15th September 2010, 09:36 | #2622 | Link |
23sKiDdOo!
I have a NVIDIA 9500GS.
I can get DGTools2026 working with MPEG2Files, only when i use "Use_D3D=1" (in the *.ini file). Both, DgIndexNV and DGSource() are working quite well. But when i load *.x264 files into DGINDEXNV, it crashes with the following error message: "Failed to start GPU Decoder" Error#100 Maybe it is the Graphic Card, which is garbage... BTW: What is the D3D-Mode all about - what exactly is the difference and disadvantages to native driver support? I know that there should be disadvantages, but i am just curious what the technical background is...maybe someone can answer this question...Thanks.. Last edited by Hagbard23; 15th September 2010 at 10:12. |
15th September 2010, 15:38 | #2623 | Link |
just wanted to thank you. whatever you did fixed my problem with having to open the preview window every time i opened a .avs in megui!
quick question, though i dont know if it relates to dgtools or not. sometimes i'll open up one of the various tools in megui while i have an encode going and it will crash out megui but if you look at task manager the encode is still running. it eventually finishes up at the time it's supposed to and the file is intact. any clues as to what's going on? |
15th September 2010, 15:56 | #2624 | Link | |
@neuron: move the post to the GUI forum if necessary. |
15th September 2010, 19:50 | #2627 | Link |
Acid fr0g
Neuron2, if any spare time, please make DGIndexNV remember in and out directory separately. Sometimes the ripping source drive is one, the output project one is another.
And the filling status in in the Windows7 bar (a-la-MeGui to tell one), would be very useful if audio is off (hint: office) and the demux is long... Thanks
@turment on Telegram |
16th September 2010, 08:52 | #2628 | Link | |
1. load 5 jobs into megui 2. close megui, then open megui 3. hit start at this point megui should gray out. you then have no option but to close megui in which case you get a crash window with this error: Problem signature: Problem Event Name: APPCRASH Application Name: MeGUI.exe Application Version: 0.3.5.12 Application Timestamp: 4c8d3471 Fault Module Name: nvcuda.dll_unloaded Fault Module Version: 0.0.0.0 Fault Module Timestamp: 4c379085 Exception Code: c0000005 Exception Offset: 000000000945564f OS Version: 6.1.7600.2.0.0.256.48 Locale ID: 1033 Additional Information 1: 2264 Additional Information 2: 2264db07e74365624c50317d7b856ae9 Additional Information 3: dbaf Additional Information 4: dbaf93d46593b450aa6261886a14bd19 after it closes down you will notice x264 is still running in taskmanager and cpu usage confirms that it is indeed encoding script i use if it mattters: # Set DAR in encoder to 16 : 9. The following line is for automatic signalling global MeGUI_darx = 16 global MeGUI_dary = 9 LoadPlugin("C:\Program Files\Megui_x64\tools\dgindexnv\DGDecodeNV.dll") DGSource("D:\8\00067.dgi",fieldop=0) this happens in both 32 and 64 bit megui. sorry if this doesnt belong in this thread but i didnt know how else to reply to zathor's post directly. *edit* if you do not close megui and then open it back up as per step #2, all will be fine. it will not gray out and crash. *edit #2 forgot to answer zathor's questions* graphics memory is 512meg. usage on gpu-z is normal, around 8%. i explained the crash type and the report is posted. *edit #3* after crashing this way around 4 or so times megui gets messed up and i have to reinstall otherwise it crashes anytime i even attempt to enque a job. Last edited by gahz; 16th September 2010 at 09:28. |
18th September 2010, 15:55 | #2630 | Link |
"1. Activation of a screensaver or standby mode may interfere with proper operation of the NV tools. They should be disabled during use of the NV tools."
Hmnm, dumb question, no doubt, but does that also mean you can't game while DGSource is running?
Gorgeous, delicious, deculture! |
18th September 2010, 17:05 | #2631 | Link |
Mr. Sandman
@neuron2: as promised here's an MKV with vorbis audio (dgindexnv cant demux it). it's 2 channels, if you need a MKV with vorbis 5.1 channels audio just ask.
http://www.mediafire.com/?p50eerrupiuyciq
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 18th September 2010 at 17:19. |
19th September 2010, 09:17 | #2632 | Link |
Hello,
I have warnings "CuvidDecodePicture: 1" when seeking in DGIndexNV with some VOB files loaded, can I just ignore them safely as there are just warnings or do I need to provide you a sample so that you can check ? Underground78 |
19th September 2010, 11:12 | #2633 | Link |
Sadly, I seem to have a problem with DGDecNV, after all. :( All seemed to go so well. I was trying to encode the following job:
LoadPlugin("C:\Program Files (x86)\dgdecnv2026\DGDecodeNV.dll") DGSource("f:\jobs\push.dgi").ConvertToYV12() Crop(0, 132, 0, -132) MCTemporalDenoise(settings="low") GradFun2DBmod(thr=1.4,thrC=1.0,mode=0,str=1.2,strC=0.0,temp=50,adapt=64,mask=false,show=false) SupTitle("f:\jobs\push_exp.sup", forcedOnly=false, swapCbCr=false, relocate=true, relocOffset="0,0,0,0") Also, DGSource seems to use a wicked amount of memory. At ca. ~5 GB total physical memory, it's using 1.5-2GB over what I'm used to. Not that I mind, per se; but I actually expected lower memory usage (as some would be offloaded to the GPU memory?). So, I'm suspecting something is wrong, really. I use Windows 7, 64-bit, with a GTX285 and the latest 258.96 drivers.
19th September 2010, 13:22 | #2634 | Link | |
19th September 2010, 13:44 | #2635 | Link | |
Memory usage also steadily increases with DGSource; not dramatically, but still noticeable; from 4.6 to 5.1 GB over time (at which point I aborted the encode, since, at 2% CPU usage for x264, the decoder hardly seemed to feed any frames any more). And yes, I use the official 2.58 AviSynth release.
19th September 2010, 14:17 | #2637 | Link |
Mr. Sandman
those drivers are in beta stage for a reason...
19th September 2010, 16:52 | #2638 | Link | |
Which process uses how much memory? Did you check memory usage with Process Explorer? |
20th September 2010, 06:14 | #2640 | Link |
Acid fr0g
We can count WHQL drivers release on two hands. And we know that WHQL is a way for Microsoft to get money too, not a proof of quality.
I need feedback, not moaning
