp", FrameRate=24, VFR=false) # Audio is frameserved by AviSynth just for Preview and Edit purposes. Audio = A2DAudioSource("C:\Users\xyz\Downloads\file2.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp") Video = Video.ConvertToYV12 #Using DGPulldown/HCenc to upsize FPS Video = Video.AddBorders(0,88,0,88) Video = Video.Spline64Resize(720,480) AudioDub(Video, Audio) <> <8/23/2011 7:48:02 PM> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 2726 MB HCenc Parameters: -ini "C:\Users\xyz\AppData\Local\Temp\DVD_1_file2.HCenc.ini" HCenc ini file: *INFILE C:\Users\xyz\AppData\Local\Temp\DVD_1_file2_1.avs *AVSRELOAD *OUTFILE C:\Users\xyz\Videos\DVD_1_file2.m2v *LOGFILE C:\Users\xyz\AppData\Local\Temp\DVD_1_file2.HCenc.log *MAXBITRATE 7964 *BITRATE 2626 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *TFF *BIAS 30 *DC_PREC 8 *MATRIX MPEG *AQ 1 *LUMGAIN 1 *SMP *PRIORITY IDLE *WAIT 2 <> <8/23/2011 10:31:13 PM> END VIDEO ENCODING OPERATIONS A2DVideoSource: DirectShowSource Created File: C:\Users\xyz\Videos\DVD_1_file2.m2v (2727.4 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 2642 kbps - 720x480 - DAR 1.778 - 24 fps (CFR) - Progressive (TFF) - 2:25:07 hours - 208983 frames <> <8/23/2011 10:31:13 PM> START PULLDOWN OPERATIONS DGPulldown Parameters: "C:\Users\xyz\Videos\DVD_1_file2.m2v" -srcfps 24.000 -destfps 29.97 -inplace -tff <> <8/23/2011 10:36:59 PM> END PULLDOWN OPERATIONS DGPulldown executed on File: C:\Users\xyz\Videos\DVD_1_file2.m2v (2727.4 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 2642 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:25:07 hours - 208772 frames <> <8/23/2011 10:37:00 PM> START AUDIO DEMUXING OPERATIONS (Track 1) FFmpeg Parameters: -i "C:\Users\xyz\Downloads\file2.mkv" -acodec copy "C:\Users\xyz\Videos\DVD_1_file2_1.ToFix.dts" <> <8/23/2011 10:45:46 PM> END AUDIO ENCODING OPERATIONS (Track 1) Created File: C:\Users\xyz\Videos\DVD_1_file2_1.dts (1566.4 MB) OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 2:25:03 hours (0 ms delay) <> <8/23/2011 10:45:47 PM> START DVD AUTHORING OPERATIONS BatchMux Parameters: -arglist "C:\Users\xyz\AppData\Local\Temp\DVD_1_BatchMux.ini" BatchMux ini file: -d "C:\Users\xyz\Videos\DVD_1\VIDEO_TS" -mxp "C:\Users\xyz\AppData\Local\Temp\DVD_1_MuxMan.mxp" -l "C:\Users\xyz\AppData\Local\Temp\DVD_1_MuxMan.log" -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan" -prio LOW -palette "C:\Users\xyz\AppData\Local\Temp\DVD_1_Palette.txt" -v "C:\Users\xyz\Videos\DVD_1_file2.m2v" -vidmode LB -a1 "C:\Users\xyz\Videos\DVD_1_file2_1.dts" -a1lang en -cellfr "C:\Users\xyz\Videos\DVD_1_file2_Chapters.txt" -progfr "C:\Users\xyz\Videos\DVD_1_file2_Chapters.txt" -chapfr "C:\Users\xyz\Videos\DVD_1_file2_Chapters.txt" <> <8/23/2011 11:02:19 PM> CHECK DVD SIZE DVD Folder (actual) Size: 2802 MB vs Estimated Size: 4450 MB -> 37.0% undersize vs Assets Size: 4293.8 MB -> Warning! <> <8/23/2011 11:02:19 PM> END DVD AUTHORING OPERATIONS Created Folder: C:\Users\xyz\Videos\DVD_1 (2802 MB) <> <8/23/2011 11:02:20 PM> Log file created by AVStoDVD Release 2.4.1 <> |
25th August 2011, 00:20 | #1863 | Link |
Hi Mrc,
Related to last issue, i take out the subtitles and everything is okay for the conversion. I was only had that subtitle, no srt. I can even convert it, look like they are corrupted. THanks :--)
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
25th August 2011, 13:10 | #1864 | Link |
AVStoDVD Dev
@ggtop
I will think about that @shreeit in project #2, force DTS track encoding to AC3: go to 'Edit Title'/'Audio', toggle off 'Auto Audio Setup' and 'Keep DVD-compliant audio'. @8ternity you are welcome Bye |
25th August 2011, 21:48 | #1865 | Link |
@MrC. I uncheck 'Keep DVD-compliant audio' from preference/audio menu. Can't find go to 'Edit Title'/'Audio', toggle off 'Auto Audio Setup'
I noticed I got warning/error by ffmeg.exe Stream #0.1: Audio: pcm_s161e, 48000 Hz, 6 channels, s16 4608 kb/s Incompatible sample format 's16' for codec 'ac3', autoselecting format 'flt' [ac3 @07c097e0] No channel layout specified. The encoder will guess the layout, but might be incorrect |
25th August 2011, 22:11 | #1866 | Link | ||
AVStoDVD Dev
Bye |
3rd September 2011, 15:04 | #1868 | Link |
Hi, small remark:
I was trying to get a DVB recording to DVD. I pulled it through ProjectX to remove any errors first. It gave me a m2v and a mp2 file which I threw at AVStoDVD. But on authoring I kept getting the following error: Code:
"Warning! Errors found during Title 1 Audio Track 1 encoding. Do you want to start Backup Audio encoding routine (FFmpeg based)? [YES/NO]" I assume this behavior is intentional, but it can have side-effects, like in my case where I wanted to keep original audio quality but the audio stream was encoded. Maybe this behavior can be smartened a bit so there's no unnecessary encoding when a stream copy can be done. Maybe the warning could be clearer too; I didn't know that by pressing YES I was choosing for an encode instead of a stream copy. Last edited by Sjakko; 3rd September 2011 at 19:30. Reason: some tweaking |
4th September 2011, 15:19 | #1869 | Link | |
I have the same problem as Whiskey. I think the problem is a typing error in the SubtitleCreator parameters AVStoDVD provides. See, there's no space between the "-i" and the IFO path parameter! Code:
SubtitleCreator Parameters: "C:\DVD\DVD_0_Clash.Of.Empires.Battle.For.Asia.srt" -p4 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO" |
5th September 2011, 13:08 | #1870 | Link | |
AVStoDVD Dev
Bye |
5th September 2011, 13:09 | #1871 | Link | |
AVStoDVD Dev
Bye |
5th September 2011, 14:25 | #1872 | Link | |
<5-9-2011 15:01:49> START PROCESS <> <5-9-2011 15:01:49> PROJECT SETTINGS DVD Video Standard: PAL DVD Titles number: 1 DVD Size: 1217/4450 MB (27%) DVD Output Setup: DVD Folder DVD Label: DVD DVD Menu: No Menu Output Folder: F:\Werkmap\AVStoDVD Delete Temp Process Files: No Delete Working Files: No Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES MultiThread: 1 AVS Source Filter: A2DSource AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize Video Resolution: 0 Video BitRate Min: 2500 Video BitRate Level 1: 6500 Video Profile Level 2: 4500 Video BitRate Max: 8500 Keep DVD Compliant Video: 1 AC3 Audio Encoder: 0 PAL SpeedUp: 0 Force FFmpeg for Long Audio: 1 DVD Audio Format: 1 DVD Audio BitRate: 192 Keep DVD Compliant Audio: 1 Normalize Audio: 0 Auto Delay Audio: 1 DVD Audio Language (Primary): EN - English DVD Audio Language (Secondary): EN - English DVD Subs Language (Primary): EN - English DVD Subs Language (Secondary): EN - English DVD Subs Font: Tahoma 18pt Bold (255,255,255) Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: I: TSSTcorp CDDVDW SH-S223F SB03 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Save Log file: 1 Display errors messages: 1 Unload ActiveMovie library: 0 Adjust ffdshow mixer: 1 Save General Settings: 0 <> <5-9-2011 15:01:49> TITLE 1 SOURCE FILES Video: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.m2v Info: MPEG-2 Video - 2987 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 51:31 minutes - 77275 frames Audio 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2 Info: MPEG-1 Audio layer 2 - 256 kbps - CBR - 2 ch - 48000 Hz - 51:31 minutes (0 ms delay) - External Subs 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.srt [] <> <5-9-2011 15:01:49> AVISYNTH SCRIPT Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi") # Video is frameserved by AviSynth just for Preview and Edit purposes. Video = A2DVideoSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.m2v", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP", FrameRate=25, VFR=false) # Audio is frameserved by AviSynth just for Preview and Edit purposes. Audio = A2DAudioSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP") Video = Video.ConvertToYV12(interlaced=true) AudioDub(Video, Audio) <> <5-9-2011 15:01:49> START VIDEO DEMUXING OPERATIONS Target Video FileSize: 1100,6 MB FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.m2v" -vcodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.m2v" <> <5-9-2011 15:02:28> END VIDEO ENCODING OPERATIONS Created File: F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.m2v (1094,2 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 2987 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 51:31 minutes - 77275 frames <> <5-9-2011 15:02:28> START AUDIO DEMUXING OPERATIONS (Track 1) FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2" -acodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.ToFix.mp2" <> <5-9-2011 15:02:51> START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1) FFmpeg Parameters: -threads 2 -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2" -y -vn -acodec mp2 -ar 48000 -ab 256k "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.mp2" <> <5-9-2011 15:03:24> END AUDIO ENCODING OPERATIONS (Track 1) Created File: F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.mp2 (94,3 MB) OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 256 kbps - CBR - 2 ch - 48000 Hz - 51:31 minutes (0 ms delay) <> <5-9-2011 15:03:24> START SUBS ENCODING OPERATIONS (Track 1) SRT fixing routine applied (0 lines fixed) SubtitleCreator Parameters: "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.srt" -p2 -i"C:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO" <> <5-9-2011 15:03:34> PROCESS ABORTED DURING TITLE 1 SUBS (TRACK 1) ENCODING OPERATIONS. CHECK LOG FILE <F:\WERKMAP\AVSTODVD\DVD_0.LOG> FOR MORE INFO. <> <5-9-2011 15:03:34> Log file created by AVStoDVD Release 2.4.1 <> Now below the exact same project, only now I renamed 1 character in the source folder: The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS instead of The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS And now the audio stream copy succeeds! The log: Code:
<5-9-2011 15:04:13> START PROCESS <> <5-9-2011 15:04:13> PROJECT SETTINGS DVD Video Standard: PAL DVD Titles number: 1 DVD Size: 1217/4450 MB (27%) DVD Output Setup: DVD Folder DVD Label: DVD DVD Menu: No Menu Output Folder: F:\Werkmap\AVStoDVD Delete Temp Process Files: No Delete Working Files: No Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES MultiThread: 1 AVS Source Filter: A2DSource AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize Video Resolution: 0 Video BitRate Min: 2500 Video BitRate Level 1: 6500 Video Profile Level 2: 4500 Video BitRate Max: 8500 Keep DVD Compliant Video: 1 AC3 Audio Encoder: 0 PAL SpeedUp: 0 Force FFmpeg for Long Audio: 1 DVD Audio Format: 1 DVD Audio BitRate: 192 Keep DVD Compliant Audio: 1 Normalize Audio: 0 Auto Delay Audio: 1 DVD Audio Language (Primary): EN - English DVD Audio Language (Secondary): EN - English DVD Subs Language (Primary): EN - English DVD Subs Language (Secondary): EN - English DVD Subs Font: Tahoma 18pt Bold (255,255,255) Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: I: TSSTcorp CDDVDW SH-S223F SB03 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Save Log file: 1 Display errors messages: 1 Unload ActiveMovie library: 0 Adjust ffdshow mixer: 1 Save General Settings: 0 <> <5-9-2011 15:04:13> TITLE 1 SOURCE FILES Video: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.m2v Info: MPEG-2 Video - 2987 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 51:31 minutes - 77275 frames Audio 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.mp2 Info: MPEG-1 Audio layer 2 - 256 kbps - CBR - 2 ch - 48000 Hz - 51:31 minutes (0 ms delay) - External Subs 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.srt [] <> <5-9-2011 15:04:13> AVISYNTH SCRIPT Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi") # Video is frameserved by AviSynth just for Preview and Edit purposes. Video = A2DVideoSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.m2v", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP", FrameRate=25, VFR=false) # Audio is frameserved by AviSynth just for Preview and Edit purposes. Audio = A2DAudioSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.mp2", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP") Video = Video.ConvertToYV12(interlaced=true) AudioDub(Video, Audio) <> <5-9-2011 15:04:13> START VIDEO DEMUXING OPERATIONS Target Video FileSize: 1100,6 MB FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.m2v" -vcodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.m2v" <> <5-9-2011 15:04:56> END VIDEO ENCODING OPERATIONS Created File: F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.m2v (1094,2 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 2987 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 51:31 minutes - 77275 frames <> <5-9-2011 15:04:56> START AUDIO DEMUXING OPERATIONS (Track 1) FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.mp2" -acodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.ToFix.mp2" <> <5-9-2011 15:05:04> END AUDIO ENCODING OPERATIONS (Track 1) Created File: F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.mp2 (94,3 MB) OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 256 kbps - CBR - 2 ch - 48000 Hz - 51:31 minutes (0 ms delay) <> <5-9-2011 15:05:04> START SUBS ENCODING OPERATIONS (Track 1) SRT fixing routine applied (0 lines fixed) SubtitleCreator Parameters: "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.srt" -p2 -i"C:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO" <> <5-9-2011 15:05:15> PROCESS ABORTED DURING TITLE 1 SUBS (TRACK 1) ENCODING OPERATIONS. CHECK LOG FILE <F:\WERKMAP\AVSTODVD\DVD_0.LOG> FOR MORE INFO. <> <5-9-2011 15:05:15> Log file created by AVStoDVD Release 2.4.1 <> I can provide you with temporary files for both cases above if you want. Thank you! |
6th September 2011, 11:41 | #1873 | Link | ||
AVStoDVD Dev
Bye |
6th September 2011, 12:19 | #1874 | Link | ||
You've got mail. |
7th September 2011, 12:57 | #1875 | Link | |
AVStoDVD Dev
Bye |
8th September 2011, 13:43 | #1877 | Link |
Hi mrc,
Did you had instruction regarding custom dvd menu templates (background, button, etc.) to customisez a dvd menu in default? I want to check for creating a theme menu, starting to play with that to create one menu for testing.
9th September 2011, 16:12 | #1878 | Link |
AVStoDVD Dev
@8ternity
you can start having a look at the 'Templates - Readme.txt' file under '\AVStoDVD\Menu\Templates' folder. Then you can download some custom templates from here and get some hints. I hope you will share your creations with us. Thanks in advance Bye |
10th September 2011, 11:12 | #1879 | Link |
Just an info
Hi all,
right now I'm converting some dozens DV tapes to DVD and always wondered why the preview doesn't work although the final DVD / encoded file works fine. My setup is Windows 7 64bit, Cedocida DV codec installed, AVS Source Filter: AviSource(). I did some research and found that I have to use all involved components in the same "environment". Because I have 32bit Avisynth installed it loads the 32bit cedocida VfW codec with AviSource() enabled, I also have to use 32bit MPC-HC for preview. And that was the culprit, because my default preview player path pointed to the 64bit version. After installing the 32bit version in parallel and changing the path everything works fine. ggtop Last edited by ggtop; 13th September 2011 at 22:02. |
