17th August 2007, 01:39 | #481 | Link |
Otaku
@casimir666
I have found a bug regarding that "remember file position" option. If you let a file reach the end then mpc will play the next in the playlist but if you try to play the previous file again it will resume from the end meaning that it will just skip to the next track instead of playing the file from the beginning. also regarding raynor case... probably both dvd and file entries from "remember dvd position" and "remember file position" should be cleared if those option are disabled or you should add a button in mpc to clear them like "clear dvd/file history" button.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
17th August 2007, 03:22 | #482 | Link |
http://rapidshare.com/files/46651266....ts.03.ts.html
This video has two audio tracks. At least is what VLC tells me. But I can't see/switch the tracks using MPC. Can anyone do it? |
17th August 2007, 04:44 | #483 | Link | |
Nothing (as in: nil, niet, nada, nichts, rien) should be saved or remembered in that case ... Of course, If you had them checked, and decide to uncheck them, the existing saved positions / file histories should all be cleared automatically. All the best, raynor Last edited by raynor; 17th August 2007 at 04:51. |
17th August 2007, 15:36 | #484 | Link |
Otaku
Well I said what you quoted in case the first suggestion is not possible. Those entries are only saved because you used the "remember" feature, they are not saved if you don't use the function.
17th August 2007, 17:08 | #485 | Link | |
even if you DO NOT use the "Remember File Position" feature (i.e. the checkbox is unchecked). That is the whole issue. Don't believe me ? Try it for yourself : (1) Delete all Gabest registry settings, (2) use a fresh download of MPCHC, unzip it (3) Note that the "Remember File Position" checkbox is already disabled by default (!) (4) Also manually uncheck "Keep History Of Recently Opened Files" if you want, even though this has got nothing to do with the other feature and is irrelevant in our case (5) Play some files .... then quit the player (6) ---> the file paths (e.g. File Name 1= C:\Videos\Something.avi) are saved in the registry. Again, If one does not use this feature, (which I don't) nothing should be saved or remembered at all (and existing entries should be cleared if the feature is used for some time and then disabled later) Please, Casimir, change this behavoiur, and "respect" the chosen setting. --raynor Last edited by raynor; 18th August 2007 at 15:40. |
18th August 2007, 23:15 | #486 | Link | |
I've checked for both EVR and EVR Custom, no EVR output with MPEG-2 Internal filter (1.0.9.0) playing DVDs here. If I disable the internal decoder, it will use Microsoft (Vista) Default MPEG-2 decoder with EVR alright. But it doesn't work with EVR Custom (so I can't use shaders to correct colors). Microsoft's MPEG-2 decoder doesn't work with Haali Renderer either, so I can't get any color correction with this decoder. And the internal decoder with Haali gives me the stupid Macrovision Fail message. Hell !!! It would be perfect if I could get MPC's internal MPEG-2 decoder (that is awesome) with EVR Custom or Haali. Or... if I could get Microsoft's MPEG-2 decoder (DXVA?) with EVR Custom. But I don't think the latter option has anything to do with MPC's development. Last edited by Rash; 18th August 2007 at 23:18. |
20th August 2007, 17:16 | #488 | Link |
Feature request:
Disable Vista monitor power saving only when playback is active, thus not when playback has stopped.
MPC-HC 2.1.7.2 |
21st August 2007, 04:53 | #489 | Link |
Since this tread deals with mpc, I post 2 bugs that appear while I use mpc.
1) While I select - view> on top> while playing, sometimes when I open a folder/window it will cover up mpc(playing some video) rather than mpc itself stay on top while playing. But once I click on mpc again, it will stay on top even I click on the folder/window. 2) While I select - play> after playback> close, after video playback it shutdown mpc. I thought it suppose to close the video I m playing, m I right? Btw, this 'play' bug occur when i used the old mpc6940, haven't try it on mpchc or clsid updated version. Juz wonder m I the only 1 who have this 2 bugs. I m using WinXP. Thks. |
27th August 2007, 14:10 | #493 | Link |
That has already been done in the current code present in SVN
MPC-HC 2.1.7.2 |
27th August 2007, 18:32 | #494 | Link |
Can anybody with SVN access please upload a little patch for me? I've done the changes to Casimir's SVN, but I don't know SVN well enough to "upload" something.
http://madshi.net/dtsac3source.zip Contained is a new version of DTSAC3Source.cpp (together with a new compiled dtsac3source.ax). There are 3 changes in the source code: (1) m_AvgTimePerFrame calculation was incorrect for AC3. (2) m_AvgTimePerFrame calculation was incorrect for DTS. (3) Fix for problems with audio sync with Blu-Ray/HD DVD DTS files. The problem with (3) is this: Usually 1536kbit/s DTS tracks have 2013 bytes per frame. But DTS tracks taken from HD DVD and Blu-Ray strangely only have 2012 bytes per frame. DTSAC3Source handled this mathematically correctly. But audio sync slowly drifted away from the video. We have to mathematically handle the 2012 frames as if they were 2013 bytes long to keep audio sync while seeking. |
27th August 2007, 18:50 | #495 | Link | |
ffdshow/AviSynth wrangler
You could post your patch here, though, and point Casimir666 at it. Make sure you post a patch (as opposed to a full source file), though, as that makes it easier to apply it when other changes were made to that file in the meantime. As for using SVN - grab TortoiseSVN if you want a powerful but easy-to-use SVN client. You can even use it to produce the diff I mentioned above. np: Nine Horses - Serotonin (Burnt Friedman Remix) (Money For All)
now playing: [artist] - [track] ([album]) |
27th August 2007, 19:28 | #496 | Link | |
27th August 2007, 19:56 | #497 | Link |
Care to elaborate what happened? I never had any problems with it...
np: Nine Horses - Birds Sing For Their Lives (Money For All)
27th August 2007, 20:01 | #498 | Link |
@madshi
Your modifications will be included in next release (clsid patches too). I have start looking for Vista 64 support but it's a lot of work and it will not be available in near future. If someone have 64 bits asm routines for colorspace conversion and IDCT it will be helpfull
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net |
27th August 2007, 20:41 | #499 | Link |
Otaku
@casimir666
Those are good news, also please check this issue I've posted before.
27th August 2007, 20:59 | #500 | Link |
Well, during/after the first reboot after the SVN client installation the Explorer froze and consumed my DualCore CPU so much that it took me several minutes of waiting to open the task manager and kill the Explorer. Might have been bad luck. Maybe the problem wouldn't have shown another time. But since I don't really plan to use SVN in the near future, I decided to go safe and uninstall the SVN client again.
