Old 14th November 2009, 12:23   #10461  |  Link
Egh
Originally Posted by boiled_sugar View Post
Hi
I tried weightp, the new feature of x264, but MPC-HC can't decode the encoded video correctly with DXVA. ffdshow decodes the video correctly.
Works here on 1337 build and XP x64. Obviously on VMR9 only, as mpchc doesn't really support EVR on my system....
BTW guys, congratulations on releasing a leet build 1337
Egh is offline
Old 14th November 2009, 15:33   #10462  |  Link
Px
>>^^__^^<<
Px's Avatar
Ok, got some free time to make bugreport
MPC HC doesn't show subtitles on some BD (Ip Man in my case)
File info
General
Complete name                    : H:\New\Ip.Man.2008.1080p.H264.Remux\BDMV\STREAM\00001.m2ts
Format                           : BDAV
Format/Info                      : Blu-ray Video
File size                        : 22.0 GiB
Duration                         : 1h 46mn
Overall bit rate                 : 29.6 Mbps
Maximum Overall bit rate         : 35.5 Mbps
Video
Menu ID                          : 1 (0x1)
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Duration                         : 1h 46mn
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 24.000 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Menu ID                          : 1 (0x1)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Duration                         : 1h 46mn
Bit rate mode                    : Constant
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Surround: L R, LFE
Sampling rate                    : 48.0 KHz
Stream size                      : 292 MiB (1%)
Language                         : Russian /  /
Audio #2
Menu ID                          : 1 (0x1)
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : MA
Duration                         : 1h 46mn
Bit rate mode                    : Variable
Channel(s)                       : 8 channels
Channel positions                : Front: L C R, Surround: L C C R, LFE
Resolution                       : 16 bits
Language                         : Chinese /  /
Text #1
Menu ID                          : 1 (0x1)
Format                           : PGS
Language                         : English /  /
Text #2
Menu ID                          : 1 (0x1)
Format                           : PGS
OS - Win XP x64, Video - ATI with latest drivers, DX up to date. Haali media splitter detects subtitle streams, but when I select one of them, produces error:
Internal splitter also doesn't help and it's behavior depends on revision:
1) b1249 detects all subtitle streams right, but doesn't show
2) b1326 incorrectly detects language of secondary stream
3) b1337 doesn't detect subtitle streams at all
Bug exists independent on opening m2ts file, index.bdmv or "Open DVD"
With PowerDVD subtitles shows fine
Px is offline
Old 14th November 2009, 17:07   #10463  |  Link
Opuz Klass
Hi there guys!
MPC-HC is crashing with Intel GMA500 graphics chipset when trying to play any video using EVR-CP in Windows 7. I would like to help you by providing you with minidumps but I'm not finding them. I've confirmed this behavior in several laptops using this chipset with Windows 7 (latest drivers).
Opuz Klass is offline
Old 14th November 2009, 18:48   #10464  |  Link
therealjoeblow
Feature Request: Smart-Stretch Shader
Would it be possible to add a shader that "smart-stretches" 4:3 media content to 16:9 similar to the way that PowerDVD does for DVD material, ie, where the center 1/3 of the image remains mostly undistorted, and the bulk of the stretching is done in the outer thirds, more towards the edges of the video frame? Kind of like projecting the image onto a cylinder...
Cheers,
The REAL Joe
therealjoeblow is offline
Old 14th November 2009, 19:42   #10465  |  Link
Snowknight26
http://mpc-hc.svn.sourceforge.net/vi...7&pathrev=1338
Wouldn't it be more appropriate if the stream names were "MPEG-2" instead of "MPEG 2", "H.264" instead of "H264", "Secondary DTS-HD High Resolution Audio" instead of "Secondary DTS HD High Resolution Audio", and "VC-1" instead of "VC1?"
Snowknight26 is offline
Old 14th November 2009, 19:52   #10466  |  Link
tetsuo55
MPC-HC Project Manager
should be easy to fix, please open a ticket on trac so it can be discussed and done
https://sourceforge.net/apps/trac/mpc-hc/newticket
tetsuo55 is offline
Old 14th November 2009, 20:51   #10467  |  Link
Mangix
Audiophile
boiled_sugar's sample works on my computer. using XP 32-bit, VMR9, DXVA, 195.39 GeForce drivers
Mangix is offline
Old 14th November 2009, 21:36   #10468  |  Link
kieranrk
Please watch your DVDs in their correct aspect ratios.
kieranrk is offline
Old 15th November 2009, 03:59   #10469  |  Link
Egh
tetsuo55:
do you think it would be a worthy feature is there was a method to override a sub style with default?
I know the styles can be edited on-the-fly, but if you want to revert a style to one's default choice, you have to adjust font, scaling, several colours, outline/shadow size etc. An "override" button in that tabsheet would be handy, imo. I'm so annoyed by some "creativity" styles that I quite so often just override them manually.
Egh is offline
Old 15th November 2009, 09:04   #10470  |  Link
tetsuo55
Originally Posted by Egh View Post
tetsuo55:
yeah a "display all text based subtitles as standard SRT" would probably be a good feature.
You can add it to the tracker, but we have no coders who want to work on adding this right now.
tetsuo55 is offline
Old 15th November 2009, 09:58   #10471  |  Link
easyfab
@boiled_sugar : I've the same problem on my Ati HD 2600 with mpc dxva and pdvd dxva : so it's an Ati bug, I hope it's only a driver problem and not hardware.
easyfab is offline
Old 15th November 2009, 11:22   #10472  |  Link
littleD
littleD's Avatar
I have ati and have corruption too.
BTw whats that anime?
littleD is offline
Old 15th November 2009, 14:22   #10473  |  Link
donaldtone
wishilist:
1. update ogglib in ogg Directshow splitter to support more formats: like Kate stream.
2. add Kate format subtitle support to subtitle render engine.
Then mpc-hc can completely support new version of ogv format. This format is totally free and theora, vorbis and kate are patent free codecs. Right now only VLC can support its subtitle.
donaldtone is offline
Old 16th November 2009, 00:29   #10474  |  Link
tetsuo55
i have run mpc-hc through the microsoft application verifier and it fails quite a few tests.
This is a call to all coders, please help us fix the crashes and memory leaks.
the verifier can be downloaded here:
http://www.microsoft.com/downloads/d...DisplayLang=en
The tests that give errors and cause crashes are:
Handles, Heaps, locks, low resource, LuaPriv and DangerousAPi
the goal should be to have an error free (and warning free) result with all tests enabled.
EDIT:
Also /SAFESEH fails to complete, some precompiled parts need to be recompiled with vs2008 with the /SAFESEH switch before MPC-HC itself can be compiled with it
EDIT2:
/DYNAMICBASE, /NXCOMPAT should be added by default (and /SAFESEH once that has been fixed)
Also /RTC1, /Od can be used to find out more about the memory leaks/crashes and if you happen to have a enterprise version of vs2008 /analyse will give even more info
EDIT3:
Some data:
On my systems:
about 80% of allocated ram is unused/leaked by mpc-hc
mpc-hc leaks 4kb/s during playback
during playback 200MB+ of pagefile is allocated and heavily used (many pagefaults)
Cleaned with no movie mpc-hc only uses 700kb of ram, uncleaned it uses 13MB and with a movie the lowest i've seen is 40MB(18MB cleaned)
tetsuo55 is offline
Old 16th November 2009, 02:46   #10475  |  Link
boiled_sugar
戦場ヶ原蕩れ
I'm sorry. The corruption turned out to be x264 bug. Now it's fixed.
Tegami Bachi
boiled_sugar is offline
Old 16th November 2009, 03:41   #10476  |  Link
Opuz Klass
tetsuo55,
Have you read my report in post 10489 of this thread? Please let me know how I can help you solving this problem.
Thanks
Old 16th November 2009, 03:45   #10477  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
Hi,why Complete Last mpc-hc give me error:
MEDIASUBTYPE_DVB_SUBTITLES not defined.
betaking is offline
Old 16th November 2009, 04:49   #10478  |  Link
nuhkka
why does my mpc-hc freeze when the windows uac thing comes up?
nuhkka is offline
Old 16th November 2009, 08:56   #10479  |  Link
tetsuo55
Originally Posted by Opuz Klass View Post
Hi there guys!
have a look here: http://sourceforge.net/apps/trac/mpc...ing_guidelines
see here http://forum.doom9.org/showthread.ph...75#post1344275
tetsuo55 is offline
Old 16th November 2009, 14:11   #10480  |  Link
STaRGaZeR
4:2:0 hater
Same question:
Error 2 error C2065: 'MEDIASUBTYPE_DVB_SUBTITLES' : undeclared identifier SubtitleInputPin.cpp 68
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline
dxva, h264, home cinema, media player classic, mpc-hc
