Old 30th May 2009, 15:23   #861  |  Link
turbojet
OK thanks.
Old 6th June 2009, 14:21   #862  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
A new 2.2.0 Alpha (build 090605) is available to download. Here you are the main mods:
- Some bugs fixed
- Added files drag&drop capability to main window
- Added 'Title'/'View Title Info' command
- Added 'Change ffdshow Mixer Output to <same as input>' option to 'Preferences'/'Misc'
- Added support to text-only style DVD Menu
- Added DVD Menu highlights customization
- Added DVD Menu thumbnails shadow customization
- Added DVD Menu video bitrate customization
- MediaInfo updated to 0.7.16
With this Alpha I have added all the new features I planned for 2.2.0 release. Let me know if you find any issues or within days (I'm updating the Help Section.. yawn!) I will convert it into Final.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 6th June 2009, 20:36   #863  |  Link
dialysis1
dialysis1's Avatar
I can't seem to download it.
It's okay now.
Last edited by dialysis1; 7th June 2009 at 03:02. Reason: Site was down for a while
dialysis1 is offline   Reply With Quote
Old 6th June 2009, 21:14   #864  |  Link
hlrsnd
Are you going to use the latest HCEncoder with 2.2?
hlrsnd is offline   Reply With Quote
Old 6th June 2009, 22:24   #865  |  Link
Milardo
I'm not sure how to do this exactly, but if I wanted to just set the video bitrate to just 800 kb/s so I could fit as many videos as I could on a dvd but still maintain good enough quality, how do I do that? I mean there are a lot of windows that pop up when encoding/converting dvds that seem to be configurable so I'm a bit confused. Thanks in advance for any good replies.
Bugs: Can't seem to access the dvd menu option says "run-time error 35600 index out of bounds"
Milardo is offline   Reply With Quote
Old 7th June 2009, 14:37   #866  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Latest 0.24 beta still have some small bugs, thus the answer is no. But, if you want, you can overwrite current (0.23) HCenc.exe file with the new (0.24 beta) one. Everything will work, except for new HCenc features, of course.
Very simple indeed: go to 'Preferences'/'AudioVideo' and set 800 to 'Video Lower Avg BitRate'. Press OK (save settings if you want) and load your ton of videos.
Please be more specific: when does it happen (Menu Wizard, Menu Editor, ...)? How is your project set up (titles number, output, configuration, ...)? Is the error systematic or random?
Let me know
Bye
MrC
AVStoDVD Homepage
Old 7th June 2009, 20:53   #867  |  Link
Filbert
I get the same "run-time error 35600 index out of bounds" with default configuration. Just pressing "DVD Menu" (or "Menu Wizard") causes this error (doesn't matter which kind of video or number of titles). Clean "no install", AVStoDVD_220Alpha090515 worked without probs. System is german XP Prof. SP3 + updates...
Greets, Filbert
Filbert is offline   Reply With Quote
Old 7th June 2009, 23:48   #868  |  Link
Milardo
Thanks on how to set the low bitrate. For the error message, yeah just pressing the dvd menu button causes the error I had two videos in the program tried asf and m2v videos but got the same error seems to be systematic error.
Old 8th June 2009, 05:20   #869  |  Link
MysticE
Same here. Added 3 AVI's and hit 'Menu Wizard', same sort of 'out of bounds error'.
MysticE is offline   Reply With Quote
Old 8th June 2009, 11:40   #870  |  Link
dialysis1
dialysis1's Avatar
Same here.
Click on ok and the program closes.
Old 8th June 2009, 20:16   #871  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Very weird. From my side, I must admit that I cannot replicate the error. Just a quick troubleshooting:
1. Did you use a new folder for build 090605 or did you overwrite build 090515?
2. Using build 090515, did you change anything from default DVDMenu Wizard settings?
3. Quick & dirt fix: locate and delete registry key "HKEY_LOCAL_MACHINE\SOFTWARE\AVStoDVD\DVDMenu", then retry with build 090605. If you feel in "help mode on", take a screenshot of registry key before deleting it and post here.
Thanks guys
Bye
MrC
AVStoDVD Homepage
Old 8th June 2009, 21:25   #872  |  Link
Filbert
1. new folder
2. no change in 090515
3. hmm, can't find this regkey, nor a similar one.
[edit] okay, after doing a menu with build 090515 i get this regkey, but it makes no difference if it is there or not. 090605 doesn't create this key as it crashes before it can...
Greets, Filbert
Old 8th June 2009, 22:35   #873  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Ok, bug found.
I hope to release another Alpha (last?) tomorrow.
Bye
MrC
AVStoDVD Homepage
Old 9th June 2009, 18:05   #874  |  Link
Filbert
Ok, bug found.
Thanx, dvd menue in build 090609 seems to work again :-)
Though I get some error during audio operations, will do tests and post log...
Greets, Filbert
Old 9th June 2009, 19:21   #875  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Here we go, a new 2.2.0 Alpha (build 090609) is out. Small change log:
- DVD Menu Wizard form opening bug fixed
- Improved DVD Menu highlights links generation routine
- Updated Help Section
Bye
MrC
AVStoDVD Homepage
Old 9th June 2009, 20:25   #876  |  Link
Filbert
This seems to affect all alpha builds since final 2.1.4 (that build doesn't produce the error), see attached logfile.
The videofile is a DV Quicktime Movie (exported from Avid Xpress Pro). When loading into AVStoDVD i get asked to choose an audio track because AVS detected 2 Audio Tracks (although I know there is only one 2ch audio track). With 2.1.4. i didn't got this question (it showed/used only one track).
If I check the file with Mediainfo it also only shows one track:
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Codec ID : twos
Duration : 19s 240ms
Bit rate mode : Constant
Bit rate : 1536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 3.52 MiB (5%)
Encoded date : UTC 2007-10-16 14:38:28
Tagged date : UTC 2007-10-16 14:38:36
When I start encoding it aborts the audio encoding (no matter if I encode to AC3 or leave it as original WAV (which should be DVD compliant). The "testrun.ToFix.wav" has the length 0, so demuxing seems to go wrong.
If I convert the same file using an AVI container it works...
Greets, Filbert
Old 9th June 2009, 21:29   #877  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Format : PCM
Codec ID : twos
Greets, Filbert
Filbert, while waiting for attachment approval, let me do 2 preliminary considerations:
1. If AVStoDVD says that there are 2 audio tracks, the reason is that MediaInfo.dll detects 2 audio tracks (code: .AudioTracksCount = bstr(MediaInfo_Get(Handle, MediaInfo_Stream_General, 0, StrPtr("AudioCount"), MediaInfo_Info_Text, MediaInfo_Info_Name))). Anyway, if you select track 0, then audio track handling is same as release 2.1.4. Only if you select track >0, then I force the use of ffmpegsource.dll plugin to extract the track. Thus, do not bother about this issue.
2. You are saying that no matter you select audio re-encode or keep original, you get errors. It could be, but they must be 2 different errors, because the routines are very different (i.e. audio re-encoding does not produce the intermediate file "testrun.ToFix.wav"). Please clarify and/or attach the 2 log files.
BTW, thanks for the debug and the feedback. A proactive help is always very appreciated.
Bye
MrC
AVStoDVD Homepage
Old 10th June 2009, 08:35   #878  |  Link
Filbert
BTW, if I really do select track 1 I get an avysynth error:
AviSynth Error!
Avisynth open failure:
FFmpegSource: Invalid audio track number
(C:\DOKUME~1\schnitt\LOKALE~1\Temp\testrun.avs, line 9)
As far as I see the two logs are the same (using Winmerge), they only differ in time. Both settings (DVD Audio Wav, keep DVD compliant Audio checked/not checked) produce the "testrun.ToFix.wav". The interesting part of the log is the same as the previous attached complete log file:
<10.06.2009 08:47:43>
START AUDIO DEMUXING OPERATIONS
FFmpeg Parameters: -i "D:\testrun.mov" -acodec copy "C:\Dokumente und Einstellungen\schnitt\Eigene Dateien\testrun.ToFix.wav"
ERROR DURING OPERATIONS ('AUDIO enconding operations' Section): 0 -
PROCESS ABORTED.
Hope this helps, otherwise I can do some more testing or upload a testfile...
Greets, Filbert
Old 10th June 2009, 20:19   #879  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Filbert
things are becoming very interesting. Yes, please, upload the file or a portion of it.
Bye
MrC
AVStoDVD Homepage
Old 10th June 2009, 21:46   #880  |  Link
Filbert
Uploaded it, see PM. It's a different file with same error. It was converted from (working) AVI container to Quicktime Movie using AppleDV Codec. Only difference is that it doesn't show up the 2 audio tracks when loading the file (which might be caused by exporting empty audio tracks from the timeline in Avid).
Hope it helps... Greets, Filbert
[IMG] code is Off
