8th January 2009, 16:46 | #7721 | Link | |
use 'r'
This is evil logic to keep description of application in "changelog.txt". Especially, while help screen exists. And another little bug, as far as it goes. When capturing output from "eac3to" like this: "eac3to>help.txt", file is filled with 08h characters, but they must have not be there. P.S. Madshi, I appreciate your work very-very much, there's no doubt! Making world a little more perfect is great. Last edited by n0mag!c; 8th January 2009 at 17:17. |
8th January 2009, 17:14 | #7722 | Link |
I would guess the bug or change happened because of this problem:
http://forum.doom9.org/showpost.php?...postcount=7607 |
8th January 2009, 18:34 | #7723 | Link |
madshi,
Could you add a command that forces dialog normalization...something like -forceDialnorm Or even a command that would me me specify what level of dialog normalization an ac3 file has? Either way would work. Yet another option would be if eac3to detected a -0 dialog normalization level as having dialog normalization so that when eac3to extracted the file it would change it to -31. Reason I ask is so that I can "fix" my ac3 tracks with -0 dialog normalization without having to re-encode them. I believe that this wouldn't be too big of a feature to add since removing dialog normalization doesn't seem to require re-encoding (seems like its just changing the value from whatever the file was to -0 pre v2.85 or -31 post v2.85 .) One other question : When I do an eac3to command on a bluray structure, it tells me my main movie track's video is something like 1080p24. lets say that was feature 1. So I do a eac3to 1) command and again is says the video track is 1080p24. When I check the m2ts file with mediainfo it says the video is 23.976 FPS. MeGUI also detects the video as 23.976 FPS. I transcode my video down to 720p and create a bluray structure with tsMuxer. When I play my avchd discs on my bluray player, the video stutters when there's movement...like if the camera is following the actor and the background is moving, the background seems to stutter. Now I can't figure out for the life of me why this is happening. Only difference I have noticed is the following. eac3to reports 1080p24 on both the regular eac3to command against the original bluray and when I look at the main movie feature (ie eac3to 1) ) When I do a eac3to command on my bluray structured transcoded bluray, it reports 720p24. But when I look at the main movie feature (eac3to 1)) it reports 720p23. I looked at my bluray structure with bdedit.exe on both the original bluray and my transcoded bluray and I don't see any difference. Where does eac3to get the information from that would be having eac3to say its 720p23 instead of 720p24? I think this might have something to do with why my video seems to stutter. PS. doesnt happen on my pc when I play the m2ts file directly. And yes when I transcode my video it is transcoded at 23.976 fps. Last edited by alc0re; 8th January 2009 at 18:36. |
8th January 2009, 19:45 | #7724 | Link | |
use 'r'
Modern TVs use different techniques to eliminate this effect, personally, I prefer interpolation of additional frames, similar to Philips' DNM (digital natural motion). But many others don't like it for the "theatre" look. Last edited by n0mag!c; 8th January 2009 at 22:24. |
8th January 2009, 21:07 | #7726 | Link | ||
It's not a bug, it's just what gets piped from the screen/console to the file. All you need to do is run this: eac3to -log=help.txt
Chumbo Last edited by Chumbo; 8th January 2009 at 21:13. |
8th January 2009, 21:38 | #7727 | Link | |
use 'r'
But this happens only with "eac3to"... |
8th January 2009, 23:29 | #7728 | Link |
@Madshi,
When I convert a DTS Hi-Res stream (from Predator 2) to LPCM, eac3to doesn't seem to list the final bit-depth: Code:
eac3to 00013.m2ts 3: c:\video\temp.pcm M2TS, 1 video track, 9 audio tracks, 24 subtitle tracks, 1:48:00 1: Chapters, 33 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Hi-Res, English, 5.1 channels, 24 bits, 3018kbps, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) ... [a03] Extracting audio track number 3... [a03] Decoding with ArcSoft DTS Decoder... [a03] Swapping endian... [a03] Remapping channels... [a03] Creating file "c:\video\temp.pcm"... [a03] The last DTS frame is incomplete and thus gets skipped. Video track 2 contains 155364 frames. eac3to processing took 17 minutes, 40 seconds. Done. Thanks
Gorgeous, delicious, deculture! |
9th January 2009, 00:09 | #7730 | Link | |
use 'r'
Sometimes 23, 24, 23.976 are used as synonyms. Last edited by n0mag!c; 9th January 2009 at 00:37. |
9th January 2009, 02:49 | #7731 | Link |
no i dont have that ability. To me I see stuttering a lot too but not like this. I can take the same movie and watch it from the retail bluray or hd-dvd and then transcode it and see a big difference.
BD-RE is not an option for me. I thought maybe the bitrate was too high also for a dvd, but I've been using Ryu77's profiles lately for avchd content. he's got a lower value in his profile. Ryu's profile : VBVBuffersize = 15000 and VBVMaxbirate = 17500. Those values are a lot lower than max 40000 for 4.1 (which is max supported.) I'm still curious why it says 1080p24 on the original bluray and not on the transcoded. If I can't figure this out I'm going to try playing the avchd disc on another brand bluray player. Problem with that is that it won't be on my tv. EDIT/UPDATE : This morning I transcoded The Matrix Revolutions using RipBot264 instead of MeGUI. My normal process is using MeGUI with Ryu77's AVCHD profile, with a target size of 8152 to fit on a dual layer dvd. I have been burning my movies to memorex dual layer dvds. I wanted to try something different so I transcoded the matrix 3 this morning using ripbot instead of megui. I also changed the target size to fit on a single layer dvd. I used ripbot's avchd/bluray profiles. I also burnt the movie to a Verbatim single layer dvd that I just bought cause I researched and found that Verbatim make better blank dvds. I'm watching that ripbot transcoded movie right now and I don't see the same stuttering issue. Unfortunately there were a few different things that are different now. RipBot did the transcoding, albeit with the same program that MeGUI does so that shouldn't be the difference. The bitrate is a lot lower than all my other transcodes since I made this one fit on a single layer dvd (dual layers are freakin expensive.) The x264 encoding profile is different. The level is different (4.0 as opposed to 4.1) I just now have to try different things to figure out what made the difference. Also, RipBot does the muxing through tsMuxer as opposed to me doing it manually. I need to figure out if RipBot changes any of the default muxing options in tsMuxer, like the "continually insert SPS/PPS or Add Picture Timing Info or or Use ASync I/O. EDIT/UPDATE 2 : Demuxed a movie that had the stuttering issue. Remuxed the movie with tsRemux and on the video stream options, I changed the level from High@4.1 to High@4.0. Tested. Works perfectly. So for anyone interested, the panasonic bd35 does not play nice with video at level 4.1. Last edited by alc0re; 9th January 2009 at 08:14. |
9th January 2009, 11:21 | #7733 | Link |
Crash when EVO unexpectedly ends / incomplete EAC3 packet
Madshi,
Had finally time to make a sample to reproduce the issue from post #7225. (issue: cannot extract EAC3 5.1 audio track from EVO, got endless 13ms audio overlap warnings, preventing eac3to from completing) However, while testing the sample, eac3to doesn't like incomplete EAC3 packets anymore seems. Got crash. Sample (part1.evo, 33MB): http://www.mediafire.com/?c1sn23b2kxr See also crash report send by email |
9th January 2009, 16:44 | #7734 | Link |
use 'r'
@Madshi
I've never got "Clipping detected" message on AC3-file before, is it normal?
eac3to v2.87 command line: D:\PROGRAMS\AUDIO\EAC3TO\eac3to.EXE en.ac3 J:\temp\trans\en.wavs ------------------------------------------------------------------------------ AC3, 5.1 channels, 2:23:27, 448kbps, 48khz, dialnorm: -27dB The Nero decoder doesn't seem to work, will use libav instead. Removing AC3 dialog normalization... Decoding with libav/ffmpeg... Remapping channels... Reducing depth from 64 to 24 bits... Writing WAVs... Creating file "J:\temp\trans\en.C.wav"... Creating file "J:\temp\trans\en.LFE.wav"... Creating file "J:\temp\trans\en.L.wav"... Creating file "J:\temp\trans\en.R.wav"... Creating file "J:\temp\trans\en.SL.wav"... Creating file "J:\temp\trans\en.SR.wav"... Clipping detected, a 2nd pass will be necessary. Starting 2nd pass... Removing AC3 dialog normalization... Decoding with libav/ffmpeg... Remapping channels... Reducing depth from 64 to 24 bits... Writing WAVs... Creating file "J:\temp\trans\en.L.wav"... Creating file "J:\temp\trans\en.C.wav"... Creating file "J:\temp\trans\en.R.wav"... Creating file "J:\temp\trans\en.LFE.wav"... Creating file "J:\temp\trans\en.SL.wav"... Creating file "J:\temp\trans\en.SR.wav"... eac3to processing took 9 minutes, 13 seconds. Done. Code:
====== INPUT FILE INFO ======================== File is ac3 Bitrate (kbit/s) 448 Act rate (kbit/s) 448.000 File size (bytes) 481990656 Channels mode 3/2: L+C+R+SL+SR Sampling Frec 48000 Low Frec Effects LFE: Present Duration 02:23:26.976 Frame length (ms) 32.000000 Frames/second 31.250000 Num of frames 268968 Bytes per Frame 1792.0000 Size % Framesize 0 CRC present: YES ============================================= ====== TARGET FILE INFO ====================== Start Frame 0 End Frame 268967 Num of Frames 268968 Duration 02:23:26.976 NotFixedDelay 0.0000 ============================================= ====== PROCESSING LOG ====================== P.S. Gosh, I'd rather be using 2.80... P.P.S. Here is that sample. Last edited by n0mag!c; 9th January 2009 at 16:56. |
9th January 2009, 18:18 | #7735 | Link |
is there actually any way to utilize DTS Express tracks somehow atm? using ac3filter, I only get garbage sound and muxing them with mkvmerge doesnt work as well yet. so is converting them to normal DTS or ac3 is the only choice I have atm?
9th January 2009, 18:47 | #7736 | Link | |
(hope i explained this correctly, madshi) Can't you use nero decoder with your media player (mpc)? I think is the only dshow decoder available for dts express. Otherwise conversion is the only way. |
9th January 2009, 19:49 | #7737 | Link |
Never knew you could do that. (since pcm/raw has no header and all). If at all possible, though, I'd like eac3to to include that information for DTS-HD tracks too, like it does for DTS-MA/TrueHD, etc.
9th January 2009, 20:09 | #7739 | Link | |
9th January 2009, 20:12 | #7740 | Link | |
By convention, command > log.txt should work with any console command line application. For some reason, eac3to prints 80 backspace characters at the beginning of each line. Wierd. Last edited by 73ChargerFan; 9th January 2009 at 20:20. |
eac3to |
